Recording MIDI
Discussion in 'alt.steinberg.cubase' started by Orchmenides Tubilderborst, Jun 16, 2009.
  1. Orchmenides Tubilderborst Guest
    Message Count:
    O.K.
    I'm currently constructing a drum track one one MIDI channel (using
    Addictive Drums) The transport bar is set at Mix/Merge so that I can go back
    and add (say ) snare to the original kick drum, then add cymbals, toms etc.
    When I add the next 'layer' the data is there and audible at playback, but
    the area of the track which is 'overdubbed' is greyed out and no data is
    visible even in the Drum Editor; all of which makes editing and tweaking
    very difficult. Is there any way to stop it from 'greying-out' on recording
    and/or to 'de-grey' the area(s) already greyed out, in order to edit the
    data as necessary?
    Thanks in advance.
    Mart.
      • Advertising
  2. S.O.D.D.I. Guest
    Message Count:
    "Orchmenides Tubilderborst" <> wrote in message
    news:9kMZl.45512$2...
    > O.K.
    > back and add (say ) snare to the original kick drum, then add cymbals,
    > toms etc. When I add the next 'layer' the data is there and audible at
    > playback, but the area of the track which is 'overdubbed' is greyed out
    > and no data is visible even in the Drum Editor; all of which makes editing
    > and tweaking very difficult. Is there any way to stop it from
    > 'greying-out' on recording and/or to 'de-grey' the area(s) already greyed
    > out, in order to edit the data as necessary?
    > Thanks in advance.
    > Mart.
    Touch the part with the 'glue' tool.
  3. Orchmenides Tubilderborst Guest
    Message Count:
    Hey! S.O.D.D.I. It worked!! Thank you so much!! If you knew the hours I've
    trawled Manuals, Web Sites etc, and it was THAT simple!!! Thanks once again.
    Mart.
    "S.O.D.D.I." <> wrote in message
    news:...
    >> O.K.
    >> (using Addictive Drums) The transport bar is set at Mix/Merge so that I
    >> can go back and add (say ) snare to the original kick drum, then add
    >> cymbals, toms etc. When I add the next 'layer' the data is there and
    >> audible at playback, but the area of the track which is 'overdubbed' is
    >> greyed out and no data is visible even in the Drum Editor; all of which
    >> makes editing and tweaking very difficult. Is there any way to stop it
    >> from 'greying-out' on recording and/or to 'de-grey' the area(s) already
    >> greyed out, in order to edit the data as necessary?
    >> Thanks in advance.
    >> Mart.
      • Advertising
Share This Page
