touch sensitivity
Discussion in 'cakewalk.audio' started by Ron, Nov 30, 2004.
  1. Ron Guest
    Message Count:
    I am desperately trying to find a way to change the touch sensitivity
    of my keyboard in Sonar 4. I've examined the manual but I can't find
    anything on changing this, but a friend told me that it is possible to
    change the setting..( my keyboard doesn't have that option ) in the
    software...
    Can anyone tell me if it can be done in Sonar ?
    Ron
      • Advertising
  2. Glennbo Guest
    Message Count:
    The entity known as Ron, posted:
    > software...
    You can adjust the *velocity* response in Sonar with the velocity slider.
    Remove YourHeadFromYourAss to Reply by email
    _______ _____ ___ _____ ____
    / ___/ / / __/ |/ / |/ / _ )/ __ \
    / (_ / /__/ _// / / _ / /_/ /
    \___/____/___/_/|_/_/|_/____/\____/
    Glennbo These go to eleven
    Non-Linear Sound http://www.soundclick.com/glennbo
    Hear My Music http://www.soundclick.com/jambits
  3. The Amazing Seismo Guest
    Message Count:
    "Glennbo" <> wrote in message
    news:Xns95B158CF4A45DBrownShoesDontMakeIt@151.164.30.44...
    >> software...
    How would I eliminate all touch sensitivity?
    I am used to the old electronic keyboards that were either on or off. This
    new way of doing things causes me lots of grief. TIA
    Ed Cregger
  4. Dave Mazza Guest
    Message Count:
    That has to be done on the keyboard. Most keyboards have the option of
    turning that off.
      • Advertising
  5. Ricky W. Hunt Guest
    Message Count:
    "Ron" <> wrote in message
    news:...
    > software...
    What do you mean by change it? Are you trying to making a linear change or
    something like a curve? Sonar's MIDI FX called Velocity (which can really be
    thought of as a compressor) can help for linear stuff (or to remove it all
    together, like Ed wants to do). A third party product like this:
    http://www.cakewalk.com/Products/MusicLab/vm.asp set for Expansion could
    probably mimic altering the response curve.
  6. The Amazing Seismo Guest
    Message Count:
    "Dave Mazza" <> wrote in message
    news:qk1rd.34915$...
    > turning that off.
    Thanks, Dave. Now I have a clue as to where to start searching.
    Ed Cregger
  7. ronw Guest
    Message Count:
    > > software...
    Thank you, the velocity slider did the trick, my problem was that I didn't
    know it was called the key 'velocity'...thanks for pointing it out to me...
    Ron
  8. John Braner Guest
    Message Count:
    Or else, just record your part, and then set all velocities to 100 (that's
    what I do for ie Hammond Organ parts).
    There's a CAL script for this. I can't remember the name of it but it sets
    minimum and maximum values for all selected MIDI notes. You just set min and
    max value to 100 (I have this script bound to a function key).
    John Braner
    http://www.soundclick.com/jbranermusic.htm
    "The Amazing Seismo" <> wrote in message
    news:...
    > > turning that off.
    > Ed Cregger
  9. The Amazing Seismo Guest
    Message Count:
    "John Braner" <> wrote in message
    news:1101904288.r104qXTROrQIzlKREMAfiw@teranews...
    > and
    > John Braner
    Thanks, John.
    Much appreciated.
    Ed Cregger
  10. Ricky W. Hunt Guest
    Message Count:
    > and
    Why not just use the Velocity plugin? It's non-destructive and probably even
    works in real-time.
  11. Paul Guest
    Message Count:
    You could always just use "Interpolate" and set the velocities what ever you
    want.
    Paul
    "Ricky W. Hunt" <> wrote in message
    news:Tajrd.496025$D%.445617@attbi_s51...
    >> (that's
    >> sets
    >> and
    > even works in real-time.
      • Advertising
Share This Page
