Sonar 7, truly improved?
Discussion in 'cakewalk.audio' started by Stig, Mar 2, 2008.
  1. Stig Guest
    Message Count:
    OK, I would appreciate any feedback from those in the know...
    I am considering doing the update, BUT, I cannot seem to find any
    verification that Sonar 7 is any better at handling soft-synth related
    crashes. This has been a real issue for me in the past few months, and I an
    getting fairly sick of seeing the little glitches that keep popping up,
    hanging, freezing, (you know)..I have a great DAW, custom made Sonica, so I
    assume that the soft-synths are the culprit. Any ideas? Thanks, C
      • Advertising
  2. Sue Morton Guest
    Message Count:
    All softsynths have trouble? Or just certain ones? What version of Sonar?
    There was a problem with the TTS-1, I think it was Sonar 5, they've fixed
    that. That's the only one I know about, though. More details please? What
    were you doing when the hang/freeze happens? etc.
    Sue Morton
    > and I an getting fairly sick of seeing the little glitches that keep
    > popping up, hanging, freezing, (you know)..I have a great DAW, custom
    > made Sonica, so I assume that the soft-synths are the culprit. Any
    > ideas? Thanks, C
  3. Stig Guest
    Message Count:
    I am using Sonar 6. I think I am describing general freezing problems, that
    only appeared when I added a few synths. Native Instrument Elektrik Piano,
    Organized Trio. Just plain "strange" things happen. I even heard you
    yourself allude to some "bugginess". It just seems so less stable than a few
    months ago. Do you think this sort of thing is related to the synths, or
    just the program itself? I was hoping that perhaps an upgrade might help the
    situation. Thanks again, c
    "Sue Morton" <> wrote in message
    news:GhDyj.17420$...
    > Sonar? There was a problem with the TTS-1, I think it was Sonar 5, they've
    > fixed that. That's the only one I know about, though. More details
    > please? What were you doing when the hang/freeze happens? etc.
    > Sue Morton
    >> ideas? Thanks, C
  4. Sue Morton Guest
    Message Count:
    I've not heard of general "bugginess", and nothing specific to soft synths.
    Rick has been experiencing problems but he's narrowed these down as likely
    the Kontakt2 Player. I only experienced the TTS-1 problem I mentioned,
    which has been fixed. All the bugs I've experienced I've been able to find
    the item or area of concern and also recreate the 'bug'. I have reported
    all of them to Cake, they confirm the bug exists and then nothing more
    happens. Release after release and not fixed. I'm not sure what you recall
    me "alluding to"? My beef with Cake is that these things happen at all, and
    aren't fixed promptly when identified. Finding and recreating the problem
    and reporting it, is not my issue.
    I asked for specific details from you because usually the solution lies in
    finding out what is actually wrong, which is not very often of a general
    nature. Your general "bugginess" with synths, as you've explained it, can
    be attributed to a specific problem that has not yet been isolated (most
    likely), or a corruption of broader impact that is specific to your system
    (also probable).
    Sue Morton
    > problems, that only appeared when I added a few synths. Native
    > Instrument Elektrik Piano, Organized Trio. Just plain "strange"
    > things happen. I even heard you yourself allude to some "bugginess".
    > It just seems so less stable than a few months ago. Do you think this
    > sort of thing is related to the synths, or just the program itself? I
    > was hoping that perhaps an upgrade might help the situation. Thanks
    > again, c
    >> they've fixed that. That's the only one I know about, though. More
    >> details please? What were you doing when the hang/freeze happens?
    >> etc. --
    >> Sue Morton
    >>> related crashes. This has been a real issue for me in the past few
    >>> months, and I an getting fairly sick of seeing the little glitches
    >>> that keep popping up, hanging, freezing, (you know)..I have a great
    >>> DAW, custom made Sonica, so I assume that the soft-synths are the
      • Advertising
  5. Stig Guest
    Message Count:
    Thanks for the reply, Sue.
    I suppose it's those little things that just make recording harder.
    Examples: when I use the V-vocal, on certain tracks it will simply not
    display any editable notes, rendering it useless. When I normalize a track
    now, very often it will hang up for like 60 seconds before it clicks back
    (this is on a small clip). Sometimes just doing a quick save will hang for
    another 30 seconds, it's fairly unpredictable. Since I got the update on the
    New NI Elektrik Piano (1.5) it is sooooo much more stable.
