SYS EX Checksum error
Discussion in 'alt.steinberg.cubase' started by Kenneth Kisbye, Feb 7, 2004.
  1. Kenneth Kisbye Guest
    Message Count:
    Hi all
    I've got a lot of music recorded on Amiga with DR.T KCS. all songs include
    SYS EX data from Roland Sound Canvas and Roland JD990. When I send them back
    to instruments from Amiga - every thing works perfect, but when I send them
    to my pc and record them with Cubase SE and then send them to the
    instruments I got a lot of Checksum Error. Midi notes get transferred all
    right, it only SYS EX that gives me problems.
    It seems that data get into cubase se all right - all data I checked start
    with F0 and stops with F7
    Please help !
    cheers
    Kenneth
      • Advertising
  2. Aphelion Guest
    Message Count:
    On Sat, 7 Feb 2004 11:32:51 +0100, "Kenneth Kisbye" <>
    wrote:
    >Hi all
    >Please help !
    >cheers
    >Kenneth
    Hi Kenneth,
    Man...... I used KCS (& Bars & Pipes Pro) for years on an Amiga.
    I think we need to know more about your PC, as in what MIDI interface
    you're using, what operating system, WinXP I imagine?
    And... are you using any (emulated) MIDI ports in CubaseSE?
    As I remember... and this has to do as much with WinXP as Cubase...
    any interruption in the sysex data flow can cause a sysex fault. So if
    a note is transmitted (or controller data..) during the sysex dump a
    fault can happen.
    It can also be the fault of emulated drivers as well.
    Can you isolate the sysex?
    Ap
  3. Kenneth Kisbye Guest
    Message Count:
    I use win XP pro (uk version) and Madio Delta 24/96
    Both midi in- and out is Delta AP midi - so no emulated midi used
    I mute all other track so no notes is played.
    I also tried to make a sys ex dump directly from JD990 to cubase se and
    when returned to instrument I get a lot of checksum error.
    I also tried to lower the beat during play back to reduce the dataflow -
    still same problem. So the problem seems to origin from the pc/cubase not
    amiga.
    what do you mean by "> Can you isolate the sysex?" ??
    Kenneth
    "Aphelion" <> wrote in message
    news:...
    > wrote:
    > >Hi all
    include
    back
    them
    start
    > >Please help !
    > >cheers
    > >Kenneth
    > Hi Kenneth,
    > fault can happen.
    > Ap
  4. Aphelion Guest
    Message Count:
    On Sun, 8 Feb 2004 09:34:38 +0100, "Kenneth Kisbye" <>
    >amiga.
    Kenneth,
    I'm pretty sure SE uses the same MIDI system as SX.
    Have you read about the "ignoreportfilter" file?
    This is from a message I posted a couple of days ago.
    ignoreportfilter
    MIDI port filter - Important note regarding MIDI Interfaces
    Cubase SX / SL version 1.02 or higher has a function to filter out
    redundant MIDI ports provided by the MIDI interface driver. For
    instance if the MIDI interface driver installs both Windows MIDI ports
    and DirectMusic ports, these ports used to both show up in former
    Cubase SX / SL versions. Since DirectMusic mirrors the Windows MIDI
    ports as "emulated" DirectMusic ports by itself, it was possible that
    the MIDI ports showed up even 3 times in the MIDI device list in
    Cubase SX / SL. These multiple appearances of the MIDI ports were
    actually "multiple versions" of the same physical MIDI port.
    To avoid this, Cubase SX / SL 1.02 and higher provides an option to
    remove these redundant entries utilizing the MIDI port filter.
    However, in some cases the non-filtered, left over MIDI ports that
    will show up in the MIDI device list of Cubase SX / SL can be the ones
    that actually do not work as the MIDI interface driver doesn't support
    the DirectMusic architecture as Cubase SX / SL would expect.
