SX3 Exporting all audio tracks out of a project
Discussion in 'alt.steinberg.cubase' started by SSR, Apr 30, 2009.
  1. SSR Guest
    Message Count:
    I recorded a cassette tape into Cubase as a single file then split it into
    separate tracks.
    Is there a way to export each track to a separate file all in one process?
      • Advertising
  2. Bas Guest
    Message Count:
    >separate tracks.
    I don't think so.
    1 track at a time, I'm afraid.
  3. SSR Guest
    Message Count:
    Hrumph :(
    thanks anyways :)
    "Bas" <> wrote in message
    news:eek:...
    >>into
    >>separate tracks.
    > I don't think so.
  4. Hueyduck Guest
    Message Count:
    > separate tracks.
    If there is no real time FX applied on the sounds, you could create one
    region for each portion of audio, select them all together, right click
    and then "create audio from regions" or something like that.
    Not very clean a way to proceed, though.
    I think Cubase 5 has the function you're looking for (I have yet to read
    the whole manual, so I'm not 100% sure about this).
    Huey
  5. Bas Guest
    Message Count:
    On Fri, 01 May 2009 10:17:12 +0200, Hueyduck <>
    wrote:
    >> separate tracks.
    Yes it does.
    When exporting audio, you can select the channels you want exported
    in the left part (channel selection) of the window.
      • Advertising
Share This Page
