The Roland JX-8P..
Discussion in 'rec.music.synth' started by K. Shaman, May 12, 2006.
  1. K. Shaman Guest
    Message Count:
    How is this synth. Is it a good all-purpose, analog synth? Would you
    suggest it over an Alesis Ion? Any opinions would be appreciated.
    Thank you.
      • Advertising
  2. nuMInous Guest
    Message Count:
    "K. Shaman" <> wrote in message
    news:2006051200010375249-kshaman@justusfewcom...
    > Thank you.
    Hey!
    I've got a Roland JX-8P. It's old (in case you weren't aware).
    It's only a 6 voice poly synth, with dual DCO's (Triangle, Pulse, Square &
    Noise - no PWM, which is a shame), Low Pass filter with resonance, dual
    envelopes & you can cross-modulate the DCO's. Programming is difficult (but
    not impossible) without a PG-800. The VCA can, at times, distort. There
    are only 32 programmable patches, so if you're into programming, then you're
    going to run out of program space. Not sure if you can get the MC-16
    program cartridges any more, but that'll give you another 32 programs.
    MIDI is quite usable. Each patch is only 87 bytes long, so an
    individual patch dump won't take you forever. Mind you, considering that
    there are only 87 bytes of data (10 of which are the Patch Name), it shows
    you that you may get bored with it's sound making ability quickly. There is
    no way to do an automatic dump via MIDI (i.e. get the computer to do an
    automatic backup of your data), you need to manually capture each patch by
    pressing the patch you want to save.
    There's a HPF, but it's almost useless. It only has three
    settings - as opposed to the LPF which is a slider. You can't sync the LFO
    with MIDI, which is a bit-of-a-drag. There is a built-in Chorus, but there
    are only two settings (slow & fast) - however the chorus must be BBD based,
    as it's noisy as hell!
    So, with all the things that I've said are wrong with the 8P, why do
    I have one? There's some sentimental attachment (my first _real_ synth -
    first was a Roland JX-3P, which wasn't worth it), it's easy to program,
    solid as a rock (never had a problem with it - apart from me mistakenly
    removing the battery & losing my patch data) & I like the feel. Whilst it's
    not a "weighted" keyboard, each key has a metal weight underneath each key,
    giving it some "inertia". Also, even with this 'weight', it's a light synth
    (about 8Kg, ~18lb), compared with a Yamaha DX (about 12Kg, ~26lb).
    However, if I'm ever to get another synth, I'd be on the lookout for
    an Access Virus KB, Waldorf Wave (dreamin'), or Kawai K5000W.
    - Mi.
    "Perception is 9/10ths of Reality" - Me.
    http://www.mp3.com.au/nuMInous
    [Existance] [Impulse] [Patterns]
      • Advertising
Share This Page
