using Kontakt from Sonar
Discussion in 'cakewalk.audio' started by Dewittian, Jun 16, 2010.
  1. Dewittian Guest
    Message Count:
    I used the VST to insert a MIDI and audio traks all neatly wrapped up
    in a folder. then in kontakt I used the library tab and found solo
    Cello and loaded it. When I activate the different pink colored keys
    on the bottom left of the keyboard the notes i click on respond as
    they should with different articulations (pizzicato, sticatto, tremolo
    and such).
    Now comes the hard part. I went in to the piano view roll in Sonar
    and put some notes in to test it and I'm having trouble figuring out
    how to get a note in the piano view to change the kontakt note played
    like I want for each different articulation. If I want two long
    notes followed by a few pizzicato notes, I can't figure out how to
    designate the note on the piano view to make kontakt player play the
    different style
    Does anyone know how to help me set this up so I can put the notes in
    the piano view and designate what version of the Cello sample I
    control when it plays back? I don't even know what they'd call that
    in the help menu?
    Thanks
      • Advertising
  2. Michael Fanning Guest
    Message Count:
    For the most part in Kontakt, changing articulations depends on the library
    you are using. Some of the libraries have key switching where you enter a
    specific note and it triggers such things a pizzicato, legato, vibrato etc.
    If the library doesn't have key switching then you might have to set up
    separate tracks for pizzi strings, legato, sustained notes etc. and then set
    the tracks up loading the patches you need for those articulations. Refer
    to the manual for the library to find which notes do the switching or you
    can just hit the notes that are below or sometimes above the instrument's
    range of playable notes and find out which trigger notes to use.
    MICHAEL FANNING,
    http://www.soundclick.com/michaelfanning
    "Dewittian" <> wrote in message
    news:...
    > and such).
    > different style
    > in the help menu?
    > Thanks
  3. Phoenix Guest
    Message Count:
    On Wed, 16 Jun 2010 13:07:33 -0700, "Michael Fanning"
    library
    enter a
    vibrato etc.
    set up
    then set
    Refer
    or you
    instrument's
    > MICHAEL FANNING,
    news:.
    up
    solo
    keys
    tremolo
    > > and such).
    Sonar
    out
    played
    the
    > > different style
    notes in
    that
    > > in the help menu?
    > > Thanks
    Some libraries have good documentation., like Scarbee bass, some,
    well, if they're documented, it's well hidden. If there's a pattern,
    let me know if you find it. I'd like to be able to be able to toggle
    pizza/legato with a pedal, among other things.
  4. polymod Guest
    Message Count:
    news:...
    > and such).
    > different style
    > in the help menu?
    > Thanks
  5. polymod Guest
    Message Count:
    news:...
    > and such).
    > different style
    > in the help menu?
    Sorry about the trigger finger<g>
    It's pretty EZ Paul. You just have to make sure you put the articulation
    trigger notes at the right pitch just before the next articulated note.
    As you can see in the "keyboard view" of Kontakt, the articulation trigger
    notes are usually an octave below the lowest note of the instrument's range.
    Just put your trigger notes there. That's all there is to it.
    Poly
      • Advertising
Share This Page