    These cases were for example found with the following MIDI Interfaces:
    - MIDIMAN MIDIsport 8x8
    - MOTU MIDITimepieceAV
    -And OTHERS as well
    In this case, you can re-enable the filtered MIDI ports by proceeding
    as follows:
    - Browse to the Cubase SX / SL application folder (usually
    C:\programs\steinberg\cubasesx)
    and locate the folder "MIDI Port Enabler"
    - Open this folder
    - Pick the file "ignoreportfilter" and move it into the Cubase SX / SL
    application folder (one directory up)
    - Start Cubase SX / SL
    Now all available MIDI ports provided by the MIDI interface driver
    will appear in the MIDI device list of Cubase SX / SL. Please be aware
    that the MIDI ports now can show up 2 or 3 times in the list. If
    you're used to manage your MIDI IN by setting "All MIDI Inputs" in the
    MIDI IN selector, you should go to the Device Setup/All MIDI Inputs
    and disable the unwanted ports. Otherwise you will record MIDI from
    multiple ports which results in double MIDI notes.
    In addition to the above text from Steinberg.
    After doing this:
    Go to Device Setup/DirectMusic and select "NO" for all ports.
    Now there will be no (emulated) ports visible.
    Just want to make sure we're straight on this.
    There's a Win32 Sysex Dump program here.
    Get version 1.21
    http://www.bome.com/midi/
    Or hre, fr a great utility.
    http://www.midiox.com/
    It's also possible that early versions of SE suffered
    some of the same MIDI problems that early versions of
    SX had.
    >Kenneth
    >news:...
    >> wrote:
    >> >Hi all
    >include
    >back
    >them
    >start
    >> >Please help !
    >> >cheers
    >> >Kenneth
    >> Hi Kenneth,
    >> fault can happen.
    >> Ap
      • Advertising
  5. Kenneth Kisbye Guest
    Message Count:
    I've tried the ignoreportfilter procedure (pew - hard stuff - for me to
    understand) - no luck
    Also I've all the time selected "Delta AP midi" for both in and out.
    I've DL the program. It possible to get sys ex data both way's but there
    still remail a single "execlutive check sum error" or two. and basicly I
    wanna do it from inside cubase se - to have everything in a single file.
    More ideas..... ?
    Kenneth
    news:...
    > >amiga.
    > Kenneth,
    > ignoreportfilter
    > -And OTHERS as well
    > as follows:
    > - Open this folder
    > After doing this:
    > Get version 1.21
    > SX had.
    > >Kenneth
    > >news:...
    > >> wrote:
    > >> >Hi all
    > >include
    them
    > >back
    > >them
    all
    > >start
    > >> >Please help !
    > >> >cheers
    > >> >Kenneth
    > >> Hi Kenneth,
    > >> fault can happen.
    > >> Ap
  6. Aphelion Guest
    Message Count:
    On Sun, 8 Feb 2004 15:21:52 +0100, "Kenneth Kisbye" <>
    >More ideas..... ?
    >Kenneth
    Unfortunately... no.
    I would try the latest drivers from the M-Audio website.
    You also might try visiting Cubase.net
    http://www.steinberg.net/en/support/forums/
    There's a few good people over there but it's been my experience that
    the whiners are in greater number.
    There's also two or three representatives from Steinberg online.
    Just to let you know, I can transfer sysex to and from Cubase SX, so
    it is possible.
    Ap
  7. Kenneth Kisbye Guest
    Message Count:
    Thanks for trying :))
    Cheers
    Kenneth
    news:...
    > >More ideas..... ?
    > >Kenneth
    > it is possible.
    > Ap
  8. Aphelion Guest
    Message Count:
    On Mon, 9 Feb 2004 21:14:38 +0100, "Kenneth Kisbye" <>
    >Cheers
    >Kenneth
    If you solve it, please post the method.
    thanks-
    Ap
    >news:...
    >> >More ideas..... ?
    >> >Kenneth
    >> it is possible.
    >> Ap
  9. Steve Grace Guest
    Message Count:
    You might try slowing down the tempo in Cubase. Try 80 bpm.
    "Kenneth Kisbye" <> wrote in message
    news:c08ppl$2mec$...
    > Cheers
    > Kenneth
    > news:...
    there
    I
    file.
    > > >More ideas..... ?
    > > >Kenneth
    > > it is possible.
    > > Ap
  10. Kenneth Kisbye Guest
    Message Count:
    Fine idea , I already tried that - no luck here
    Kenneth
    "Steve Grace" <> wrote in message
    news:6LVVb.12408$IF1.11549@fed1read01...
    > > Cheers
    > > Kenneth
    > > news:...
    to
    > there
    basicly
    > I
    > file.
    > > > >More ideas..... ?
    > > > >Kenneth
    > > > it is possible.
    > > > Ap
      • Advertising
Share This Page
