Sup Drum 2.0 velo question?
Discussion in 'cakewalk.audio' started by jeffl, May 6, 2010.
  1. jeffl Guest
    Message Count:
    I built a mix drumkit with Hit Factory and couple X pads for xtra kik,
    cymbal. There seems to be no key/note assigned to the ride I like--easy
    fix--learned note--success. Except when I play the cymbal with mouse I get
    the bell cutting thru I like but when I play the keys it sounds wimpy--not
    as loud and not bell/chimy.
    What am I missing?
    Thanx
    Jeff
      • Advertising
  2. jeffl Guest
    Message Count:
    In the meantime I'm gonna plug in my old trusty dr008 (dfh original
    samples)--some of these sounds (the ride and hats are REALLY good) are just
    better but think I should be able to get the sound I want outta this Sup
    2.0....right..?
    "jeffl" <> wrote in message
    news:hrtgu8$dul$-september.org...
    > What am I missing?
    > Thanx
    > Jeff
  3. Glennbo Guest
    Message Count:
    The killer robot "jeffl" <> grabbed the controls of the
    spaceship cakewalk.audio and pressed these buttons...
    > like--easy fix--learned note--success. Except when I play the cymbal
    > with mouse I get the bell cutting thru I like but when I play the keys
    > it sounds wimpy--not as loud and not bell/chimy.
    > What am I missing?
    There's a check box for "edit articulation only" or something to that
    effect. If you select that, then select the bell articulation, and then
    click learn and hit a midi key, it will link that sample up to your key.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  4. jeffl Guest
    Message Count:
    cool-thanx!!!
    "Glennbo" <> wrote in message
    news:Xns9D7057DFAD3A5BrownShoesDontMakeIt@188.40.43.213...
    >> What am I missing?
    > ________ __
      • Advertising
Share This Page
