Saving MIDI setup in a performance Roland G1000
Discussion in 'alt.music.synth.roland' started by moylanmarketing@gmail.com, Sep 4, 2007.
  1. Guest
    Message Count:
    My biggest (and only) complaint about the G1000 is that I can't figure
    out how
    to save the MIDI output settings in a performance.
    For example, I want to run other rack units together with the g1000
    but the rack units are set to receive messages from channel 1 and the
    G1000 defaults to channel 4 to send the messages.
    Also, when you boot up the G1000 all of the channels for the arranger
    are set to transmit "ON" and all arranger and local sounds are set to
    tx program change "on". This is a pain because every time I want to
    play the keyboard with the rest of my rack gear, I have to go through
    and manually turn off all the program changes for every channel and
    turn off the "TX" for the arranger. It takes too much time.
    So to make this short. Does anyone know how to change the default
    (or boot up) MIDI transmit settings? Or do you know how to save the
    MIDI transmit settings into a performance for easy access?
    Any advise would be very helpful.
    Thanks
    Rob
      • Advertising
Share This Page