    So, in effect, it just seems to be less stable than in was a few months ago.
    Just wondering if anyone else has seen this kind of thing. Thanks again, c
    news:%pEyj.59723$...
    > synths. Rick has been experiencing problems but he's narrowed these down
    > as likely the Kontakt2 Player. I only experienced the TTS-1 problem I
    > mentioned, which has been fixed. All the bugs I've experienced I've been
    > able to find the item or area of concern and also recreate the 'bug'. I
    > have reported all of them to Cake, they confirm the bug exists and then
    > nothing more happens. Release after release and not fixed. I'm not sure
    > what you recall me "alluding to"? My beef with Cake is that these things
    > happen at all, and aren't fixed promptly when identified. Finding and
    > recreating the problem and reporting it, is not my issue.
    > (also probable).
    > Sue Morton
    >> again, c
    >>> etc. --
    >>> Sue Morton
  6. Ted Perlman Guest
    Message Count:
    <soft-synth related crashes. This has been a real issue for me>
    All I use is softsynths (with a few hardware modules) 24/7 everyday without
    issue in Nuendo. Plus all my hardware reverbs added as external fx. No
    problems. I keep hearing about issues all the time with Sonar & softsynths,
    audio cardss, DSP cards, etc. Why stick with the program when it causes so
    many headaches?
    Regards,
    Ted Perlman
    Producer-Arranger-Musician-Composer
    www.tedperlman.com
    www.myspace.com/tedperlman
  7. Rick Paul Guest
    Message Count:
    A few thoughts on the specifics you mentioned here (a few more replies in
    context elsewhere in the thread):
    "Stig" <> wrote in message
    news:47cb1f5c$0$16672$...
    This can be due to the nature of the signal. For example, a signal that has
    a very high balance of overtones to fundamental, or, especially, noise to
    pitched tones (e.g. a very whispery vocal), can cause this. It can be the
    same sort of thing in AutoTune, though some things may be tracked better or
    worse in one or the other. There really isn't much you can do in that case,
    other than possibly using a manual pitch shifter if your ears can hear what
    needs to be done. Tuners like V-Vocal and AutoTune do rely on being able to
    detect the pitch of the content, and sometimes get fooled by certain signals
    that don't have a strong enough fundamental.
    Note that if you are talking about strongly pitched stuff that is just
    sometimes randomly not having any pitch detected, but other times having
    pitch detected on the exact same clips, that is another thing. I've never
    experienced that. Make sure the clip isn't muted or something -- that's
    about the only thing I can think of at this point.
    > When I normalize a track now, very often it will hang up for like 60
    > seconds before it clicks back (this is on a small clip).
    Do you have a lot of clips in the project and have you done a lot of editing
    in the project session prior to this point? One thing I have seen is that
    SONAR can sometimes take progressively long to get back to you on even
    simple things when there are loads of clips and you've been in an intense
    editing session for a long time. I think the reason may be because the Undo
    list gets unwieldy. When that happens, the easiest "solution" is to save
    your results, close the project, then reopen it. That clears the Undo list.
    As far as I know SONAR doesn't have any facility to limit the size of the
    Undo list to prevent this sort of thing. It might be nice if it did,
    though, then conceivably there might be times when we'd wish we hadn't just
    gone off the end of it. ;-) This seems the most likely reason for a very
    long delay with the kind of case you are talking about.
    Another that might add to it would be if you are normalizing a slip edited
    clip but SONAR has to normalize the whole clip (including portions that
    aren't visible due to the slip editing) behind the scenes (i.e. in case you
    stretch the thing out again later -- I'm not actually sure if it would do
    that or not in terms of what portion of the signal gets normalized, but I do
    believe it has to do some calculations based on the whole clip in such a
    case). One thing you can do to help on this front is to Apply Trimming to
    clips you will be doing non-realtime processing on.
    If you are using AudioSnap on a clip, doing the calculations for that can
    also slow things down considerably for rendering operations, especially with
    some of the more expensive stretching algorithms.
    Another thing that can come into play with slow response time is all the
    latency in the system if, for example, you have a lot of plug-ins with high
    latency. I can't imagine that would ever create a 60 second delay, but some
    plug-ins with very high latency (PSP Neon HR comes to mind) can create some
    fairly long delays, and noticeable moves backward or forward in time if, for
    example, you bypass them or enable them during playback. From memory, I
    think it was at least a few seconds. This isn't likely what you're seeing,
    but the main reason I mention it is it can slow down response time in
    general, and could also add to the overall response time delays you get in
    other scenarios that might have slow response time.
