SONAR and Garritan Personal Orchestra, and Arturia Moog
Discussion in 'cakewalk.audio' started by Benjamin Goldman, Aug 18, 2010.
  1. Benjamin Goldman Guest
    Message Count:
    Is there a limit to how many *GPO* instruments I can have on separate
    tracks and channels in *SONAR 7 Studio*?
    I have a lot of trouble with GPO - or any VST or DXi plug-ins . . .
    running multiple instances . . . ESPECIALLY with the Arturia Moog
    Modular V2.
    If anybody knows about *GPO* and *Overture* *3* I'm very interested. I
    haven't managed more than 8 at the same time.
    Cheers,
    Ben
      • Advertising
  2. Rick Paul Guest
    Message Count:
    You don't mention many details, such as what kind of troubles you're running
    into, which version of GPO, etc.
    The only thing I can things I can think of offhand are:
    With some versions of the KONTAKT Player I do recall running into troubles
    with multiple instances. It's been awhile now, so my memory on that is
    pretty vague, but I think it was with KONTAKT Player V2, and I believe it
    could be any of the Garritan or Sample Modeling instruments, though I
    wouldn't swear to it. If I remember correctly, my workaround was generally
    to freeze whichever one I wasn't actively using. However, I also think that
    newer versions of KONTAKT and/or the KONTAKT Player made the issues go away.
    I currently have KONTAKT V3 and KONTAKT Player V4, so those are the most
    likely versions I'd be using on anything current.
    I also have had some stability issues with Arturia V Collection instruments,
    where SONAR might crash or hang on certain plug-in operations, such as
    inserting it or bringing it back after freezing. Again, this is a pretty
    vague memory, and I don't recall having any issues more recently, but I also
    don't use the Arturia plug-ins super regularly as much of the music I make
    doesn't call for synth sounds at all. I don't recall if I've had any
    troubles with these since updating to the V2 versions (I just noticed the
    Jupiter 8V2 is out now, too -- not sure if I missed it earlier or it hasn't
    yet gotten a public announcement, but your message reminded me to check if
    it was there since I'd just noticed in the last few days that it was the
    only one that I didn't have a V2 version of -- the version info on their
    download page doesn't even say what is new in V2).
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
    "Benjamin Goldman" <> wrote in message
    news:i4fmhp$gkg$-september.org...
    > Modular V2.
    > Cheers,
    > Ben
  3. Benjamin Goldman Guest
    Message Count:
    > running into, which version of GPO, etc.
    > troubles with multiple instances. It's been awhile now, so my memory
    > on that is pretty vague, but I think it was with KONTAKT Player V2,
    > and I believe it could be any of the Garritan or Sample Modeling
    > instruments, though I wouldn't swear to it. If I remember correctly,
    > my workaround was generally to freeze whichever one I wasn't actively
    > using. However, I also think that newer versions of KONTAKT and/or
    > the KONTAKT Player made the issues go away. I currently have KONTAKT
    > V3 and KONTAKT Player V4, so those are the most likely versions I'd
    > instruments, where SONAR might crash or hang on certain plug-in
    > operations, such as inserting it or bringing it back after freezing.
    > Again, this is a pretty vague memory, and I don't recall having any
    > issues more recently, but I also don't use the Arturia plug-ins super
    > regularly as much of the music I make doesn't call for synth sounds
    > at all. I don't recall if I've had any troubles with these since
    > updating to the V2 versions (I just noticed the Jupiter 8V2 is out
    > now, too -- not sure if I missed it earlier or it hasn't yet gotten a
    > public announcement, but your message reminded me to check if it was
    > their download page doesn't even say what is new in V2).
    > Rick
    Thanks Rick. Inserting and using soft synths has always been a pain in
    the neck for me. About all I can /easily/ do is play a softsynth from
    a keyboard.
    I may give Gary Garritan a call.
    As for Arturia, I by far prefer the V2 to the original Moog Modular.
    I've had that freeze things up. EVen the V2 has had trouble as an
    inserted synth. A log off and back on would free up resources and put
    things back to normal.
    I'm starting to think about using an extra computer for running the
    Moog as an outboard and connecting with MIDI cables. I could record it
    to an Audio Track.
    Thanks for the input, Rick. Much appreciated.
    Cheers,
    Ben
  4. Rick Paul Guest
    Message Count:
    Just wondering here if it's possible you're running low on usable memory?
    That could create issues with softsynths if so. It might well be that a
    reason I haven't seen problems recently is because of my move to SONAR x64
    and the additional amount of my 4 GB configuration it lets SONAR use (32-bit
    Windows only allows SONAR to use 2 GB total application space, independent
    of how much the rest of the system has available).
    Rick
    Rick Paul
    news:i4p6nh$o19$-september.org...
    >> Rick
    > a keyboard.
    > to an Audio Track.
    > Cheers,
    > Ben
      • Advertising
  5. Benjamin Goldman Guest
    Message Count:
    > memory? That could create issues with softsynths if so. It might
    > well be that a reason I haven't seen problems recently is because of
    > my move to SONAR x64 and the additional amount of my 4 GB
    > configuration it lets SONAR use (32-bit Windows only allows SONAR to
    > use 2 GB total application space, independent of how much the rest of
    > Rick
    No memory or computing power problems. It's only that I am trying to
    understand how to use stuff.
    I haven't even got around to using effects returns yet and am quite
    behind when it comes to doing anything else but simply recording. MIDI
    work and audio file processing are easy for me.
    I get confused about track folders and how many times a synth needs to
    be inserted etc. If I do one and freeze, do one and freeze, then I can
    deal.
    Cheers,
    Ben
  6. Rick Paul Guest
    Message Count:
    With multitimbral instruments like GPO, you can use multiple MIDI tracks per
    instance and either submix them to a stereo pair or send different
    instruments to different outputs. The key is how you insert them in the
    synth rack to create the audio outputs (or if you manually create and route
    additional audio outputs. Of course, you could also do one instance per
    instrument if you like, but that probably isn't as efficient in terms of
    resource usage.
    Rick
    Rick Paul
    news:i4qdcb$peg$-september.org...
    >> Rick
    > deal.
    > Cheers,
    > Ben
      • Advertising
Share This Page
