Roland RD300SX setups advice
Discussion in 'alt.music.synth.roland' started by nickapay@googlemail.com, Jul 13, 2007.
  1. Guest
    Message Count:
    I'm thinking about buying a RD300SX for gig work. I've studied the
    manual but it's not clear about whether one is able to set up batches
    of tones on each setup (of which there are 32 setups). I would like to
    be able to trigger these sounds from another midi keyboard by
    selecting different channels which will correspond to the channels
    that the tones on the rd300 have been setup on. If this is possible,
    then am I able to select any sound from the entire 400 odd sounds
    including allocating any of the GM2 sounds to any of the channels.
    Thanks in advance for any advice.
    Nick
      • Advertising
Share This Page
