The V-Vocal Website
Discussion in 'cakewalk.audio' started by Glennbo, Sep 9, 2010.
  1. Glennbo Guest
    Message Count:
    Q. Whaddaya get for including buggy glopped on plugins?
    A. User fan sites like this one! ;)
    http://www.v-vocal.com/
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
      • Advertising
  2. Gerry Peters Guest
    Message Count:
    On Thu, 9 Sep 2010 02:51:55 +0000 (UTC), Glennbo
    I've not had this problem, because I always "bounce to clip" after I
    tune a clip. Many years ago when many noticed instability with V-vocal
    clips, this was the recommended procedure. Never leave a clip as a
    v-vocal clip.
    The kiss of death is to copy and paste a v-vocal clip. I tried that
    about 2 or 3 times and never did it again. I always first rename a
    file before I start tuning it, so I can always revert back to the
    original unaltered vocal. I notice his workaround for v-vocal is
    underconstruction. I suppose he's post what I've just said as a
    workaround.
    I've gotten in the habit of working this way, so I'm not too concerned
    about them fixing this, although it's pretty lame and pathetic that
    it's never been fixed. Is there no shame left in the corporate world?
    Gerry Peters
  3. Glennbo Guest
    Message Count:
    The killer robot Gerry Peters <> grabbed the controls
    of the spaceship cakewalk.audio and pressed these buttons...
    > v-vocal clip.
    > workaround.
    I only tried using VVocal a few times and every time it was buggy so I quit
    using it altogether. In general if I don't like a vocal part due to pitch,
    I just re-sing it until I do like it. Still, Cake should either fix or
    scrap bugged up stuff like this and not let it go for 5 years and 5
    versions. As a developer, I'd either block access to doing what's broken,
    fix it, or scrap the module all together, but I wouldn't leave something in
    the software that can almost crash it on demand.
    ________ __
  4. Neil Rutman Guest
    Message Count:
    I do what Gerry doesandusev-vocal virtually problem free.
    Next up - fix thespacebar on mykeyboard!
    NeilR
    "Glennbo" <> wrote in message
    news:Xns9DEE579881CABBrownShoesDontMakeIt@188.40.43.230...
    > controls
    >> v-vocal clip.
    >> workaround.
    > quit
    > pitch,
    > in
    > ________ __
      • Advertising
  5. Glennbo Guest
    Message Count:
    The killer robot "Neil Rutman" <> grabbed the controls
    But if you are new Sonar user and you don't know to do that, you see your
    software as being buggy and un-trustworty. They should fix it.
    ________ __
  6. Sue Morton Guest
    Message Count:
    I submitted several reproducible bug reports early on for v-vocal, none
    are fixed AFAICT. But then neither are the reproducible bugs I
    submitted for Sonar 3 and 4. Cake is nothing if not consistent. :-/
    Sue Morton
    news:Xns9DEE63CEC69BDBrownShoesDontMakeIt@188.40.43.230...
    > controls
    > your
  7. Glennbo Guest
    Message Count:
    The killer robot "Sue Morton" <> grabbed the
    controls of the spaceship cakewalk.audio and pressed these buttons...
    I think a lot of it stems from the fact that a lot of the code was not
    written by people who currently work for Cake. VVocal is a Roland thing
    that was included before Roland bought them. Many bugs in the core
    software were introduced when Ron (IT'S MY KITCHEN, MINE I TELL YA!!!)
    Kuper was doing a lot of the programming. He no longer is a developer for
    Cake, so someone else must try to decipher his code and fix things in it.
    That's one big advantage I think brand "R" has. The guy who wrote it is
    still the same guy continuing to write it and is able to fix bugs fast
    because he is extremely familiar with the guts of the code.
    >> your software as being buggy and un-trustworty. They should fix it.
    ________ __
  8. Gerry Peters Guest
    Message Count:
    On Thu, 9 Sep 2010 14:48:41 +0000 (UTC), Glennbo
    You're right. I like V-vocal a whole lot more than auto-tune. The only
    bug I even encounter with V-Vocal is a rare instance where I get a
    phasing effect. When that happens I remove V-vocal from that word and
    if I still want to tune it, I then use auto-tune. Other than that it's
    bug free using it the way I use it.
    I have a macro set up where I highlight a vocal phrase and hit
    Control-Alt-V and it opens the V-Vocal screen maximizes it to fill my
    whole computer screen, then it fits the waveform perfectly into the
    whole screen and then tunes it. That's a good starting point to start
    manually adjusting the vocal. Sometimes no adjustment is needed.
    Gerry Peters
  9. Gerry Peters Guest
    Message Count:
    On Thu, 9 Sep 2010 15:15:22 +0000 (UTC), Glennbo
    Well that explains why it's not fixed. I have more sympathy and
    understanding for them not fixing it. I think at minimum they should
    be upfront in the help file and explain about the code decipher and
    give the workaround instead of someone thinking this is a lame buggy
    product.
