I am connecting my client's K2500 to my PC in order to record his sequencer events via midi. I am using Cubase SX2.0. However his sequences have many tempo changes and odd meters. Is there anyway I can record those changes along with his midi events in real time? The basic idea is that I'm trying to recreate his sequences in SX and I need to match his timing information bar for bar.
I have a K2500 and I use Sonar.... You can export the sequence directly from the K2500 to a Standard MIDI File and drop it to a floppy.... In Sonar I can then just open the SMF from the disk...and everything is there....tempo changes, odd meters....etc..... At some point I end up saving the project into the Sonar format..... Hope this helps! MC "Keith" <> wrote in message news:6NtYc.14841$Ka6.14561@okepread03... > I am connecting my client's K2500 to my PC in order to record his > sequencer events via midi. I am using Cubase SX2.0. However his sequences > have many tempo changes and odd meters. Is there anyway I can record those > changes along with > his midi events in real time? The basic idea is that I'm trying to recreate > his sequences in SX and I need to match his timing information bar for bar. > >
We've thought of that. The problem is that his sequences are broken up into many midi files, each file representing a different section of the song. Then there is the one master file which tells the K2500 how to put the different files together into one sequence. So how do we join the files together in order to import the entire song as one sequence? "MC" <> wrote in message news:rS9Zc.6914$... > I have a K2500 and I use Sonar.... > You can export the sequence directly from the K2500 to a Standard MIDI File > and drop it to a floppy.... > In Sonar I can then just open the SMF from the disk...and everything is > there....tempo changes, odd meters....etc..... > > At some point I end up saving the project into the Sonar format..... > Hope this helps! > MC
Not sure about Cubase....but in Sonar you can open multiple projects and pretty much cut and paste where you want your tracks to start and end...with meter and tempo changes. How it works in Cubase....I have no idea....I just know Ive brought together multiple files in Sonar. Sounds like thats a Cubase function that needs to be researched....especially if the K2500 has all the different MIDI files stored..... "Keith" <> wrote in message news:dYpZc.15735$Ka6.14950@okepread03... > We've thought of that. The problem is that his sequences are broken up > into many midi files, each file representing a different section of the > song. Then there is the one master file which tells the K2500 how to put the > different files together into one sequence. So how do we join the files > together in order to import the entire song as one sequence? > > > "MC" <> wrote in message > news:rS9Zc.6914$... > > I have a K2500 and I use Sonar.... > > You can export the sequence directly from the K2500 to a Standard MIDI > File > > and drop it to a floppy.... > > In Sonar I can then just open the SMF from the disk...and everything is > > there....tempo changes, odd meters....etc..... > > > > At some point I end up saving the project into the Sonar format..... > > Hope this helps! > > MC > >
