Hello good people, After a long break using cubase sx2 i'm back on it and with a problem; when i record an audio track (headphones to monitor) the record enabled track also records the backing track or any sound going through the sound card (m-audio delta). I cant see why its doing this any help greatly appreciated, thanks in advance, JJ
On Thu, 23 Sep 2010 03:52:42 -0700 (PDT), Jack Jarmush <> wrote: >Hello good people, After a long break using cubase sx2 i'm back on it >and with a problem; when i record an audio track (headphones to >monitor) the record enabled track also records the backing track or >any sound going through the sound card (m-audio delta). I cant see why >its doing this any help greatly appreciated, thanks in advance, >JJ Sounds like a routing/input problem, nothing fancy. Just select the input for the audio track in you vst settings?
On Sep 23, 2:44 pm, Max Doorrijhoogte <> wrote: > On Thu, 23 Sep 2010 03:52:42 -0700 (PDT), Jack Jarmush > > <> wrote: > >Hello good people, After a long break using cubase sx2 i'm back on it > >and with a problem; when i record an audio track (headphones to > >monitor) the record enabled track also records the backing track or > >any sound going through the sound card (m-audio delta). I cant see why > >its doing this any help greatly appreciated, thanks in advance, > >JJ > > Sounds like a routing/input problem, nothing fancy. > Just select the input for the audio track in you vst settings? found the prob.... had the wrong asio driver selected.
On Thu, 23 Sep 2010 06:42:06 -0700 (PDT), Jack Jarmush <> wrote: >On Sep 23, 2:44 pm, Max Doorrijhoogte <> wrote: >> On Thu, 23 Sep 2010 03:52:42 -0700 (PDT), Jack Jarmush >> >> <> wrote: >> >Hello good people, After a long break using cubase sx2 i'm back on it >> >and with a problem; when i record an audio track (headphones to >> >monitor) the record enabled track also records the backing track or >> >any sound going through the sound card (m-audio delta). I cant see why >> >its doing this any help greatly appreciated, thanks in advance, >> >JJ >> >> Sounds like a routing/input problem, nothing fancy. >> Just select the input for the audio track in you vst settings? > >found the prob.... had the wrong asio driver selected. Cool. Happy Cubase-ing!
