Sonar XL with the Kurweil K2vx
Discussion in 'cakewalk.audio' started by scott, Sep 17, 2003.
  1. scott Guest
    Message Count:
    Does Sonar support the Kurzweil K2vx? I tried cakewalk 7.0 in the past but
    it would not recognize the keyboard. I was wondering if the support had been
    added. I'd like to buy Sonar, but not if I can't use my keyboard with it.
    THANKS!
      • Advertising
  2. EnJneer Guest
    Message Count:
    Hi Scott,
    Your question is unclear. No DAW (Except Logic on Sound Diver-enabled
    synths) can "recognise" a piece of outboard gear. All it can do is interface
    with it via MIDI.
    If you mean, "Will it connect via MIDI?" then yes it should. If your
    CWPA 7 could not "see" your Kurzweil as a MIDI device, then you most likely
    had some hardware/connectivity issues.
    If you mean, "Will SONAR recognise all the banks and patches and sysex
    data and list them by name in the Track View... it won't. No DAW will,
    either. You can look at cakewalk.com downloads and see if they have an
    Instrument Definition for it (which you load into Cakewalk) or check out the
    bad-ass resources for Cakewalk/SONAR users here:
    http://www.dspacer.com/KurzCake.htm If you can put up with the NASTY MIDI
    music at the site, that is...
    Hope that helps,
    J
    "scott" <> wrote in message
    news:W3T9b.39080$n94.1102@fed1read04...
    been
    > THANKS!
  3. scott Guest
    Message Count:
    Yes, I meant MIDI up with it. In fact, I've found info on the web stating
    that CWPA 7 won't even MIDI up with it. My Juno 106 would work fine. I could
    sequence it and record tracks on CWPA with it. But when I connect the
    Kurzeil, nothing.
    Thanks for the insight!
    Scott
    "EnJneer" <> wrote in message
    news:Ue7ab.486594$...
    > Hi Scott,
    interface
    > with it via MIDI.
    likely
    the
    > Hope that helps,
    > J
    but
    > been
    it.
    > > THANKS!
  4. EnJneer Guest
    Message Count:
    Dude, that is fried. The problem MUST be with the Kurzweil somehow... why
    wouldn't it NOT interface? It's either MIDI-compliant or it's not... you
    would thing, anyway...
    Can you point me to that info on the web? I'm v. curious about this now.
    Good luck.
    J
    Engineer/Producer
    (Delete "no.spam" from my e-mail address to reply driect)
    news:tv8ab.40462$n94.36033@fed1read04...
    could
    > Kurzeil, nothing.
    > Scott
    > > Hi Scott,
    Diver-enabled
    > interface
    > > with it via MIDI.
    > likely
    sysex
    > the
    MIDI
    > > Hope that helps,
    > > J
    > but
    had
    > > been
    > it.
    > > > THANKS!
      • Advertising
  5. scott Guest
    Message Count:
    Maybe I read something wrong. But I thought I'd read it. IT definitely
    sounds like a pain to get to work though. I guess the drums have to be
    remapped and a bank of sounds has to be created for Cakewalk to use.
    I found this and it sounds pretty helpful.
    a.. John W. Mason has updated his SYX2INS.EXE which will find all your K2000
    (and now, maybe K2500) program banks and convert them to multiple Cakewalk
    instrument format files. Read the details and you can download the program
    from Sweetwater's regular (not K2000) Incoming FTP site. Look for
    Syx2ins2.zip (53 KB) and see my Downloading & Un-compressing page for help,
    if needed. Read Kenni Fink's explanation of How to convert Kurzweil banks to
    Cakewalk .ins files.
    a.. To enable Cakewalk to "poll" your Kurzweil K2000, use a text editing
    program (like Notepad) to add the following string to your "cakewalk.ini"
    file--located where Cakewalk has been installed.
    ;; Kurzweil K2000 Courtesy of John Mason - BitStream (Compressed) Format
    Kurzweil K2000 RAM Programs: 000s Bank=F0 07 00 78 0B 00 00 00 01 00 F7
    Kurzweil K2000 RAM Programs: 100s Bank=F0 07 00 78 0B 00 00 01 01 00 F7
    Kurzweil K2000 RAM Programs: 200s Bank=F0 07 00 78 0B 00 00 02 01 00 F7
    Kurzweil K2000 RAM Programs: 300s Bank=F0 07 00 78 0B 00 00 03 01 00 F7
    Kurzweil K2000 RAM Programs: 400s Bank=F0 07 00 78 0B 00 00 04 01 00 F7
    Kurzweil K2000 RAM Programs: 500s Bank=F0 07 00 78 0B 00 00 05 01 00 F7
    Kurzweil K2000 RAM Programs: 600s Bank=F0 07 00 78 0B 00 00 06 01 00 F7
    Kurzweil K2000 RAM Programs: 700s Bank=F0 07 00 78 0B 00 00 07 01 00 F7
    Kurzweil K2000 RAM Programs: 800s Bank=F0 07 00 78 0B 00 00 08 01 00 F7
    Kurzweil K2000 RAM Programs: 900s Bank=F0 07 00 78 0B 00 00 09 01 00 F7
    news:D5kab.59631$...
    > Good luck.
    > J
    > Engineer/Producer
    stating
    > could
    > > Kurzeil, nothing.
    > > Scott
    > > > Hi Scott,
    > Diver-enabled
    > > interface
    > > > with it via MIDI.
    your
    > > likely
    > sysex
    out
    > > the
    > MIDI
    > > > Hope that helps,
    > > > J
    past
    > > but
    > had
    > > > been
    with
    > > it.
    > > > > THANKS!
  6. EnJneer Guest
    Message Count:
    Right... Looks good. Too bad it's so much work, eh?
    J
    Engineer/Producer
    news:1vuab.42929$n94.17343@fed1read04...
    K2000
    help,
    to
    why
    > > Good luck.
    > > J
    > > Engineer/Producer
    > stating
    > > could
    > > > Kurzeil, nothing.
    > > > Scott
    > > > > Hi Scott,
    > > Diver-enabled
    > > > interface
    > > > > with it via MIDI.
    > your
    > > > likely
    > > sysex
    will,
    an
    > out
    > > > the
    > > MIDI
    > > > > Hope that helps,
    > > > > J
    > past
    > > > but
    support
    > > had
    > > > > been
    > with
    > > > it.
    > > > > > THANKS!
      • Advertising
Share This Page
