Vsampler Version Cocktail Kit
Discussion in 'cakewalk.audio' started by Glennbo, Apr 18, 2010.
  1. Glennbo Guest
    Message Count:
    The next incarnation of my cocktail kit. This one is done as a Vsampler
    instrument, and has more samples than the original. It now includes
    sidestick, rimshot, and crash 2 on the crash ride cymbal. It also rotates
    the voices so that the cymbals sound less fake. Hopefully this structure
    will translate properly on other people's systems. I made it so it should
    function as a self contained folder with the samples and .vs3 file
    together. Anyway, the new version is here. Enjoy!!!
    http://members.cox.net/spambaconandspam/Glennbo'sCocktailKit.zip
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
      • Advertising
  2. Mr. Robin Banks Guest
    Message Count:
    Glennbo <> whinged
    news:Xns9D5EA7FD138C0BrownShoesDontMakeIt@69.16.185.250:
    > Vsampler instrument, and has more samples than the original. It now
    > includes sidestick, rimshot, and crash 2 on the crash ride cymbal. It
    > also rotates the voices so that the cymbals sound less fake.
    > Hopefully this structure will translate properly on other people's
    > systems. I made it so it should function as a self contained folder
    > with the samples and .vs3 file together. Anyway, the new version is
    > here. Enjoy!!!
    Unfortunately, Master Booka does not have V-Sampler. Tsk tsk.
    Robin Banks LLC, Grand Bahamas
    Advanced Risk and Wealth Management
  3. Glennbo Guest
    Message Count:
    The killer robot "Mr. Robin Banks" <> grabbed the controls of
    the spaceship cakewalk.audio and pressed these buttons...
    >> here. Enjoy!!!
    Too bad, coz it's setup and ready to record/play with more samples and
    variations. For instance, the Vsampler version of the small side tom and
    the floor tom have three keys each, and each one is set with decreasing
    pitch and volume. The pitch is very slight, only so you don't get phasing.
    ________ __
  4. Phoenix Guest
    Message Count:
    On Mon, 19 Apr 2010 07:00:08 +0000 (UTC), "Mr. Robin Banks"
    <> wrote:
    > Glennbo <> whinged
    now
    cymbal. It
    folder
    is
    > > here. Enjoy!!!
    Oh boy, now I have to find Vsampler 3.52.
      • Advertising
  5. Glennbo Guest
    Message Count:
    The killer robot Phoenix <> grabbed the controls of the
    I think it's on the Sonar 3 disk.
    ________ __
  6. John Braner Guest
    Message Count:
  7. Glennbo Guest
    Message Count:
    The killer robot John Braner <> grabbed the controls of
    > Or you can get it here:
    > http://www.maz-sound.com/index.php?show=product&id=2&PHPSESSID=6f9c5ad0
    > dc76c61c6260377daa7007c8
    But the Sonar one is free, if you have it.
    ________ __
  8. polymod Guest
    Message Count:
    "Glennbo" <> wrote in message
    news:Xns9D5F6DF06D5D5BrownShoesDontMakeIt@188.40.43.213...
    My Kontakt manual says it supports VSampler 1-2.5.
    Prolly won't work, but it's worth a try!
    Poly
  9. Glennbo Guest
    Message Count:
    The killer robot "polymod" <> grabbed the controls
    of the spaceship cakewalk.audio and pressed these buttons...
    >> > ad0 dc76c61c6260377daa7007c8
    Hopefully that will work, because the Vsampler version of my cocktail kit
    is way better in Vsampler.
    I used Vsampler v3.5 (I think that's the version) that came bundled with
    Sonar 3. It's the same one I used to use for my DFH/Purrrfect drum kit,
    back when I was writing some documentation for Vsampler, since it didn't
    come with any manual when they bundled it with Sonar.
    ________ __
  10. Phoenix Guest
    Message Count:
    On Mon, 19 Apr 2010 12:30:02 -0400, "polymod" <>
    controls of
    > Poly
    John's link should do it; not @ my PC right now but I think I have
    the SN in a doc with other CW-related ones. I did get the full
    version way back when. I hadn't thought to try Kontakt. Would be nice
    if that works cos it's 64-bit. How do you get Kontakt to do the
    alternate samples thing though?
  11. John Braner Guest
    Message Count:
    On 19/04/2010 16:48, Glennbo wrote:
    > The killer robot John Braner<> grabbed the controls of
    I think the SONAR version is on the wevb site too. You just need a serial number which will be on
    your SONAR disk I guess (in which case you probably wouldn't need the download link) ;-)
    John Braner
    http://cdbaby.com/cd/JohnBraner
    http://www.soundclick.com/johnbraner
  12. John Braner Guest
    Message Count:
    > controls of
    >> Poly
    > John's link should do it; not @ my PC right now but I think I have the
    > SN in a doc with other CW-related ones. I did get the full version way
    > back when. I hadn't thought to try Kontakt. Would be nice if that works
    > cos it's 64-bit. How do you get Kontakt to do the alternate samples
    > thing though?
    If you upgraded to the full version (like I did) - go to th eweb site because there is a newish
    version from late last year - 3.5a or something like that...
    John Braner
  13. Glennbo Guest
    Message Count:
    > serial number which will be on your SONAR disk I guess (in which case
    I upgraded the copy I had already installed from my Sonar disk. I didn't
    know you could do a virgin install, and just type in your OEM Sonar key.
    BTW, tell Toontrack to send me a SDX editor, and I'll make a Superior
    Drummer version of my cocktail kit, since all the ones Toontrack have
    ever made sound like total dog doo doo. ;)
    ________ __
  14. Phoenix Guest
    Message Count:
    On Mon, 19 Apr 2010 18:52:05 +0100, John Braner <>
    > > controls of
    > >> Poly
    have the
    version way
    works
    samples
    > > thing though?
    > John Braner
    So there is; thanks joh
  15. Phoenix Guest
    Message Count:
    Oops stupid phone newsgroup program.That was supposed to be "thanks
    john".
  16. Mr. Robin Banks Guest
    Message Count:
    Glennbo <> whinged
    news:Xns9D5F6DF06D5D5BrownShoesDontMakeIt@188.40.43.213:
    6f9c5ad0
    I will have to search Master Booka's Sonar 5 disks. He is away somwhere
    yachting and pitching woo with a certain multiple New York Times best
    selling Authoress at the moment.
  17. Glennbo Guest
    Message Count:
    In news:Xns9D63DE9728829RobinBanksGBLLC@94.75.214.90 the killer robot "Mr.
    Robin Banks" <> grabbed the controls of the spaceship
    Sonar 3 was the one that included it. I don't know if 4 and 5 continued to
    have it, since it was already installed on my machine after Sonar 3.
    ________ __
  18. Phoenix Guest
    Message Count:
    Woo-hoo, I found my S/N and reg code!
    news:Xns9D645A3271646BrownShoesDontMakeIt@69.16.185.247...
    > to
    > ________ __
  19. Glennbo Guest
    Message Count:
    In news:hs9utq$tug$-september.org the killer robot "Phoenix"
    Now you can kick back and have a cocktail!
    ________ __
      • Advertising
Share This Page
