sample rate makes little sense
Discussion in 'cakewalk.audio' started by Adam Skeggs, Nov 8, 2003.
  1. Adam Skeggs Guest
    Message Count:
    Hi,
    I don't understand how a sample rate of say 44.1kHz can be any good at all
    at higher frequencies. I guess I am missing something but surely if the
    frequency being sampled is 20kHz then each cycle would be sampled only twice
    (approx). If for instance you had a sine wave at 20kHz and happened to
    sample on the peaks (approx) then a sine wave would look just like a square
    wave, ie, not representative of the waveform at all!
    Is it true that the higher the frequency the less accurate the sampling?
    Adam.
      • Advertising
  2. Dennis Bathory-Kitsz Guest
    Message Count:
    Exactly right.
    There are lots of good tutorials on this, but put very simply, it was
    thought that it simply didn't matter if there were a square wave at
    20KHz because you couldn't hear it. A square wave is a sine wave +
    harmonics, and if you can't hear the harmonics, then all you hear is the
    fundamental = the sine wave.
    Now that's turned out to be not quite true, for lots of reasons, not
    least of which is that the harmonics in that square wave create
    unpleasant results with the harmonics of other square waves in the
    sample -- causing resulting tones (subharmonics).
    One way to get around this was brick-wall filtering at the high end, but
    this caused some measure of phase-shift that was perceived by some as
    grittiness and loss of soundstage in early digital recordings.
    So higher sampling rates have been used and more advanced filters.
    That's just a start, somewhat misleading if you take it as the complete
    answer. Look around for tutorials online ... there are lots of good
    ones!
    Dennis
  3. Pat Farrell Guest
    Message Count:
    On Sat, 8 Nov 2003 13:58:42 +1100, "Adam Skeggs"
    >(approx).
    Correct. You have to sample at twice the signal rate to get anything
    useful. Nyquist invented the idea.
    No. Unless your sampling hardware is lame. Some consumer stuff
    may not work well at high rates, but the consumers won't care.
    Pat http://www.pfarrell.com/prc/
  4. Dennis Bathory-Kitsz Guest
    Message Count:
    I read his question the other way around -- higher the frequency being
    sampled, not higher the frequency of sampling! Language, darn it.
    Dennis
      • Advertising
  5. Pat Farrell Guest
    Message Count:
    On Sat, 08 Nov 2003 04:08:59 GMT, Dennis Bathory-Kitsz
    Had not thought of it that way.
    Lets try again, with a little more crispness in the language.
    The CD standard rate is 44.1kHz. Its Nyquist rate is
    22.05 kHz. It can theoritically capture signal rates as
    high as 22kHz. Which is higher than the 20-20k Hz range
    of "human" hearing that audio engineers have used for
    decades.
    But you must have an anti-aliasing filter at the Nyquist
    rate, that is, a low pass filter that throws away everything
    above 22kHz, because you will not be able to identify
    and recreate signals (for example 24kHz) when sampled.
    In reality, filters are more like 6dB per octave, or 12dB per octave,
    so real world analog filters start lower, say at 15kHz.
    Starting lower is bad, we pay big bucks for mics and preamps
    that go up. Or you can try using a brick wall filter that
    starts at 20kHz, but they are evil, cause all sorts of
    phase problems in the audible range.
    So, what do you do if you think that interharmonic
    sounds exist in the 15kHz to 30kHz range that
    you have to capture digitally?
    You have only one option, sample at a higher rate.
    Sampling at 88.2 kHz will let you try to capture
    signals at 44.1kHz, which means
    you are likely to actually capture signals at 30kHz.
    Sampling at really high rates, say 192kHz would let
    you capture any signal that exists in the 80kHz range.
    My personal belief is that humans can detect phase
    relationships far better than they can detect frequency,
    and higher sample rates help phase capture
    as well.
    I am cautious about prosumer gear that claims to
    record at high rates, many of them quote a rate
    but without any supporting information (such
    as distortion at a given bandwidth, or even
    frequency response).
  6. foldedpath Guest
    Message Count:
    "Pat Farrell" <> wrote in
    news::
    <some snippage>
    > as well.
    My question with high sample rates is always... how much of this really
    matters, when you're crunching the final product down to 16 bit 44.1 kHz
    audio for distribution as MP3's and audio CD's?
