turntable worth fixing?
Discussion in 'cakewalk.audio' started by polymod, Sep 18, 2010.
  1. polymod Guest
    Message Count:
    The albums have been kept in hiding for years, but the other day I was
    pumped about digitizing one particular album I had performed on some years
    ago. So I dug up the wife's 1972 Marantz turntable and was ready to roll but
    discovered the turntable no longer spins. I took off what I had always
    called the "turntable" and discovered what I assume used to be a rubber belt
    now looks like liquid tar and made a bit of a mess.
    Bag it? Or is it just a matter of some thorough cleaning and a belt from a
    30 year old record player?
    I took a few pics if it helps:
    The black tar-like substance around the brass roller is the culprit.
    http://www.sonicmusic.net/turntable1.JPG
    http://www.sonicmusic.net/turntable2.JPG
    Make/model:
    http://www.sonicmusic.net/turntable3.JPG
    http://www.sonicmusic.net/turntable4.JPG
    TIA
    Poly
      • Advertising
  2. Steve_Karl Guest
    Message Count:
    http://cgi.ebay.com/TURNTABLE-DRIVE...rntable_Parts_Accessories&hash=item483886ba21
    Here's a belt.
    I'd transfer all of your LPs to PC ASAP and be done with it.
    S
    "polymod" <> wrote in message news:4c94ee0b$0$20180$...
    > Make/model:
    > TIA
    > Poly
  3. dick Guest
    Message Count:
    > Make/model:
    > TIA
    > Poly
    Looks like ~$20 buys your memory's return. :-D
    <http://bit.ly/b4dMJo>
    <http://bit.ly/9cphEH>
    Clean it up. Lube the spindle and motor and rock out!
    <http://bit.ly/ckFeT3>
    Or if you're really serious: :-D
    <http://bit.ly/93HVRX>
    dick
    The True Spirit of '08:
    <http://tinyurl.com/2j78qt>
    The Boss Confronting "The American Taliban"®
    <http://tinyurl.com/bt75g8>
    (he's right behind me, isn't he?)
  4. Benjamin Goldman Guest
    Message Count:
    Steve_Karl wrote:
    > http://cgi.ebay.com/TURNTABLE-DRIVE-BELT-MARANTZ-TT-1060-/310185998881
    > ?pt=Turntable_Parts_Accessories&hash=item483886ba21 Here's a belt.
    > S
    All? You're nuts, man.
    > > was pumped about digitizing one particular album I had performed on
    > > some years ago. So I dug up the wife's 1972 Marantz turntable and
    > > was ready to roll but discovered the turntable no longer spins. I
    > > took off what I had always called the "turntable" and discovered
    > > what I assume used to be a rubber belt now looks like liquid tar
    > > from a 30 year old record player?
    > > Make/model:
    > > TIA
    > > Poly
    Yeah, belts are easy to get. I had a motor go out on one I had spare
    belts for so bought a new turntable. I always keep a good one around.
    Same for reel-to-reel and cassette.
    Larry, that thing is called the platter. ;-)
    This what I've got:
    http://www.sweetwater.com/store/detail/TTUSB/
    Works better for me with the RCA plugs than the USB. It will stand up
    to time for whenever you need it again.
    Cheers,
    Ben
      • Advertising
  5. Glennbo Guest
    Message Count:
    In news:4c94ee0b$0$20180$ the killer robot "polymod"
    <> grabbed the controls of the spaceship
    cakewalk.audio and pressed these buttons...
    > years ago. So I dug up the wife's 1972 Marantz turntable and was ready
    > to roll but discovered the turntable no longer spins. I took off what
    > I had always called the "turntable" and discovered what I assume used
    > to be a rubber belt now looks like liquid tar and made a bit of a
    > mess.
    I'd prolly get a belt, although I have more than once looked at the
    Numark USB turntable, which is like $99 and specifically made for
    digitizing vinyl.
    http://pro-audio.musiciansfriend.co...Turntable-with-USB-Audio-Interface?sku=801258
    Do you have a phono preamp? Magnetic phono cartridges *require* an RIAA
    preamp to both get the signal where it needs to be level wise, *and* to
    restore the recorded signals frequency response using de-emphasis.
    You can use an old receiver to do it, plugging the turntable into the
    phono input, and using one of the tape outs to go to your computer. Be
    sure to have the volume level all the way down so you don't blow the
    power amp with no speaker load. You can also get dedicated RIAA preamps
    that just have simple stereo in stereo out for about twelve bucks.
    http://compare.ebay.com/like/270622083374?ltyp=AllFixedPriceItemTypes&var=sbar
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  6. Benjamin Goldman Guest
    Message Count:
    > digitizing vinyl.
    That Ben suggested.
    The USB codec sucks on it. I use the RCA pin plugs and get hi-fidelity
    results.
    > http://pro-audio.musiciansfriend.com/product/Numark-TTUSB-BeltDrive-Tu
    > Do you have a phono preamp? Magnetic phono cartridges require an RIAA
    > preamp to both get the signal where it needs to be level wise, and to
    > Be sure to have the volume level all the way down so you don't blow
    > the power amp with no speaker load. You can also get dedicated RIAA
    > preamps that just have simple stereo in stereo out for about twelve
    > bucks.
    > var=sbar
    Cheers,
    Ben
  7. Glennbo Guest
    Message Count:
    In news:-september.org the killer robot
    "Benjamin Goldman" <> grabbed the controls of
    the spaceship cakewalk.audio and pressed these buttons...
    >> digitizing vinyl.
    > That Ben suggested.
