My biggest (and only) complaint about the G1000 is that I can't figure out how to save the MIDI output settings in a performance. For example, I want to run other rack units together with the g1000 but the rack units are set to receive messages from channel 1 and the G1000 defaults to channel 4 to send the messages. Also, when you boot up the G1000 all of the channels for the arranger are set to transmit "ON" and all arranger and local sounds are set to tx program change "on". This is a pain because every time I want to play the keyboard with the rest of my rack gear, I have to go through and manually turn off all the program changes for every channel and turn off the "TX" for the arranger. It takes too much time. So to make this short. Does anyone know how to change the default (or boot up) MIDI transmit settings? Or do you know how to save the MIDI transmit settings into a performance for easy access? Any advise would be very helpful. Thanks Rob
