Unusedable Exported WAV
Discussion in 'cakewalk.audio' started by Benjamin Goldman, Jul 10, 2010.
  1. Benjamin Goldman Guest
    Message Count:
    After I freeze a soft synth track and then export to WAV it won't play.
    What am I doing wrong?
    Cheers,
    Ben
      • Advertising
  2. Rick Paul Guest
    Message Count:
    "Benjamin Goldman" <> wrote in message
    news:...
    Make sure you're exporting in a format (i.e. sample rate and bit depth) that
    your player can handle. I think the default is probably 64-bit (or maybe
    32-bit if you're using the 32-bit audio engine?) and the same sample rate as
    you're using in your project, but I'm pretty sure 64-bit is not something
    Windows Media Player, for example, can handle.
    Some of the default formats can be changed in the Audio Options (or is that
    the Audio tab of the Global Options?), but I'm don't recall if this specific
    one can. I do recall it allows changing the imported audio file bit-depth
    (I usually just leave it as the source format since there's no benefit to
    sending it upwards at that level), and the rendering format for internal
    audio files (e.g. from doing a freeze -- I usually make that 64-bit to keep
    maximum resolution so as not to force bit reduction from a freeze), and
    there is at least one more that I don't recall off the top of my head.
    Rick
    Rick Paul
    Closet Cowboy Music (ASCAP)
    Web: www.RickPaul.info
    MySpace: www.myspace.com/rickpaulmusic
  3. Gerry Peters Guest
    Message Count:
    On Sat, 10 Jul 2010 11:32:16 -0700, "Benjamin Goldman"
    I assume you mean the exported wav file won't play. Do you mean it
    plays but there is silence or do you get an error message saying win
    media player can't play the file? When you export you can choose 16
    bit 44.1., if that doesn't play or plays but is silent then you may
    have another track soloed or the synth track muted, that will produce
    a silent wav file
    Hope that helps.
    Gerry Peters
  4. Benjamin Goldman Guest
    Message Count:
    > news:...
    > > play. What am I doing wrong?
    > depth) that your player can handle. I think the default is probably
    > 64-bit (or maybe 32-bit if you're using the 32-bit audio engine?) and
    > the same sample rate as you're using in your project, but I'm pretty
    > sure 64-bit is not something Windows Media Player, for example, can
    > handle.
    > is that the Audio tab of the Global Options?), but I'm don't recall
    > if this specific one can. I do recall it allows changing the
    > imported audio file bit-depth (I usually just leave it as the source
    > format since there's no benefit to sending it upwards at that level),
    > and the rendering format for internal audio files (e.g. from doing a
    > freeze -- I usually make that 64-bit to keep maximum resolution so as
    > not to force bit reduction from a freeze), and there is at least one
    > Rick
    Thanks. I'll take the check mark out of the 64 bit. Bet that's it.
    We'll see.
    Cheers,
    Ben
      • Advertising
  5. Benjamin Goldman Guest
    Message Count:
    > a silent wav file
    > Hope that helps.
    Thanks. The Media Player, Real Player, and Sound Forge won't open it,
    saying I need the correct codec.
    I think Rick hit it about the 64 bit setting issue. Am going to check
    that out now.
    Cheers,
    Ben
  6. Benjamin Goldman Guest
    Message Count:
    > news:...
    > handle.
    > Rick
    That did it. Thanks. I made a new project with 16 bit and exported to
    16 bit. The default in both cases was 64. :-/
    All better now!
    Cheers,
    Ben
  7. Benjamin Goldman Guest
    Message Count:
    > a silent wav file
    > Hope that helps.
    It was the 16 bit 64 bit issue Rick suggested. I set everything to 16
    bit and the exported wav is readable now. :eek:)
    Cheers,
    Ben
  8. Gerry Peters Guest
    Message Count:
    On Sat, 10 Jul 2010 23:11:53 -0700, "Benjamin Goldman"
    >> a silent wav file
    >> Hope that helps.