    Gerry Peters
  10. Glennbo Guest
    Message Count:
    >>thing that was included before Roland bought them. Many bugs in the
    >>core software were introduced when Ron (IT'S MY KITCHEN, MINE I TELL
    >>YA!!!) Kuper was doing a lot of the programming. He no longer is a
    >>developer for Cake, so someone else must try to decipher his code and
    >>fix things in it. That's one big advantage
    > product.
    They should at least make it so it only works with a bounce, so you can't
    leave a clip in a state that might crash the whole program.
    ________ __
  11. Bob Donald Guest
    Message Count:
    Brand "R" LOL. I was actually thinking about buying the upgrade to play
    with V-vocal, but I'm going to give reatune a try when I get everything set
    up first.
  12. Glennbo Guest
    Message Count:
    The killer robot "Bob Donald" <> grabbed the controls of
    > play with V-vocal, but I'm going to give reatune a try when I get
    > everything set up first.
    I've barely played with ReaTune, but it seemed very stable, and I believe
    it employs the same incredible "Elastique" pitch stretching engine that is
    used elsewhere in "R".
    >> not written by people who currently work for Cake. VVocal is a
    >> Roland thing that was included before Roland bought them. Many bugs
    >> in the core software were introduced when Ron (IT'S MY KITCHEN, MINE
    >> I TELL YA!!!) Kuper was doing a lot of the programming. He no longer
    >> is a developer for Cake, so someone else must try to decipher his
    >> code and fix things in it. That's one big advantage I think brand "R"
    >> has. The guy who wrote it is still the same guy continuing to write
    >> it and is able to fix bugs fast because he is extremely familiar with
    ________ __
  13. Rick Paul Guest
    Message Count:
    I can't recall ever having had any problems with V-Vocal on the stability
    front, but, then again, I've always used it as a destructive effect like
    Gerry does because that's also the way I've used AutoTune for manual tuning.
    I still prefer AutoTune for all lead vocals, because I've never quite been
    able to figure out how to get V-Vocal to not give at least a slightly
    phasey, or at least electronic-sounding, effect and I absolutely hate their
    version of a pencil tool, which I find very hard to control with a mouse.
    However, I have used V-Vocal quite a bit for background vocals, where the
    slight lack of transparency isn't as important, and where I sometimes want
    to use the time alignment features, which AutoTune doesn't have, to tighten
    things against the lead vocal.
    That said, once I upgraded from AutoTune 4 to AutoTune Evo, I started using
    AutoTune more for background vocals, too, because Evo is a lot quicker to
    use with the new note-drawing tool (alongside some tuning speed tweaks to
    avoid the robotic effect), and the savings in time is significant. I can
    always use V-Vocal for time alignment in a separate pass if I really need
    that.
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
    "Gerry Peters" <> wrote in message
    news:...
    >>controls
    > Gerry Peters
  14. Gerry Peters Guest
    Message Count:
    On Sat, 11 Sep 2010 17:16:30 -0700, "Rick Paul"
    whenever I get that, I use the eraser tool to erase a little before
    and a little after it. Most of the time that removes it, sometimes I
    have to redo the V-vocal slip being careful to leave out that word
    which was phasing. Occasionally you can manually tune that note, other
    times I just open auto-tune and tune that word. Sometimes I can work
    for many hours and never get the phasing effect and other times I get
    it maybe 3 times during one song. It seems to be worse with some
    singers, maybe you're one of those singers that it picks on.
    I find the format tool works well when you have to tune a note which
    is close to a half step off and you start getting a little of the
    munchkin or darth vader effect. It knocks it out pretty well
    > I can
    >that.
    that is a pretty amazingeffect, you can even simulate a ritard with
    it
    Gerry Peters
  15. Rick Paul Guest
    Message Count:
    news:...
    I pretty much always get it. It's not a super-obvious thing, perhaps no
    different than if you were to use a mic that had some electronic character
    to it or something, but it's still sufficiently non-transparent that I don't
    want to use it on an exposed vocal in most context. I have actually used it
    a few times in modern pop-type stuff where it wouldn't be unusual to have
    even more egregious electronic effects.
    Yeah, that might well be. I think I probably have a fairly high balance of
    air and/or overtones in my voice much of the time, and that kind of stuff
    isn't super-friendly to pitch detection algorithms. AutoTune sometimes
    misses notes, too, but it doesn't even try to tune what it misses, so it's
    more or less like bypassing the effect on those parts.
    I assume you mean the formant tool? I haven't played with that much, but,
    from the little I have (and I may well have actually used it beyond playing
    a few times) I can appreciate how it could be useful at times. Since I'm
    mainly using V-Vocal on BGVs, though, and I usually double those anyway, I
    haven't generally cared so much if a slight hint of munchkin or Darth Vader
    effect creeps in.
    >> I can
    >>that.
    > it
    I've mostly used it for cleaning up sloppy note lengths in BGVs. The need
    to do that owes in part to my making the parts up as I go, and generally
    only starting to learn them decently around the third take, and not
    necessarily even getting it tight by then. And I typically only do about 5
    takes to get me one doubled part. That and not having the world's greatest
    breath support, so too often running out of air before the end of a long
    note at the end of a phrase. It just depends on the song and its style,
    though, whether I care all that much about tightness.
    Rick
    Rick Paul
      • Advertising
Share This Page
