This is why I should have stopped building my own computers yearsago . . .
Discussion in 'cakewalk.audio' started by Ben Berman, May 21, 2010.
  1. Ben Berman Guest
    Message Count:
    .. . . because I am all thumbs mechanically.
    I am removing a motherboard from a rackmount case, and 2 of the screws
    have an unnatural attraction to the brass standoffs underneath. I can
    even hear the standoffs spinning underneath . . . 8-(
    Any suggestions? It's in the case, so I can't really sneak a wrench
    underneath to grab the standoffs. Grrrrrrr.
    Any and all suggestions are welcome, 'cause it's gonna give me my chance
    to format NTFS and reinstall Windows, as Sue advised me to do about a
    year ago :cool:
    bzb
    THE SONG FACTORY
    Words and Music, made to order(TM)
    WWW: http://www.thesongfactory.com
      • Advertising
  2. Steve_Karl Guest
    Message Count:
    Re: This is why I should have stopped building my own computers years ago . . .
    Snap the heads off the screws with a good pair of cutters.
    "Ben Berman" <> wrote in message news:4bf70a21$0$21869$...
    > I am removing a motherboard from a rackmount case, and 2 of the screws have an unnatural attraction to the brass standoffs
    > underneath. I can even hear the standoffs spinning underneath . . . 8-(
    > Any suggestions? It's in the case, so I can't really sneak a wrench underneath to grab the standoffs. Grrrrrrr.
    > Any and all suggestions are welcome, 'cause it's gonna give me my chance to format NTFS and reinstall Windows, as Sue advised me
    > to do about a year ago :cool:
    > bzb
    > THE SONG FACTORY
  3. Steve_Karl Guest
    Message Count:
    Then when you put the standoffs back in use Elmers Glue ( in a pinch ) or loctite.
    "Steve_Karl" <> wrote in message news:ht71qq$661$-september.org...
    >> bzb
    >> THE SONG FACTORY
  4. Glennbo Guest
    Message Count:
    The killer robot Ben Berman <> grabbed the controls of the
    spaceship cakewalk.audio and pressed these buttons...
    If the standoffs are the standard little threaded brass guys, just unscrew
    them out of the case. Then when the mobo is able to be removed, you'll be
    able to use a wrench or a pair of pliers to get the screw out of the
    standoff. I've had to do this this plenty of times.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
      • Advertising
  5. Ben Berman Guest
    Message Count:
    As it turns out, I learned something new: standoffs come in different
    sizes. I thought they were uniform, but wikipedia and my own recent
    experience tells me otherwise. Once I snipped the buggers outta the
    case, I found that the new ones sent by Antec didn't fit! But I did have
    a few that fit the holes but were a bit small, so Steve's suggestion for
    loctite came in handy - I'd never heard of this stuff before.
    Thanks guys.
    bzb
    THE SONG FACTORY
  6. Steve_Karl Guest
    Message Count:
    "Ben Berman" <> wrote in message news:4bfcb4cb$0$22183$...
    > a few that fit the holes but were a bit small, so Steve's suggestion for loctite came in handy - I'd never heard of this stuff
    > before.
    I didscovered it when owning a Triumph Bonniville and trying to keep the muffler
    bolts from shaking loose every 20 miles. :)
    It's great stuff.
    S
      • Advertising
Share This Page