    Glad it worked out. You can get Win Media player to play 24 bit wav
    files. The fix is below if you need it, but by now the new Win Media
    player I would think would do that without having to do this tweak. I
    can send you the zip file if that link isn't good anymore or do a
    google search.
    http://www.chrisnet.net/msdn/AudioTypeConvert.zip
    Download it, Unzip it, and place the AudioTypeConvert.ax file in your
    System32 folder.
    Then open a Command Prompt and register it with this:
    regsvr32 c:\windows\system32\AudioTypeConvert.ax
    If you want to remove it at anytime just unregister it with:
    regsvr32 /U c:\windows\system32\AudioTypeConvert.ax
    Gerry Peters
  9. Benjamin Goldman Guest
    Message Count:
    > win >> media player can't play the file? When you export you can
    > choose 16 >> bit 44.1., if that doesn't play or plays but is silent
    > then you may >> have another track soloed or the synth track muted,
    > that will produce >> a silent wav file
    > >> Hope that helps.
    > > 16 bit and the exported wav is readable now. :eek:)
    > google search.
    > System32 folder.
    Thanks. No troubles with Media Player 11.
    Email me anytime.
    Cheers,
    Ben
  10. Rick Paul Guest
    Message Count:
    Yeah, but it's best to keep 64-bit checked for the engine, and for any other
    uses where you are creating intermediate files where you want to preserve
    full resolution. The time you need to go to 16-bit is just on your mixes
    for people to play (or to play in consumer-type programs yourself). You can
    set the export format in the File Export dialog box to do that. I make some
    presets, like CD Quality Mix (I think they have a built-in one something
    like that, too, but I change a few things from the defaults), so I just have
    to pick a preset and get all the settings I want for the particular context.
    That way it doesn't affect anything else, just the final output. Whereas if
    you change the defaults for internal stuff, like freezing, final mix quality
    may be adversely affected.
    Rick
    Rick Paul
    news:...
    >> a silent wav file
    >> Hope that helps.
    > Cheers,
    > Ben
  11. Benjamin Goldman Guest
    Message Count:
    > preserve full resolution.
    Thanks again, Rick.
    Cheers,
    Ben
  12. Glennbo Guest
    Message Count:
    The killer robot "Rick Paul" <> grabbed the
    controls of the spaceship cakewalk.audio and pressed these buttons...
    > other uses where you are creating intermediate files where you want to
    > preserve full resolution. The time you need to go to 16-bit is just
    > on your mixes for people to play (or to play in consumer-type programs
    > yourself).
    Unless you're me, then you wanna go 16/44 from the start, and spend all
    your time making music on your DAW instead of troubleshooting it! <g>
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  13. Rick Paul Guest
    Message Count:
    "Glennbo" <> wrote in message
    news:Xns9DB35763E7CCDBrownShoesDontMakeIt@81.169.183.62...
    >> yourself).
    It's one thing to start at 16/44.1 -- I might quibble with that versus
    24/44.1 due to headroom considerations, but, if you're careful on your gain
    staging ahead of you're A/D converters or using really limited dynamic range
    inputs, it's no big deal. Personally, I do need the extra headroom, because
    I don't use a compressor ahead of my A/D converters since I have higher
    quality plug-in compressors than my old Behringer hardware compressor, so I
    just record at low enough levels to guarantee I don't overload the A/D
    converters, which means needing the extra precision to make up for not using
    the high end of the dynamic range (I.e. other than for stuff that needs to
    get limited).
    It's another thing together, though, to have intermediate files, such as
    freeze results and submixes, bit-reduced and dithered down to 16/44.1, when
    the internal mixing engine will be 32-bits at a minimum or 64-bit if you're
    using the 64-bit audio engine. That represents the possibility of multiple
    losses of quality enroute to even getting to the final mix (which
    necessarily needs a loss in quality if you're going down to CD quality or
    worse). That's a difference that is easily hearable based on my past
    testing of this back when I was trying to decide whether to go from 24-bit
    renders for intermediate files to 32-bit renders before 64-bit was even an
    option.
