Sonar 6.0 producer to 8.5 upgrade
Discussion in 'cakewalk.audio' started by RichL, Nov 23, 2010.
  1. RichL Guest
    Message Count:
    I posed this question in a couple of other newsgroups but someone suggested
    I post here -- seems logical, I didn't realize this group existed!
    (sorry...)
    I just bought the upgrade for Sonar Producer 8.5, and I'm wondering if there
    are any backward-compatibility issues I should be concerned with before I
    install it over Sonar Producer 6.0.
    I've got tons of Sonar 6.0 projects on my recording PC, it would be nice to
    still be able to run them (and possibly add to them) once 8.5 is installed.
    Also, is the free upgrade to Sonar X worth doing? Anyone have any
    experience with any of this?
    Thanks in advance!
      • Advertising
  2. Russ B Guest
    Message Count:
    "RichL" <> harnessed the power of kittens for evil
    and cackled news::
    > suggested I post here -- seems logical, I didn't realize this group
    > existed! (sorry...)
    > there are any backward-compatibility issues I should be concerned with
    > before I install it over Sonar Producer 6.0.
    It will install in its own directory/folder. No need to "overwrite"
    SONAR 6.0. It would be wise to make copies of your project files before
    you open them in 8.5.
    > nice to still be able to run them (and possibly add to them) once 8.5
    > is installed.
    Then keep using it-you don't lose 6.0 just because you installed 8.5 as
    they will be in separate folders. Use a different directory for your
    project files for 8.5 to be safe.
    It's not out yet. Some time in December.
    Cheers!
    Russ B --> Harnessing the power of kittens...for SUYMF!
    remove STUPIDITY to reply, however, STUPIDITY was engaged when send
    button was pressed
  3. Steve_Karl Guest
    Message Count:
    "Russ B" <> wrote in message news:Xns9E389FFEEFAE4notverybrightguy@216.196.97.142...
    > and cackled news::
    What Russ said !
  4. Russ B Guest
    Message Count:
    "Steve_Karl" <> harnessed the power of kittens for evil
    and cackled news:icf6qu$9kd$-september.org:
    > What Russ said !
    What, someone actually listen to me? Ha! Never will happen...
    FWIW, I have several versions of SONAR installed on my PC (I have 8.5 but
    still use 8.3 for some reason) and the newer versions can open the older
    versions project files with little to no issues. Pro Audio 9 files may
    have some issues (envelopes and busses primarily) when opened with SONAR.
    Cheerio!
    remove STUPIDITY to reply, however, STUPIDITY was engaged when send button
    was pressed
      • Advertising
  5. RichL Guest
    Message Count:
    > and cackled news::
    >> existed! (sorry...)
    >> is installed.
    > Cheers!
    Thanks, that helps a lot! Presumably Session Drummer 3 won't overwrite
    Session Drummer 2 either (????).
    I've got all my projects on a separate drive from the software. I'll
    probably go ahead and make 2 separate folders on that drive (called, just to
    be creative, 6.0 and 8.5) and copy all project folders into each before I go
    messing around.
  6. Steve_Karl Guest
    Message Count:
    "Russ B" <> wrote in message news:Xns9E38A36BE7531notverybrightguy@216.196.97.142...
    >> What Russ said !
    > Cheerio!
    > was pressed
    Yea. I have PA9 here also and remember the transition to actuall busses and envelopes!
  7. Russ B Guest
    Message Count:
    and cackled news:icgb3l$h8o$-september.org:
    >>> What Russ said !
    My friend in NC still hasn't upgraded from CPA9. It works for him but for
    me, it can be frustrating to not be able to use effects, busses and
    envelopes as easily as SONAR does.
    A hui hou!
    was pressed
  8. Russ B Guest
    Message Count:
    and cackled news::
    > overwrite Session Drummer 2 either (????).
    > just to be creative, 6.0 and 8.5) and copy all project folders into
    > each before I go messing around.
    Some of the files in the shared folders may be updated to the latest
    versions but that shouldn't affect 6.0. Best thing is to backup everything
    before you install 8.5.
    was pressed
  9. RichL Guest
    Message Count:
    news:Xns9E39799BBD944notverybrightguy@216.196.97.142...
    > and cackled news::
    > everything
    OK, thanks! Wish me luck, I'm installing it tonight :)
  10. RichL Guest
    Message Count:
    > and cackled news::
    > everything
    Success! The 8.5 upgrade installed successfully, and I was able to open and
    play my most recent Sonar 6 project in both Sonar 6 and Sonar 8.5 (the
    latter after making a copy of the project). All is greatness, thanks!
  11. Dominique Guest
    Message Count:
    "RichL" <> écrivait news:34SdnT2bJcX-
    suggested
    > (sorry...)
    there
    to
    installed.
    > Thanks in advance!
    Your free upgrade to X1 is a no brainer since it's free and I'm sure it
    will install in it's own folder since it's a very different application, so
    just go ahead and do it, you have nothing to loose.
  12. RichL Guest
    Message Count:
    "Dominique" <> wrote in message
    news:XnF9E3A8901EE40Ddoumdomainnet@69.16.185.252...
    > suggested
    >> (sorry...)
    > there
    > to
    > installed.
    >> Thanks in advance!
    > so
    Thanks, yeah, I'll check it out when it becomes available.
      • Advertising
Share This Page
