should i upgrade?
Discussion in 'cakewalk.audio' started by eyesnears, Jun 23, 2010.
  1. eyesnears Guest
    Message Count:
    I've been using home studio 2004 for quite a while. I'm happy with it
    for the most part but want to do more mastering. I record mostly
    acoustic instruments but sometimes like to add some samples or midi,
    like drums, and I'm not too that thrilled with what 04 offers. I also
    use many VST plugins so i'm not sure if the effects that the newer
    version come with are of any value.
    Does anyone have an opinion whether i should get home studio 7 or
    Sonar? I'm willing to pay more for Sonar if it does something i need.
    Again, the key is mastering. I have not really delved into it and my
    recording can use some 'polish'
    thanks
      • Advertising
  2. Glennbo Guest
    Message Count:
    In news:
    the killer robot eyesnears <> grabbed the controls of
    the spaceship cakewalk.audio and pressed these buttons...
    Mastering is something that different people use different tools to
    accomplish. Some folks like using a mastering plugin like Izotope.
    Others like using an actual mastering app, like Sony Soundforge, and
    others just use their DAW with the plugs it comes with, or third party
    plugs. I originally just used Sonar with a combination of native and
    third party plugs. Then I got Soundforge, and always mastered in it.
    Later I switched totally to Reaper, and now I do both my tracking and
    mastering in Reaper. I mix as I record, so by the time I'm laying down
    the final tracks, I'm almost done with the mix too. I don't use any
    mastering suite type of plugin, but I do use a mastering limiter on all
    my subs and master faders.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  3. Rick Paul Guest
    Message Count:
    As Glennbo suggested, there are a number of approaches to mastering, and one
    approach might be to just use some third party mastering plug-ins within
    your current Home Studio product. There are plenty of choices for those,
    such as iZotope Ozone, IK Multimedia T-RackS, the PSP Audioware MasterPack,
    various Waves plug-ins, the dB-audioware plug-ins, etc.
    That said, upgrading to the latest SONAR Producer Edition would also get you
    a bunch of mastering plug-ins from Cakewalk, including linear phase coherent
    multiband compressor and equalizer, an end of chain mastering limiter, a
    tube saturator, and probably some others I'm forgetting. And it would also
    get you a bunch of plug-ins and software instruments for other uses,
    including a pretty good quality software instrument for drums. I'm not
    familiar with the upgrade pricing from Home Studio to SONAR Producer, but it
    might well be that you could do that sort of upgrade for a similar price to
    what you'd pay for third party mastering plug-ins while getting a lot more
    functionality, both in SONAR itself and with all the toys that come with the
    Producer Edition, in the process.
    I'd be surprised if upgrading to a newer version of Home Studio would make a
    big difference in mastering capabilities, as a number of the
    mastering-oriented plug-ins aren't even in SONAR Studio Edition, only in
    Producer Edition. SONAR Producer Edition also has higher grade dithering
    than SONAR Studio Edition or SONAR Home Studio provide.
    FWIW, I've used various approaches to mastering over the years, but these
    days mostly do my mastering in SONAR Producer Edition (V8.5.3 at this
    point). Which plug-ins I use vary depending on the project and any time
    pressures, but my most frequently used mastering chains include Cakewalk's
    Linear Phase Multiband Compressor along with a number of PSP Audioware
    MasterPack plug-ins (especially Xenon and Neon HR, but often also
    MasterComp -- I also use VintageWarmer 2 at the end of my mix bus, prior to
    using a separate project for mastering; I generally mix to 64-bit, 88.2 kHz
    files, then do my mastering at that resolution).
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
    "eyesnears" <> wrote in message
    news:...
    > thanks
  4. eyesnears Guest
    Message Count:
    > familiar with the upgrade pricing from Home Studio to SONAR Producer, butit
    > Rick
    > Rick Paul
    > Web:www.RickPaul.info
    > MySpace:www.myspace.com/rickpaulmusic
    > news:...
    > > thanks- Hide quoted text -
    > - Show quoted text -
    thanks. I'll look into the pricing. Part of the reason for upgrade is
    my version is so old, i'm just assuming there are better features in
    the new. Maybe dumb on my part. Home Studio 7 xl has this Boost 11
    peak limiter, which looks like some sort of mastering for dummies tool
    (me).