    I can't see where it has anything to do with troubleshooting. We're talking
    set it and forget it stuff, and the defaults don't make such compromises, so
    you'd have to manually make them if you want to go that low. The only time
    you'd possibly run into trouble is if you tried to do something like use
    Sound Forge to edit the intermediate files (no issues there if you're using
    the 32-bit files, but the version of SF I have, which is not the latest,
    doesn't support 64-bit files).
    Rick
    Rick Paul
  14. Benjamin Goldman Guest
    Message Count:
    > news:Xns9DB35763E7CCDBrownShoesDontMakeIt@81.169.183.62... >The
    > > buttons...
    > > > for any other uses where you are creating intermediate files
    > > > where you want to preserve full resolution. The time you need to
    > > > go to 16-bit is just on your mixes for people to play (or to play
    > > all your time making music on your DAW instead of troubleshooting
    > > it! <g>
    > versus 24/44.1 due to headroom considerations, but, if you're careful
    > on your gain staging ahead of you're A/D converters or using really
    > limited dynamic range inputs, it's no big deal. Personally, I do
    > need the extra headroom, because I don't use a compressor ahead of my
    > A/D converters since I have higher quality plug-in compressors than
    > my old Behringer hardware compressor, so I just record at low enough
    > levels to guarantee I don't overload the A/D converters, which means
    > needing the extra precision to make up for not using the high end of
    > the dynamic range (I.e. other than for stuff that needs to get
    > limited).
    > as freeze results and submixes, bit-reduced and dithered down to
    > 16/44.1, when the internal mixing engine will be 32-bits at a minimum
    > or 64-bit if you're using the 64-bit audio engine. That represents
    > the possibility of multiple losses of quality enroute to even getting
    > to the final mix (which necessarily needs a loss in quality if you're
    > going down to CD quality or worse). That's a difference that is
    > easily hearable based on my past testing of this back when I was
    > trying to decide whether to go from 24-bit renders for intermediate
    > files to 32-bit renders before 64-bit was even an option.
    > talking set it and forget it stuff, and the defaults don't make such
    > compromises, so you'd have to manually make them if you want to go
    > that low. The only time you'd possibly run into trouble is if you
    > tried to do something like use Sound Forge to edit the intermediate
    > files (no issues there if you're using the 32-bit files, but the
    > version of SF I have, which is not the latest, doesn't support 64-bit
    > files).
    > Rick
    Neither does mine; Sound Forge Studio 6.0.
    Cheers,
    Ben
  15. Sue Morton Guest
    Message Count:
    My name must actually be Glennbo then! <vbg> Same here, 16/44 all the
    way... fast and efficient. If there are fidelity losses with this vs.
    converting back and forth amongst higher bit rates or sample rates I've
    not noticed them. But perhaps my 'ear palette' is just not refined
    enough to detect the difference.
    In any event most of my music is heard by the 'bengay crowd' (my church
    congregation) and 8 bit would probably suffice :)
    Sue Morton
    >> any
    >> to
    >> programs
    >> yourself).
    > all
  16. Glennbo Guest
    Message Count:
    >>> any other uses where you are creating intermediate files where you
    >>> want to preserve full resolution. The time you need to go to 16-bit
    >>> is just on your mixes for people to play (or to play in
    >> all your time making music on your DAW instead of troubleshooting it!
    >> <g>
    > gain staging ahead of you're A/D converters or using really limited
    > dynamic range inputs, it's no big deal. Personally, I do need the
    > extra headroom, because I don't use a compressor ahead of my A/D
    > converters since I have higher quality plug-in compressors than my old
    > Behringer hardware compressor, so I just record at low enough levels
    > to guarantee I don't overload the A/D converters, which means needing
    > the extra precision to make up for not using the high end of the
    > dynamic range (I.e. other than for stuff that needs to get limited).