    Yeah I saw that later.
    > results.
    And I assume that the RCA outs are post RIAA preamp?
    ________ __
  8. sambodidley Guest
    Message Count:
    "Benjamin Goldman" <BenGoldman######@CenturyTel.net> wrote in message
    news:-september.org...
    >> S
    >> > Make/model:
    >> > TIA
    >> > Poly
    > This what I've got:
    > Cheers,
    > Ben
    Maybe he only has a couple.<g>
  9. sambodidley Guest
    Message Count:
    > results.
    > Cheers,
    > Ben
    Same results here with mine. The USB sounded like crap.
  10. Benjamin Goldman Guest
    Message Count:
    > > > 8881 ?pt=Turntable_Parts_Accessories&hash=item483886ba21 Here's a
    > > > belt. I'd transfer all of your LPs to PC ASAP and be done with
    > > > it.
    > > > S
    > on >>> some years ago. So I dug up the wife's 1972 Marantz turntable
    > and >>> was ready to roll but discovered the turntable no longer
    > spins. I >>> took off what I had always called the "turntable" and
    > discovered >>> what I assume used to be a rubber belt now looks like
    > liquid tar >>> and made a bit of a mess.
    > belt >>> from a 30 year old record player?
    > culprit. >>> http://www.sonicmusic.net/turntable1.JPG
    > >>> Make/model:
    > >>> TIA
    > >>> Poly
    > > spare belts for so bought a new turntable. I always keep a good
    > > one around. Same for reel-to-reel and cassette.
    > > This what I've got:
    > > up to time for whenever you need it again.
    > > -- Cheers,
    > > Ben
    LOL Yeah /right!/
    Cheers,
    Ben
  11. tfm3 Guest
    Message Count:
    On Sat, 18 Sep 2010 12:47:15 -0400, "polymod" <>
    >Make/model:
    >TIA
    >Poly
    I wouldn't bother with the USB TT.Numark isn't exactly an audiophile
    brand to begin with. Strongly recommend direct drive tt [Technics
    1200,specifically] as a belt drive will transfer quite a lot of
    subsonic information [rumble] in the digitizing process making the
    ..wav files much larger than they need to be.Also,[probably stating the
    obvious,here] all phono pre's are not created equal.I use a vintage
    Luxman with cartridge impedance matching and 30hz shelf
    [filter].Originally $750-found it on craigslist for $50 mint.For the
    amount of time you may end up spending on this kind of project,might
    as well get a good result. I found Sonar to be total overkill for this
    so I've been using Adobe Audition 2 for mastering and editing.Use
    headphones for monitoring-TT's pick up speaker vibrations.
  12. Dominique Guest
    Message Count:
    tfm3 <> écrivait news:30sb96pfbplbimlom7plh4pc7nrrap3bnu@
    4ax.com:
    <snip>
    <snip>
    I thought wav file size were time based ie a 2 minutes of silence wav file
    has the same size than a 2 minutes of rumbles wav file (same sample rate
    and bit size).
    ~10 MB/min 44100hz-16bits/stereo
  13. polymod Guest
    Message Count:
  14. polymod Guest
    Message Count:
    Funny, the diagrams I saw on the net called that part a "turntable". I like
    your term better.
    You say tomato I say tomado!
    Poly
  15. polymod Guest
    Message Count:
    "sambodidley" <> wrote in message
    news:b8953$4c955966$48ac23b6$...
    > >> S
    > >> > Make/model:
    > >> > TIA
    > >> > Poly
    > > This what I've got:
    > > Cheers,
    > > Ben
    Hehe...I wish! But I really only want to do the ones I can't get on CD now
    Poly
  16. polymod Guest
    Message Count:
    "dick" <> wrote in message
    news:i72ug8$5mg$-september.org...
    years
    but
    belt
    a
    > > Make/model:
    > > TIA
    > > Poly
    Thanks a bunch dick! Appreciate it.
    Go 9'ers. I hope they at least show the #80 ceremony at half-time.
    Poly
  17. polymod Guest
    Message Count:
    "Glennbo" <> wrote in message
    news:Xns9DF7BB165C2DEBrownShoesDontMakeIt@81.169.183.62...
    > > mess.
    > digitizing vinyl.
    Yea, I still have the entire setup so it will work.
    I did see a brand new turntable for about 84 bucks so I may skip the repair
    and get something a little newer ;)
    Poly
  18. polymod Guest
    Message Count:
    "tfm3" <> wrote in message
    news:...
    years
    but
    belt
    a
    > >Make/model:
    > >TIA
    > >Poly
    Thanks for the info but my original post stated that I was only interested
    in transfering one album I played on many years ago. I'm not looking to turn
    this into a major project.....for now ;)
    Poly
  19. CozmikRay Guest
    Message Count:
    X-No-Archive: Yes
    Actually you won't damage a solid state amp (or most likely even a
    high quality, well-designed tube amp--IOW, a hi-fi amp as opposed to a
    guitar amp) by running it without a load. Think of the electricity in
    your home. Ya can't trip the breaker with nothing plugged in, because
    though there's voltage there, without a load, no current is being
    drawn. Excessive current draw is what trips circuit breakers and
    damages output devices in amplifiers.
  20. CozmikRay Guest
    Message Count:
    X-No-Archive: Yes
    If I were you I'd spend $10 for a belt, because that old 'table is
    prolly better than what you can get today for 84 bucks. Just clean the
    goo and residue left by the old belt with some alcohol or alcohol-
    based cleaner...tape head cleaner, that sort of thing.
      • Advertising
Share This Page
