Roland D 110
Discussion in 'alt.music.synth.roland' started by Basso, May 4, 2007.
  1. Basso Guest
    Message Count:
    I have just picked up a D-110 for my son to use with his keyboard so
    he can have some synth sounds to add to his piano sounds. I have a
    Yamaha TG 500 which is great, and relatively easy to use, but we are
    scratching our heads over the Roland! All we want to do at this
    stage
    is use it as a sound module, and just page throught the preset
    sounds.
    This is a cinch on the TG500 - select the bank, press the right
    button
    to page through the sounds, play them.
    The only way we can get the Roland to play sounds is to use the
    keyboard to select sounds by changing the midi channel, and even then
    we only get a few of them. Is there any way we can set the roland
    to,
    say, just transmit on all channels, and just go through the sounds
    by
    paging up and down? We have the manual, but that is just baffling......
      • Advertising
Share This Page