    I don't need the extra headroom, and my outboard hardware compressor is
    very high quality. I record with my DAW the same way I did with my
    $10,000.00 Ampex 1". Nice and hot, but with no overs going in. Once
    recorded, I still use software compression, sometimes as many as three
    inline to tame too wide of a spectrum of amplitude.
    I *NEVER* freeze anything, or mix down any tracks in any of my productions.
    My DAW runs so efficient that I don't ever need to, and that's at the 1ms
    (64 samples) that I run it at from the start to the final mixdown finish.
    > files).
    Hehe, I'm referring to all the fiddling people do with their DAWs trying to
    make it more pristine than live (just wait till everyone goes 128 bit, that
    will be so awesome!), only to glob on a bunch of Vintage Warmers to distort
    the sound so it's enjoyable to listen to again. ;)
    ________ __
  17. Glennbo Guest
    Message Count:
    The killer robot "Sue Morton" <> grabbed the
    I've never had anyone say "eew, that sounds like a 16/44 recording", but I
    have had people who record for a living tell me that I get a great sound
    out of my studio. For me, it's about taking pictures, and the subject is
    the subject, not the camera. ;)
    ________ __
  18. John Braner Guest
    Message Count:
    On 13/07/2010 14:50, Glennbo wrote:
    > The killer robot "Sue Morton"<> grabbed the
    >> My name must actually be Glennbo then!<vbg> Same here, 16/44 all the
    Sorry, you're both wrong here. The best way, by far, is to record everything at 64 bit 96KHz, and
    *then* run it through Izotope Trash (or Audioease Speakerphone), to sound like it's running through
    a megaphone. ;-)
    This way you'll get a true 64 bit quality megaphone sound. Then you can add Vintage Warmer if you
    want. This is the secret to sooper high quality soundz.
    John Braner
    http://cdbaby.com/cd/JohnBraner
    http://www.soundclick.com/johnbraner
  19. Glennbo Guest
    Message Count:
    The killer robot John Braner <> grabbed the controls of
    >>> the way... fast and efficient. If there are fidelity losses with
    >>> this vs. converting back and forth amongst higher bit rates or
    >>> sample rates I've not noticed them. But perhaps my 'ear palette' is
    >>> just not refined enough to detect the difference.
    >>> church congregation) and 8 bit would probably suffice :)
    >> but I have had people who record for a living tell me that I get a
    >> great sound out of my studio. For me, it's about taking pictures,
    >> and the subject is the subject, not the camera. ;)
    > everything at 64 bit 96KHz, and *then* run it through Izotope Trash
    > (or Audioease Speakerphone), to sound like it's running through a
    > megaphone. ;-)
    > can add Vintage Warmer if you want. This is the secret to sooper high
    > quality soundz.
    The highest quality Rudy Vallee megaphone/distortion you can get!!!
    ________ __
  20. Ull Guest
    Message Count:
    On Tue, 13 Jul 2010 00:09:24 -0700, "Rick Paul"
    <> wrote:
    >The only time
    I just did a test 64 bit export. Windows and Vegas Pro 9 recognized it
    as a 64 bit file. It opened and played in SF Pro 10 but seemed to
    identify the file as 16 bit. 64 bit IEEE float is a record option in
    SF Pro 10. File Info in Audition 3 showed it as 64 bit IEEE Float. It
    played back fine. The status bar said it was playing back at 32 bit.
    FWIW this test was on a 32 bit OS. My 64 bit OS is Linux at the
    moment. My drive with Win7 Pro 64 bit is not in the machine right now.
    The file would not play with Gnome Mplayer or VLC on Linux Mint 64 but
    would with Movie Player and Rhythmbox if anyone cares.
    Ben N. Moore
      • Advertising
Share This Page
