Velocity
Discussion in 'alt.steinberg.cubase' started by Max Doorrijhoogte, Feb 17, 2010.
  1. Max Doorrijhoogte Guest
    Message Count:
    For the life of me, I can't find anything wrong.
    Nut I recently had to install everything anew (for the umpteenth time,
    don't get me started) and now Cubase doesnt respond to varying
    velocities.
    I even drew a line in the edit window, letting velocity rise from 0 to
    127 on a snare roll...but everything sounds equally loud.
    No matter what VST module I use: Nexus2, Kontakt sampler, Predator....
    Anybody have a bright idea?
      • Advertising
  2. Cyberserf Guest
    Message Count:
    On Feb 17, 10:03 am, Max Doorrijhoogte <>
    > velocities.
    Not a fix, but until you find one, you can always bounce your MIDI
    track down to an audio track and draw a fade in the volume automation
    window.
    Cheers, CS
  3. Hueyduck Guest
    Message Count:
    Not a bright idea, but if you say that you get the same issue with all
    the vstI, I would start and look at the "midi filter" of cubase.
    I Don't remember wher these setings are located but you'll find easily.
    Remember: what is ticked is filtered. It means that if "note on
    velocity" is ticked, it will not be transmitted.
    Huey
  4. Phil W Guest
    Message Count:
    Hueyduck:
    > easily. Remember: what is ticked is filtered. It means that if "note
    > on velocity" is ticked, it will not be transmitted.
    Probably somewhere under "Program" - "Program settings" - "MIDI"
      • Advertising
  5. Max Doorrijhoogte Guest
    Message Count:
    On Wed, 17 Feb 2010 07:07:11 -0800 (PST), Cyberserf
    >> velocities.
    >window.
    >Cheers, CS
    Thanks for the input, but velocity has effects different from
    volume....
  6. Max Doorrijhoogte Guest
    Message Count:
    On Wed, 17 Feb 2010 17:27:54 +0100, Hueyduck <>
    >Huey
    You're right, and the settings are in file->preferences -> MIDI
    But they are all OK. Only SesEx is ticked.
    Driving me mad!
  7. Jos Geluk Guest
    Message Count:
    > velocities.
    An unwanted expression map perhaps? Other MIDI Transform functions could
    do this, but it shouldn't happen on a shiny fresh track.
    Play that snare roll again, but this time open a Midi Monitor on the
    track. (It's under MIDI Inserts). Make sure it is on and that notes are
    shown. As the notes roll by, is Value2 (velocity) what you expect? What
    velocity is it, if it's all the same? 127? 64?
    This would still give you no explanation though. Only whether the
    "equalization" occurs before or after the MIDI monitor. I'll see if I
    can come up with more ideas.
    Jos.
    Ardis Park Music
    www.ardispark.nl
  8. Hueyduck Guest
    Message Count:
    another not-so-bright idea:
    About the programs you are playing (be it in kontakt or other vst-i),
    are you sure that thay are set to respond to velocity. This is not a
    given at all.
    Many programs such as many synth or sometimes beat boxes, are set *not*
    tp respond top velocity, in order to emulate old harware.
    In Kontakt, for instance, you will not get a velocity/volume link unless
    ther e is , fopr eaxh program, an "AMP" modulation set to=> velocity
    with a positive value.
    Have you tried it with some pianos, or anything that you can visualy
    verify that it has a velocity controller set to modulate volume?
    Of course, if you are talking about programs that would respond to
    velocity before you reinstall everyhting, noneed to seek in this direction.
    Huey
  9. Max Doorrijhoogte Guest
    Message Count:
    On Thu, 18 Feb 2010 04:33:14 +0100, Hueyduck <>
    >given at all.
    >Huey
    Good suggestion, I'll have a look!
      • Advertising
Share This Page
