After I purchased the Event ASP8s a few years ago I sprang for Mogami spkr cables. They've basically been plugged in a limited # of times--hardly, if any wear. After some goofiness with one of the speakers a while back--(issue has subsided) I just figured they sounded slightly different and have opted to even up the volume/EQ the with the trim pots. It's always bugged me because I know (even with my tired ears) that the spkrs do not sound matched like they should. After extensive troubleshooting I have deduced that one of the spkr cables does not sound like the other --ie--slightly less volume--not as full and a bit less bass. I plugged in a garden variety Hosa and problem solved--matched full sound (volume/tone).
In news:hr4km7$bd2$-september.org the killer robot "jeffl" <> grabbed the controls of the spaceship cakewalk.audio and pressed these buttons... > After I purchased the Event ASP8s a few years ago I sprang for Mogami > spkr cables. They've basically been plugged in a limited # of > times--hardly, if any wear. After some goofiness with one of the > speakers a while back--(issue has subsided) I just figured they > sounded slightly different and have opted to even up the volume/EQ the > with the trim pots. It's always bugged me because I know (even with > my tired ears) that the spkrs do not sound matched like they should. > After extensive troubleshooting I have deduced that one of the spkr > cables does not sound like the other --ie--slightly less volume--not > as full and a bit less bass. I plugged in a garden variety Hosa and > problem solved--matched full sound (volume/tone). I always thought cheep cable was the best! -- Remove YourHeadFromYourAss to Reply by email ________ __ / ____/ /__ ____ ____ / /_ ____ / / __/ / _ \/ __ \/ __ \/ __ \/ __ \ / /_/ / / __/ / / / / / / /_/ / /_/ / \____/_/\___/_/ /_/_/ /_/_.___/\____/ --------------------------------------------------------------------- Glennbo http://www.soundclick.com/glennbo Non-Linear Sound http://www.soundclick.com/jambits Hear My Music http://www.soundclick.com/ThePseudonyms
On 4/26/2010 1:17 PM, Glennbo wrote: > In news:hr4km7$bd2$-september.org the killer robot "jeffl" > <> grabbed the controls of the spaceship > cakewalk.audio and pressed these buttons... > >> After I purchased the Event ASP8s a few years ago I sprang for Mogami >> spkr cables. They've basically been plugged in a limited # of >> times--hardly, if any wear. After some goofiness with one of the >> speakers a while back--(issue has subsided) I just figured they >> sounded slightly different and have opted to even up the volume/EQ the >> with the trim pots. It's always bugged me because I know (even with >> my tired ears) that the spkrs do not sound matched like they should. >> After extensive troubleshooting I have deduced that one of the spkr >> cables does not sound like the other --ie--slightly less volume--not >> as full and a bit less bass. I plugged in a garden variety Hosa and >> problem solved--matched full sound (volume/tone). > > I always thought cheep cable was the best! > The clearance bin at my local GC is full of cables that are made by Monster.
In news:hr4mdh$792$-september.org the killer robot kitekrazy <> grabbed the controls of the spaceship cakewalk.audio and pressed these buttons... >>> After I purchased the Event ASP8s a few years ago I sprang for >>> Mogami spkr cables. They've basically been plugged in a limited # >>> of times--hardly, if any wear. After some goofiness with one of the >>> speakers a while back--(issue has subsided) I just figured they >>> sounded slightly different and have opted to even up the volume/EQ >>> the with the trim pots. It's always bugged me because I know (even >>> with my tired ears) that the spkrs do not sound matched like they >>> should. After extensive troubleshooting I have deduced that one of >>> the spkr cables does not sound like the other --ie--slightly less >>> volume--not as full and a bit less bass. I plugged in a garden >>> variety Hosa and problem solved--matched full sound (volume/tone). >> >> I always thought cheep cable was the best! >> > > The clearance bin at my local GC is full of cables that are made by > Monster. In another life I worked at an electronics superstore. They sold Monster cable products there, so being the skeptic that I am, I wired up half their top of the line premo system with Monster cable so that the entire right side of the system had Monster Cable's best speaker wire, and best RCA to RCA cables all the way through. On the left side, I wired it up with the crappiest non name grey RCA to RCA cable, and the thinnest, cheapest speaker wire we had, which was something like 20 gauge. Anyway, I had numerous people try to tell which side had well over a hundred dollars worth of wire, and which side had a few dollars worth. Not one person could tell. Even the folks with good ears, and all the reps that frequently came by to sell us their wares. -- Remove YourHeadFromYourAss to Reply by email ________ __ / ____/ /__ ____ ____ / /_ ____ / / __/ / _ \/ __ \/ __ \/ __ \/ __ \ / /_/ / / __/ / / / / / / /_/ / /_/ / \____/_/\___/_/ /_/_/ /_/_.___/\____/ --------------------------------------------------------------------- Glennbo http://www.soundclick.com/glennbo Non-Linear Sound http://www.soundclick.com/jambits Hear My Music http://www.soundclick.com/ThePseudonyms
