Roland KR7
Discussion in 'alt.music.synth.roland' started by Al, Dec 4, 2005.
  1. Al Guest
    Message Count:
    Just purchased a Roland KR7 Digital Piano. It came with music in the GS midi
    file format which sounds excellent. We would like to buy good quality GS
    midi files but do not know where to look. I have searched the Internet using
    Google for Roland GS Albums and only found two links:-
    http://www.bck.co.uk/
    http://www.stylediskwarehouse.com/rolandmidifiles.htm
    both appear to sell the same albums.
    Could anyone recommend download sites or stores that sell music in this
    format?
    Thanks a lot.
    Al
      • Advertising
  2. Paul Lifony Guest
    Message Count:
    A friend of mine has purchased midi files from Trycho Tunes.
    www.tryco.com They were pretty good versions of the songs he wanted. I
    believe the GS midi file format is just a GS=General Standard midi
    file that conforms to the midi specification that instrument
    manufacturers agreed to. You should be able to get them from most
    online midi file retailers. Here's another site to look at...
    http://www.capmusic.com/midi.htm
    Good Luck
    >format?
    >Thanks a lot.
    >Al
  3. Al Guest
    Message Count:
    Thanks.
    Any recommendations on a good midi player to use with Windows on a PC?
    Thnx Al
    "Paul Lifony" <> wrote in message
    news:...
    > Good Luck
    >>midi
    >>using
    >>format?
    >>Thanks a lot.
    >>Al
      • Advertising
Share This Page