    Also has Cakewalk Studio Instruments.
    I'll look into some of the plugins. Has anyone used this Har-Bal
    thing. I've heard good things about it.
      • Advertising
  5. Rick Paul Guest
    Message Count:
    news:...
    > the new.
    That is probably a good assumption.
    > (me).
    Yes, Boost 11 is a mastering peak limiter, and it's pretty easy to use.
    That is also in both versions of SONAR (i.e. Studio and Producer). SONAR
    Producer also adds the linear phase equalizer and linear phase multiband
    compressor, among other tools.
    I haven't used that specific product, but I have used similar EQ matching
    features in iZotope Ozone, and those can be helpful for trying to get a
    similar frequency balance to a reference track. My best results with Ozone
    were to pick a number of different reference recordings, then try out the
    matching (with only a 25% to 35% matching and some smoothing of the curve)
    and just listen to see which ones I like the best. Unfortunately, Ozone
    doesn't let you tweak the curve from there. You're either using the
    matching or using manual settings. Thus, I started just trying to analyze
    what was going on in the matched curve I liked best and approximate the
    settings with another EQ so I could tweak from there.
    Rick
    Rick Paul
  6. polymod Guest
    Message Count:
    "Rick Paul" <> wrote in message
    news:...
    > news:...
    Hi Rick. I believe it does let you tweak the curve from there.
    Close the Snapshots window and you still can use the manual EQ nodes to
    further adjust the EQ.
    Maybe I need some coffee >g?
    Poly
  7. Phoenix Guest
    Message Count:
    On Thu, 24 Jun 2010 22:23:10 -0700, "Rick Paul"
    tool
    > > (me).
    Boost 11 can come in handy in other apps too. Saved me time improving
    the voice track on my niece's sweet 16 vid in Vegas.
    borus
  8. Rick Paul Guest
    Message Count:
    "polymod" <> wrote in message
    news:4c24a643$0$31274$...
    Whoa!!! Nope, it looks like I'm the one who's needed coffee, and for a very
    long time now!
    I could have sworn I'd tried that before and found it just got you back to
    generic settings, but I see it is making some adjustments to the calculated
    curve. It's not necessarily what I had in mind in terms of the types of
    adjustments I might want to make -- e.g. I might want to smooth out some
    specific bumps in the calculated curve rather than just raising or lowering
    portions of the curve -- but it could certainly be more useful than the
    nothing I thought was there, and there might be some scenarios where this
    sort of thing would be preferable.
    Not sure how I missed this when I know I was looking for it. Thanks, Poly.
    Rick
    Rick Paul
  9. polymod Guest
    Message Count:
    news:...
    very
    > long time now!
    calculated
    lowering
    Poly.
    Your very welcome! After all the wealth of info I've gotten from you over
    the years it's nice to be able to give something back :)
    Poly
  10. eyesnears Guest
    Message Count:
    Ozone is a bit steep $$. Har-Bal is about $90.
    From what i read Har-bal is a bit easier to use.
  11. polymod Guest
    Message Count:
    news:...
    Better make sure about that.
    I'm 99% sure that Har-Bal is to be used in conjunction with either
    Soundforge or Wavelab. One of the first steps in the process is to analyze
    your RMS power levels to be customize based on the genre of your music.
    I have an older Har-Bal guide and it says "do not continue with this tool"
    and has examples using both Soundforge and Wavelab.
    If the above is true, Ozone may be cheaper in the long run.
    Poly
  12. polymod Guest
    Message Count:
    news:4c277494$0$22506$...
    apologies......make that:
    "do not continue *without* this tool".
    Poly
  13. eyesnears Guest
    Message Count:
    > Poly
    i saw that too but i think all you need is the wav file, do the har-
    bal thing then save the new wav file and load back into whatever daw
    software you have.I wish they had a vst plugin. Anyway, i have not
    decided on hal-bar. They say 30 day money back.
    I'm first going to just upgrade my cakewalk to home studio 7 XL.
    thanks
      • Advertising
Share This Page
