Vista on one of my PCs!
Discussion in 'cakewalk.audio' started by Glennbo, Jun 14, 2010.
  1. Glennbo Guest
    Message Count:
    I am really not a fan of Vista, but now I have it installed on my bedroom
    machine, http://members.cox.net/glennbopix/BTV-Broom.jpg that's a Beyond TV
    client. I was using a freebie copy of Windows 2000 Advanced Server that I
    have on that machine, but it was way overkill, and I got turned onto an
    unopened copy of Vista Home Premium, so I installed it this weekend.
    After doing the install, it proceded to download and install 96 updates,
    then I downloaded and installed service pack 1 and service pack 2, after
    which it proceded to download and install some 30 or 40 more updates.
    I've now got it current and since that machine is pretty much a one trick
    pony (being a media client), I think it will do ok. I just got that
    machine hard wired to my router a couple weekends ago, and now with the
    lighter weight OS, it's streaming 1080 & 720 HDTV very smooth.
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
      • Advertising
  2. Bob Donald Guest
    Message Count:
    Vista was actually pretty good as a media PC, whether using VMC, or as a
    core op system to just run BTV and Sage client on. Of course, that's the
    only thing it was good for in my circumstances. Since I went to the hd200
    with Sage I ripped that PC out of the home entertainment center, but it
    worked fine when I was doing almost the same thing as you with Sage. VMC
    also has netflix and (IIRC) Hulu streaming. Now I'm back to 2 unused Vista
    licenses.....
    "Glennbo" <> wrote in message
    news:Xns9D976BE1AC56BrownShoesDontMakeIt@85.214.73.210...
    > TV
    > ________ __
  3. Glennbo Guest
    Message Count:
    In news:p the killer robot
    "Bob Donald" <> grabbed the controls of the spaceship
    cakewalk.audio and pressed these buttons...
    > a core op system to just run BTV and Sage client on. Of course,
    > that's the only thing it was good for in my circumstances. Since I
    > went to the hd200 with Sage I ripped that PC out of the home
    > entertainment center, but it worked fine when I was doing almost the
    > same thing as you with Sage. VMC also has netflix and (IIRC) Hulu
    > streaming. Now I'm back to 2 unused Vista licenses.....
    I did all the "Black Viper" tweaks, which stopped or removed from cache
    memory a *lot* of services in Vista. The only service I had to re-enable
    out of the 25 or so that I disabled was the HID service which turns out is
    needed for *extended* keys on your remotes to function properly. Every
    other thing I killed per Black Viper's "Tweaked" Vista settings, is still
    killed and everything else works and is able to breathe. I also found that
    using Cyberlink Media's HiDef decoder is the most efficient of the pack.
    Decoders from Microsoft, Snapstream, Arcsoft, and Nero had more frequent
    jitters than using Cyberlink Media's codec that gets installed with the
    free version of Power DVD that comes with most DVD burners.
    Hehe, I'm still using a two generation old X-DAW with a throw away OS for
    my media client in the bedroom. It didn't really cost me anything except
    for the case, since it was junk laying around the house and office. ;)
    ________ __
  4. kitekrazy Guest
    Message Count:
    > "Bob Donald"<> grabbed the controls of the spaceship
    A local computer guy gave me a copy of Vista Ultimate 64. I got a
    spare box I might install this on. The nice thing it's not an upgrade
    and will also come in handy for another upgrade license.
  5. Glennbo Guest
    Message Count:
    The killer robot kitekrazy <> grabbed the
    controls of the spaceship cakewalk.audio and pressed these buttons...
    >> cache memory a *lot* of services in Vista. The only service I had to
    >> re-enable out of the 25 or so that I disabled was the HID service
    >> which turns out is needed for *extended* keys on your remotes to
    >> function properly. Every other thing I killed per Black Viper's
    >> "Tweaked" Vista settings, is still killed and everything else works
    >> and is able to breathe. I also found that using Cyberlink Media's
    >> HiDef decoder is the most efficient of the pack. Decoders from
    >> Microsoft, Snapstream, Arcsoft, and Nero had more frequent jitters
    >> than using Cyberlink Media's codec that gets installed with the free
    >> for my media client in the bedroom. It didn't really cost me
    >> anything except for the case, since it was junk laying around the
    For the one function I'm using Vista for (TV Client) it works fine, and now
    that I've slimmed it down, it runs pretty good on my old P4 that was my DAW
    two computers ago.
    ________ __
      • Advertising
Share This Page