    It's nice to hear (or think you hear) subtle nuances on a high-end set of
    monitors, in a perfectly tuned room, with your D/A running at 24 bits/96k
    or 24/192k when you're mixing. But if the extra information doesn't help
    you do a better mix once you're down to 16/44.1, then what's the point of
    all the extra CPU cycles and disk storage?
    I've done some tests comparing 24/95 and 24/44.1 source files after they've
    been converted down to an audio CD, and that hasn't convinced me that I
    need to record and mix at 24/96. Maybe my software just isn't good enough
    to preserve any possible phase information that would survive the
    conversion, or maybe these old ears have lost too much high frequency
    range. But whatever the reason, I'm just not hearing enough difference to
    care about (if I'm hearing anything at all).
    If I was producing material that would be released on DVDA or SACD, that's
    another thing.
    Mike Barrs
  7. Adam Skeggs Guest
    Message Count:
    "Adam Skeggs" <> wrote in message
    news:3fac635c$0$3501$...
    > Hi,
    twice
    square
    > Adam.
    A 1Hz sine wave would get 44100 samples so you could draw a convincing
    picture of it.
    A 20kHz sine wave would get 2 samples. Join up the dots on that. It could be
    anything. Since demonstrably the sound is OK it must be that at high
    frequency (and decreasingly at lower and lower frequencies) it doesn't
    matter what the waveform is. Like a distant object to the eye, we can't see
    the detail so as long as it looks roughly like a cow it's a cow.
    If we went for 1000 samples of a 20kHz waveform that would be a 20MHz sample
    rate.
    I guess if we were dogs we would complain about the poor quality. Lucky our
    ears are not much good.
    Adam.
  8. Pat Farrell Guest
    Message Count:
    On Sat, 08 Nov 2003 06:40:04 -0000, foldedpath
    If you are aiming at MP3s, I believe that the answer is clearly "not
    worth it, don't matter." For Red Book audio as a target....
    Oh no, an engineering question!
    Engineering is about deciding what is good enough. When do you
    add more steel to a building's frame and when it added steel
    just wasted money.
    It is not engineering to buy the best of every part to make
    a cost is no object $10,000 preamp. It is engineering to make
    a good preamp that sells for $500.
    In simple terms, no group or body who has come into my studio
    has an audience who cares.
    Right now, the CPU cycle budget is fine, and wasting a few cycles
    is not a problem. In the days of Gigahertz processors, I don't run out
    of tracks or effects cycles. YMMV, seriously. I don't worry about
    the disk storage at all. Disks are nearly free. I do worry about
    disk IO capacity, both during processing and when moving
    the tracks/mix to another machine. Even over 100baseT,
    moving a gigabyte takes real time.
    I was trying to post an explaination of what higher sample
    rates do. Whether we really can afford them is a totally different
    topic. One that I think is a lot more useful than how to
    get surround sound out of Sonar (or Vegas or Logic ...)
    since all surrond sound is at best medium fidelity.
    Cycles for nothing and Disks for free....
  9. Guest
    Message Count:
    Yes this is a tough question.On Sat, 08 Nov 2003 01:59:34 -0500, "Pat
    Agree.
    Ok many will disagree but here goes. use the highest rate format your
    gear will handle. Why? Because that will give you the cleanest,
    clearest original signal. If 10 years from now you decide to put out
    a DVD or SACD you will have a better product with higher original
    sample and bit rates. Now Relaize that if you are doing nmodern music
    (rap hip hop and such) most of which is compressed to beat the band
    and left with a 3 to 6 db dynamic range you will not notice much
    difference.
    In the end the cleaner and clearer the original source material is the
    better I.E.(cleaner and clearer) end product you can have (if that is
    your desire).
    When you start to process individual tracks the higher the sample and
    bit rates mean that you have better headroom and again less distortion
    from rounding errors and such.
    I am one of those folks who could hear a distinct difference between
    16 and 24 bit and 48k, and 96k sampling. To me things had more air
    and were clearer. Many people hear nothing. I think that means that
    some peoples ears are more well trained or hear higher freqs but some
    may say it is just BS. I participated in some blind tests in a top
    flight studio and only once in 40 examples was I wrong. So for me the
    answer is simple. Use the highest rates you can get away with.
    Of course if you have a large number of tracks and high bit and sample
    rates you may run out or low on hard drive through put.