    > Sometimes just doing a quick save will hang for another 30 seconds, it's
    That is likely to mainly depend on the project, but also any other delays
    that might be inherent in the system to add to the actual saving time at any
    given moment.
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
  8. Rick Paul Guest
    Message Count:
    > mentioned,
    That is one specific problem, so far only in experienced in one specific
    project. However, I have seen some other scenarios that may fall more into
    the category of "general bugginess" with softsynths, or specific softsynths,
    at least if you don't know enough about them to narrow them down further.
    Here are a few examples that come to mind:
    Crashes when tracking with Kontakt (at least V2, not sure about V3 or V1.x)
    and some very possibly some other NI plug-ins (e.g. Guitar Rig 2 comes to
    mind, not sure about GR3). If you are on a multicore system (in my case
    Core 2 Duo), with SONAR's MP mode enabled, this seems to be a general fact
    of life. Though it is not specifically recreatable on demand, it
    empirically seems to happen fairly frequently. For example, in the most
    recent project where I hadn't had MP mode turned off, I could usually get
    through tracking one part, then it would crash on the next one. Then I'd
    restart SONAR and try that one again, and that one would be okay, then it
    would crash on the next part. This was in a total MIDI/softsynth project
    with two instances of Kontakt 2 Player running Garritan Concert & Marching
    Band parts -- 30 MIDI channels total across the two instances, though not
    all had MIDI data on them at that point. After turning MP mode off, though,
    I had no further crashes with that project. I believe I also experienced
    this issue with SONAR 6.2(.1?) -- not sure about earlier versions of
    SONAR -- and I know I've experienced it with SONAR 7.x, at least through
    SONAR 7.0.2.
    Flaky behavior, generally leading to severe audio glitches (such as repeated
    samples playing over and over for a long period) and often a hang or crash,
    when tracking MIDI some MIDI softsynths and playing multiple continuous
    controllers in parallel (e.g. a Roland style pitch/mod lever, which sends
    both pitch wheel data and mod wheel data from the same controller). I have
    experienced this with a number of softsynths including at least Kontakt 2,
    Absynth (2, I think), Cameleon 5000, and others I can't recall at the
    moment. I could not, however, get it to happen with TTS-1. This was
    reported to Cakewalk at least as far back as SONAR 6 (I think 6.0), if not
    even in some version of SONAR 5.x. Having a multicore system seems to
    reduce, but not totally eliminate, the likelihood of having problems in this
    area. My feeling on this is that, after SONAR's audio engine was retooled
    for "gap-less" behavior (initially with SONAR 4.0.3), the audio engine got
    much higher priority than other threads, and there may be some scenarios
    where starvation of those other threads occurs, especially in a low
    performing system (e.g. my previous system, which was an Athlon XP 1600+),
    but possibly also in better performing single-processor systems as you don't
    even have to have a lot going on with the system to experience this (e.g.
    one time on my old Athlon system I had it going on with just one audio loop
    playing back and tracking one softsynth part with Cameleon or Absynth --
    nothing else in the project). I suspect having a multiprocessor helps in
    this case because the additional processor may be able to service the
    thread(s) that would have been starved in the single processor situation,
    though I also think that may just delay the issue to times when things get
    more intense, as I have still experienced the problem on my Core 2 Duo
    system, albeit fairly rarely. It is also conceivable that audio drivers
    (e.g. their performance and/or stability) might come into play here -- i.e.
    in my theory (I really have no confirmation from Cakewalk to suggest that my
    theory is or isn't valid).
    SONAR hanging in the task list after a crash, requiring a reboot to clear
    it. This might be audio device-specific (I'm using an E-MU 1820M), but this
    definitely happens some percentage of the time after SONAR crashes, and has
    since at least SONAR 5 and still in SONAR 7. It is a particular frustration
    on my system because my system takes so long to reboot due to loads of
    drivers and such. I have to say I haven't noticed it happening since
    upgrading to the latest (V2.0) drivers for my E-MU hardware, but that may
    just be coincidence in that I haven't had too many crashes since that, only
    the specific ones related to the Kontakt2Player crash, which are trapped by
    SONAR's crash recovery system (most likely meaning it can shut the drivers
    down cleanly).
