Hi all, I'm trying to locate an old Roland FV-1 volume pedal, or equivalent, or at least the specs for same, to use with the VCF CONT input on my SH1000. Having a bit of trouble, wondering if anyone had any advice. I want to find/work out what the specs of the volume pedal are, and build/modify other devices to control the VCF using the same output specs - photovoltaic unit, theremin, wave-generator etc. Any advice appreciated.. thx, seht