    Good luck, I hope this makes was close to what you were looking for.
    regards,
    dh
  10. Michael Guest
    Message Count:
    In <news:3fac9b55$0$3498$>,
    > sample rate.
    > Lucky our ears are not much good.
    I can clearly hear the diff between a 44.1K and a 96K sampled sound if I
    listen to it really closely a few times.
    But does anyone really listen that closely to music over and over and over
    just to decide how "good" the recording is?
    ((U))
    M
  11. Guest
    Message Count:
    Hi
    On Fri, 7 Nov 2003 23:43:35 -0800, "Michael" <>
    Not the point. The point is that the cleaner and clearer it starts
    out the cleaner, clearer and more accurate your end result is. Now
    whether you find that to be a good thing is another completely
    different conversation.
    regards,
    dh
  12. Michael Guest
    Message Count:
    In <news:>,
    said:
    > Hi
    >> if I listen to it really closely a few times.
    >> and over just to decide how "good" the recording is?
    > regards,
    > dh
    Yeah... thanx, Dave.
    I did read further ahead and realized I was shortsighted about what I hear
    on the first go 'round.
    A cleaner, more accurate sound can be fudged and fiddled to make it less so
    if you like, but a screwed one can't be really unscrewed.
    ((U))
    M
  13. Guest
    Message Count:
    Hi Michael,
    Exactly!!
    regards,
    dh
    On Sat, 8 Nov 2003 00:35:57 -0800, "Michael" <>
    wrote:
    >In <news:>,
    > said:
    >> Hi
    >> regards,
    >> dh
    >((U))
    > M
  14. Adam Skeggs Guest
    Message Count:
    news:3fac9b55$0$3498$...
    > > Hi,
    all
    > twice
    > square
    > > Adam.
    > picture of it.
    be
    see
    sample
    > rate.
    our
    > Adam.
    I did read the later posts I am just posting in this position for purposes
    of "narative flow".
    Another perspective: Say your minimum samples (points of sampling) on a sine
    wave was 10; I picked that because I think you could join up 10 dots and it
    would look pretty much like a sine wave though it would obviously look
    chunky (not smooth). It's arbitrary but I have decided to call everything
    with less than 10 sample points junk. On this "logic" at 44.1Khz the highest
    frequency to have at least 10 dots per cycle is 4410 Hz. This is getting to
    the upper limit of a guitar.
    So the upper limit of my guitar is dodgy. My cymbals are going to be
    complete crud (visually at least).
    So far so good. Going to 96kHz lifts my 10 sample point limit to 9600Hz.
    This is in cymbal land and should give me a quality crash. On the other
    hand, I use sampled drums which are probably not that good anyway.
    OK I think I get it now.
    Adam.
  15. Pat Farrell Guest
    Message Count:
    On Sat, 8 Nov 2003 23:44:10 +1100, "Adam Skeggs"
    Good approach to visualize things.
    In reality, since you know you are going to regenerate
    a sine wave, you can do it with fewer points.
    But the analogy is correct.
    So far, fine, except that what makes an instrument sound like
    the instrument is the overtones. A guitar and trumpet play the same
    note -- the fundamental sine wave is identical. It is the overtones
    at higher frequencies that let you tell a trumpet from a guitar,
    and an acoustic guitar from a jazz electric, or shred metal at 11.
    BTW, electric guitars are two piece instruments, they
    have the guitar part, and the amplifier part. The tones
    are generated by the combination. Many of the high
    frequency tones in an electric guitar signal are caused
    by distortion and weirdness of the amplifier and the amp's
    speakers.
  16. foldedpath Guest
    Message Count:
    news::
    >>really matters, when you're crunching the final product down to 16 bit
    >>44.1 kHz audio for distribution as MP3's and audio CD's?
    >>of monitors, in a perfectly tuned room, with your D/A running at 24
    >>bits/96k or 24/192k when you're mixing. But if the extra information
    >>doesn't help you do a better mix once you're down to 16/44.1, then
    >>what's the point of all the extra CPU cycles and disk storage?
    > just wasted money.
    Good point.
    Same here, at least for now.
    In my own situation, moving away from recording at 44.1 kHz to a higher
    sampling rate would actually mean ditching my current audio recording
    platform (Emu/Ensoniq Paris), since it's a "vintage" discontinued DAW that
    will never be updated for higher sample rates.
