Strange Sounds
Discussion in 'alt.music.synth.kurzweil' started by C. L., Feb 7, 2004.
  1. C. L. Guest
    Message Count:
    I've got a Kurzweil K2000 and I haven't had it set up since I moved 6 months
    ago. I set it up just now, started it up, and ALL the piano sounds are
    really messed up. It seems as if there's 2 or 3 different sounds in
    different octaves and it starts off on one for second then switches to sound
    two then switches to sound 3.
    The non-piano sounds are fine. When I first turned it on I had my sustain
    pedal in the "foot controller" jack by accident. Don't know if that has an
    effect. I tried both the +/-, o, clear soft reset as well as going into the
    Master menu and doing a hard reset of the memory.
    Nothing helped. If this has happened to you I'm sure you know what I'm
    talking about even with the horrible description!
    Any ideas?
      • Advertising
  2. Michael Guest
    Message Count:
    Hi,
    do the batteries out and put them in again after 5 minutes. That helps often.
    Test the batteries by pressing the "4-5-6" buttons at the same time. New ones
    offer 4.7 Volts, and everything from 3.8 Volts on is normal. Better is to change
    the batteries all 12-18 months.
    Wonder if that helped
    Michael
    > Any ideas?
  3. C. L. Guest
    Message Count:
    "Michael" <> wrote in message
    news:...
    often.
    ones
    change
    My answer to your post is. . . ."this things got batteries?"
    Sorry for being so stupid about my not so cheap piece of equipment. I DID
    get out both manuals though and read all the troubleshooting topics and
    nothing mentioned batteries.
    I did the test and it came up 3.7V. I'll go get some AA batteries today and
    see if it does the trick. . . I'm imagining it will.
    Thanks!
  4. Michael Guest
    Message Count:
    Oh, never mind, sometimes I forget to switch it on.
    > I DID
    Let me know if it works.
    Best to you, Michael, Berlin, Germany
  5. C. L. Guest
    Message Count:
    Yea it did. Right after I put the new batts in it actually was still messed
    up. Then I did the 4, 5, 6 thing and it seemed to reset it and it's ok now.
    Thanks!
    "Michael" <"Michael "@best.de> wrote in message
    news:...
    > > I DID
    and
      • Advertising
Share This Page
