SP76 sounds distorted ...
Discussion in 'alt.music.synth.kurzweil' started by Gil, Aug 9, 2004.
  1. Gil Guest
    Message Count:
    I just got a second hand Kurzweil SP76. The problem is that if you
    play open chords with sustain pedal pushed on, the sounds immediately
    gets distorted.
    If you leave the keyboard switched on for a while, than it will play a
    distorted sound even with no sustain on. Any idea what the problem can
    be, and if it's worth fixing ?
    Thanks
      • Advertising
  2. Michael Houston Guest
    Message Count:
    You do have the sustain pedal plugged into the "Switch" jack and not
    the "Control" jack, right? It's easy to confuse 'em...
    >gets distorted.
    >Thanks
    Michael Houston
    musicianmike at cox dott net (you know what to do)
  3. Gil Guest
    Message Count:
    I used a higher current power supply (12v 3.5A) and the problem does
    not show so far, it even sounds better now. Does it still have a
    problem or has the original PS gone bad ? The original provides
    exactly what the keyboard needs (0.5A)
    (Gil) wrote in message news:<>...
    > gets distorted.
    > Thanks
  4. Gil Guest
    Message Count:
    I connect it to the "switch"... should I connect to the "control" ??
    (Michael Houston) wrote in message news:<>...
    > >gets distorted.
    > >Thanks
    > Michael Houston
  5. Michael Houston Guest
    Message Count:
    >gets distorted.
    >Thanks
    Michael Houston
      • Advertising
Share This Page