    Every once in a while, I re-visit this question... wondering if maybe I'm
    sticking to 44.1 kHz just to hold onto the sound quality and UI of this
    system (which I love). I have to be careful that I'm not fooling myself.
    But so far, I'm pretty convinced that I wouldn't gain anything meaningful
    by moving up to higher sample rates, and I have many things now in the
    Paris system that I'd miss if I switched systems.
    BTW, I do use Sonar... but only as a sequencer and soft synth host. I shoot
    all the DXi/VSTi audio via ADAT lightpipe into Paris when I'm working with
    audio.
    Gotcha, and that was good info, thanks.
    Mike Barrs
  17. Scott Reams Guest
    Message Count:
    > picture of it.
    be
    > anything.
    Well... any detail in a 20KHz waveform represents frequencies higher than
    20KHz.
    -S
  18. John Ridges Guest
    Message Count:
    OK, I'm going to try to clear up all this sampling munbo jumbo.
    In the first place, the filter in a CD player or soundcard output is
    the anti-imaging filter, not the anti-aliasing filter (more on
    anti-aliasing filters later). The fundimental problem with a building
    a CD anti-imaging filter is trying to go from 0dB in the passband to
    -80dB (or so) in the stopband in only 4.1 KHz. How did I get this
    number? Well, when you reproduce samples, the spectrum below the
    nyquist frequency (0-22.05 KHz) is "mirror imaged" above the nyquist
    frequency (22.05-44.1 KHz), so your theoretical maximum frequency of
    20KHz will appear again at 24.1KHz. The purpose of the anti-imaging
    filter is to filter out this image. The problem is that it needs to
    be very steep, and steep filters are hard to make, and even when you
    do you get lots of ripples in the passband. The steeper the filter,
    the bigger the ripples, and going from 0 to -80dB in 4.1 KHz is very
    steep indeed. Steep filters also invariably change the phase of the
    frequencies as they get near the stopband, and many people think they
    can hear that effect. There are ways around the problem, a popular
    one being oversampling, where the sample rate is cranked way up (like
    16 times 44.1 KHz) alowing the use of a very gentle analog filter and
    doing all the really hard filtering with a digital filer, which can be
    built very nearly perfect.
    What does this have to do with SONAR? Well, while there are people
    who claim to be able to hear above 20KHz, I tend to think the the
    improvement people hear at 96 or 192 KHz is due mostly to gentler
    anti-image filtering. Why should you sample your tracks at 96 KHz when
    you're just going to downsample them to 44.1 KHz anyway for a CD?
    That's where the anti-alias filter comes in. The anti-alias filter is
    the filter between your microphone and the A-D converter in your
    soundcard. Its got all the same problems as the anti-imaging filter,
    but any weaknesses in it will be much more obvious. For instance, any
    frequencies above the nyquist frequency that get through the
    anti-imaging filter, well, they're above human hearing anyway, so you
    probably won't notice them. But any frequencies above the nyquist
    frequency that get through the anti-alias filter get reflected down
    into the audible part of the spectrum (i.e. 35 KHz is reflected to 9.1
    KHz at a sample rate of 44.1 KHz) where they are very obvious and
    un-musical. Since it's practically impossible to biuld a filter that
    goes from 0 to -80dB in 4.1 KHz, you're either going to loose some of
    your high end because the soundcard anti-alias filter starts earlier
    than 20 KHz, or you're going to get some reflections on source
    material that has very high frequency components. So sampling at 96
    KHz could make a significant difference depending on what frequencies
    come out of your microphone (or guitar FX box) just because the
    anti-alias filters at 96 KHz have a lot more breathing room.
    As for why you should use 24 bit depth when the CD is only going to be
    16 bits, well 16 bits is actually pretty OK for music reproduction,
    but not so good when you're recording. A CD will be normalized to use
    the entire 16-bit range, but when you're recording you usually give
    yourself some headroom because you do not want to peak in digital.
    With 16 bit recording, if you give yourself 6dB of headroom (which in
    many cases is pushing it), you're only really recording at 14 bits.
    Recording at 24 bits allows you to give yourself lots of headroom and
    still have 16 good bits worth of signal after you've run it through
    your compressors and other FX.
    Of course none of this matters if you're just using softsynths and
    pre-recorded samples.
    --John
    On Fri, 07 Nov 2003 23:23:12 -0500, "Pat Farrell"
    >decades.
    >as well.
      • Advertising
Share This Page