"Glennbo" <> wrote in message news:Xns9D668DDAAC9BrownShoesDontMakeIt@188.40.43.213... > In news:hr4mdh$792$-september.org the killer robot > kitekrazy <> grabbed the controls of the > spaceship cakewalk.audio and pressed these buttons... > >>>> After I purchased the Event ASP8s a few years ago I sprang for >>>> Mogami spkr cables. They've basically been plugged in a limited # >>>> of times--hardly, if any wear. After some goofiness with one of the >>>> speakers a while back--(issue has subsided) I just figured they >>>> sounded slightly different and have opted to even up the volume/EQ >>>> the with the trim pots. It's always bugged me because I know (even >>>> with my tired ears) that the spkrs do not sound matched like they >>>> should. After extensive troubleshooting I have deduced that one of >>>> the spkr cables does not sound like the other --ie--slightly less >>>> volume--not as full and a bit less bass. I plugged in a garden >>>> variety Hosa and problem solved--matched full sound (volume/tone). >>> >>> I always thought cheep cable was the best! >>> >> >> The clearance bin at my local GC is full of cables that are made by >> Monster. > > In another life I worked at an electronics superstore. They sold Monster > cable products there, so being the skeptic that I am, I wired up half their > top of the line premo system with Monster cable so that the entire right > side of the system had Monster Cable's best speaker wire, and best RCA to > RCA cables all the way through. On the left side, I wired it up with the > crappiest non name grey RCA to RCA cable, and the thinnest, cheapest > speaker wire we had, which was something like 20 gauge. > > Anyway, I had numerous people try to tell which side had well over a > hundred dollars worth of wire, and which side had a few dollars worth. Not > one person could tell. Even the folks with good ears, and all the reps > that frequently came by to sell us their wares. > In that environment with that type of gear I sispect it would be impossible to tell. In a studio environment it is very easy to notice that::: There are cheap cables that sound bad and cheap cables that sound better than the worst. I've test that one. There are probably expensive cables that sound bad and expensive cables that sound good. I haven't bothered to test that one. There is also reasonably priced cable that can be bought by the foot that is extreemely reliable, quiet ( well shielded ) and delivers a strong full range signal, and out performs both levels of reasonably priced Beldin that I used to buy by the roll. I've never met a cheap cable that sounds as good as Canare. The last noticable quality replacement I made was replacing a run of Beldin ( 2 cables ... the stereo main outs of my console ) with Canare star quad. This was after I began recording those outs to get a quick board/headphone mix of my works in progress, about 3 yrs. ago. The signal to noise ratio imporoved about 6dB and the tone got a lot richer and wider with the Canare star quad ... more highs and lows. None of that really matterd much before, because I've been rendering over toslink and mixing in the box, but now that I'm getting more channels open for rendering, beginning to use 16 analog channels also, along with the 24 toslink, it does matter. http://sightsea.com/renders/Bays_and_Cards.jpg As far as I can tell, the analog outs of the cards ( balanced outs to balanced patch bay to balanced inputs ) are rendering with about 90dB of head room before noise, which is making them pretty competative with the adat light pipes. Canare is the best cable I've ever found. I know for sure there is worse sounding cable. That has become very obvious. There might be better sounding cable but I don't know what it is. Steve Karl > -- > Remove YourHeadFromYourAss to Reply by email > ________ __ > / ____/ /__ ____ ____ / /_ ____ > / / __/ / _ \/ __ \/ __ \/ __ \/ __ \ > / /_/ / / __/ / / / / / / /_/ / /_/ / > \____/_/\___/_/ /_/_/ /_/_.___/\____/ > --------------------------------------------------------------------- > Glennbo http://www.soundclick.com/glennbo > Non-Linear Sound http://www.soundclick.com/jambits > Hear My Music http://www.soundclick.com/ThePseudonyms