    With SONAR 6, I also often got blue screens at some point after SONAR
    crashes if I didn't reboot my system. Sometimes it might be very soon after
    the SONAR crash (e.g. when viewing a Watson log right after it), and other
    times it might be as much as a few hours later. I have not yet seen this
    with SONAR 7. BSOD's obviously have to be driver issues at some level, but
    I never had this with SONAR 5 or earlier, and the only other issues I ever
    saw that caused BSOD's for a number of years prior to the issue "provoked"
    (catalyzed?) by SONAR 6 were well known ones with some Adobe software
    running some optimization libraries that didn't work on the AMD processor I
    had at the time.
    As for the general question as to whether SONAR 7 is improved, I think it
    generally is, and I know some of my pet peeves from SONAR 6 (e.g. Mute Tool
    cursor not showing up when in the mute entire clip mode that I always use
    with the Mute Tool) are corrected. As I mentioned above, I also haven't
    seen the BSOD after a SONAR crash issue I used to see fairly regularly with
    SONAR 6.x, but I haven't heard of others experiencing that one. Of course,
    there are also all the various enhancements in SONAR 7 that come into play
    in the decision as to whether to upgrade or not. For example, I find the
    Dim Solo mode is a particularly big help on the productivity front. (For
    lots more details on my thoughts on the SONAR 7 upgrade, see
    www.cakewalknet.com/index.php?option=com_content&task=view&id=631&Itemid=2.
    Note that it was written before the SONAR 7.0.2 patch.)
    Rick
    Rick Paul
  9. Rick Paul Guest
    Message Count:
    "Ted Perlman" <> wrote in message
    news:47cb22a5$0$22824$...
    > without issue in Nuendo. Plus all my hardware reverbs added as external
    > fx. No problems. I keep hearing about issues all the time with Sonar &
    > softsynths, audio cardss, DSP cards, etc. Why stick with the program when
    > it causes so many headaches?
    Well, if you hang out in a SONAR forum, you'll hear about SONAR crashes,
    though also about people doing similar things who aren't experiencing any
    crashes. That's the nature of the beast. Just for fun, I went over to the
    Nuendo 4 forum on nuendo.com, just to check out the general topics being
    discussed over there, and it was filled with messages with "crash" and other
    assorted stability/reliability issues in titles, such as:
    Sticky: Nr Unexpected crashes
    Sticky: N4 Unexpected CPU Spiking
    Snap Point/Crashing issues after using Bounce Selection
    constant crashing...
    And that was just in the first 10 messages on the page!
    Of course, I'd guess that there are probably more Nuendo users experiencing
    just peachy behavior than experiencing problems, but users experiencing
    great behavior generally don't post, other than maybe in answer to other
    people's posts.
    It may well be that you're not using the kinds of plug-ins that are causing
    the problems -- most of mine, for example, have been with Kontakt 2, Guitar
    Rig 2, and a few other NI plug-ins. Or it may be that something is
    different about your scenario than mine beyond just the plug-ins (and DAW
    choice) as, for example, in answer to my thread on Kontakt2Player crashes,
    Ben Moore replied that he isn't having crashes. In fact, a crash that is
    100% repeatable for me in one specific project ends up not being repeatable
    in another project with the same softsynth, so there is obviously something
    more complex going on there in the problem scenario.
    Of course, choice of audio cards, and the stability of their drivers, can
    also come into play. You'd have to have the exact same plug-ins and audio
    cards, and specific uses of the applications on your system and someone
    else's to truly compare stability, and very few people have the exact same
    sets of ingredients, no less the same workflow.
    BTW, SONAR 7 also supports external hardware pretty much just as if it were
    a plug-in (except you'll have to manually restore your hardware settings or,
    if it can be automated with MIDI, automate it that way), including dealing
    with latency compensation.
    Rick
    Rick Paul
  10. Ted Perlman Guest
    Message Count:
    <And that was just in the first 10 messages on the page>
    Nuendo 4 is not ready for 24/7 work. You won't find anyting like that from
    Nuendo 3 users.
    Regards,
    Ted Perlman
    www.tedperlman.com
  11. polymod Guest
    Message Count:
    news:47cae5de$0$6474$...
    an
    I
    I would download the Sonar 7 demo and try it out.
    It don't cost anything.
    You won't be able to use V-Vocal, because the demo is pretty stripped down,
    but I would imagine you'd be able to load all your softies....I would hope!
    Poly
      • Advertising
Share This Page
