sidechain multiband compressor with Dynamic frequencies feature
Discussion in 'alt.steinberg.cubase' started by Hueyduck, Mar 23, 2009.
  1. Hueyduck Guest
    Message Count:
    Hi everyone,
    I just thought about something I'd like to try.
    I would like to use a compressor that is able to compress frequencies of
    a signal accordingly to the frequencies sent by an auxiliary signal.
    Example:
    I have a musical playback. On the other hand, I have a vocal track.
    I want the frenquencies used by the vocal track to be the trigger for
    the compression of the same frenquencies (and only them) in the
    playback track.
    When I searched the internet about this concept, I found this , for
    instance:
    http://www.barryrudolph.com/newtoys/toys/bssdpr.html
    It is a piece of hardware.
    Would it be possible to make this with a plug-in or a series of plugins?
    I would just want to heart what this process sounds like :)
    Huey
      • Advertising
  2. SODDI Guest
    Message Count:
    "Hueyduck" <> wrote in message
    news:49c7c6ff$0$2670$...
    > Hi everyone,
    > I would like to use a compressor that is able to compress frequencies of a
    > Example:
    > I want the frenquencies used by the vocal track to be the trigger for the
    > compression of the same frenquencies (and only them) in the playback
    > track.
    > instance:
    Someone IN THIS GROUP made a plug-in like that just recently.
    I'll resaearh it, get back to you.
  3. Hueyduck Guest
    Message Count:
    >> instance:
    What a coincidence! That's nice of you to look for it.
    Would you remember some key words the description of the plug in used?
    I just don't know how to say in correct english. Multiband sidechain
    compressor with dynamic frequency settings? :)
      • Advertising
Share This Page
