VST to Cubase4 and upgrading drives
Discussion in 'alt.steinberg.cubase' started by BW, Nov 2, 2008.
  1. BW Guest
    Message Count:
    I'll be taking the upgrade to 4 soon from being a life long VST user
    and I figure its about time to upgrade a couple of my drives and
    rethink how I have them setup.
    Right now I got a P4 w/ ASUS P4C800-e deluxe with 2 7200 IDE drives
    and a 7200 SATA, 2gig PC3200 ram. The IDE's are getting a little old
    so I'm thinking at least one could use a retirement. The board won't
    handle SATA 3 but downgrading the drive to 150 isn't an issue (from
    what I understand). I wasn't really thinking of setting up RAID but
    its not out of the question.
    What I was thinking is ditching the oldest IDE drive and setting up
    the "newer" IDE for XP and programs then using a new SATA for working
    audio and the other SATA for storage. The other option would be to go
    RAID for either the OS or the data drives or both. Or I could ditch
    both IDEs and setup a the OS on a RAID SATA's the do a RAID SATA for
    the data, but this would mean buying 2 new drive at least. I'm not
    worried about parity so we're talking RAID 0 for any of this. I'm not
    a pro with all this bus speed/Promise stuff so would it be worth it to
    use all SATA for the drives, or would keeping the one IDE for the OS
    make sense, or should I have a SATA drive run the OS and use the IDE
    as my data storage drive? Or is RAID even worth it for running XP, I
    can see how the arary would help for the working audio, but for just
    storage not so much. Would I want to consider using the Promise
    connection for any of this? The only card I have in there is the vid
    card, my audio card, Edirol FA101 uses firewire. So any opinions are
    welcome on getting the most out of this board as possible for read/
    write bus speeds. Seeing how I got 2 IDE connections, the Promise
    connection, 4 SATAs, two of which can be RAID, I've got some
    options...
    thanks BW
      • Advertising
  2. nickm Guest
    Message Count:
    "BW" <> wrote in message
    news:...
    > options...
    That board's pretty well specified as I remember and pretty reliable.
    There must be a reason why you think your existing hard drives are about to
    give up the ghost. Fair enough.
    It's not a bad idea to replace your drive(s) if they are giving you cause
    for concern. For a DAW, IDE 7200rpm drives are usually more than adequate.
    An ATA 133 capable drive should in theory be able to handle 133MB/s data
    transfer, but in practice actual data transfer speeds will be around only
    half that. A SATA drive can handle 150MB/s in theory, but in practice the
    speed will be similar to what is achieved with an ATA 133 drive. A SATA II
    drive can handle up to 300MB/s but on your board a SATA II drive would only
    be able to run at 150MB/s maximum. Most SATA drives sold now are SATA II
    anyway.
    For speed, you won't do much better than one of the Western Digital Raptor
    series drives as they have a spindle speed of 10krpm and they will achieve
    much nearer to the maximum transfer speed possible under SATA or SATA II,
    however capacity when compared to other drives from WD and other
    manufacturers is relatively small and they aren't cheap when compared to
    standard 7200rpm drives. The largest WD Raptor drive at the moment is I
    believe 150GB, which should be more than enough for most projects.
    Personally, I don't think you'd see much real benefit over a standard drive
    for audio with Cubase 4.5 with your current system, and I'd be tempted to go
    for a large capacity well specified Seagate drive for less money.
    RAID comes in a variety of flavours as you probably know. I've highlighted
    three below: RAID 0; RAID 1 and; RAID 5
    RAID 0:- If you are thinking about increased transfer speed and capacity,
    you will need two drives which are synchronised (striped) and which together
    provide greater capacity and will be seen as a single 'drive'. This type of
    array is called RAID 0. The advantages are: you get a larger single
    (virtual) drive and faster data transfer speeds as both drives can read and
    write simultaneously. The main disadvantage is that if one of the drives
    fails or the array gets broken (this depends on the quality of the hardware,
    the quality of the drivers and the knowledge/experience of the person
    building the system) for some other reason, you've lost all your data, so
    your backup regime would have to be very disciplined. personally I'd avoid
    using RAID 0 - particularly as the reasons for it are less compelling
    nowadays given the large capacities that are available in a single drive and
    the fact that most hard drives will perform far better than adequately well
    on their own. Of course any drive can fail, and for that reason backups are
    very important, but by putting RAID 0 into the mix, the risks of data loss
    because of a failed array are higher.
    RAID 1:- If you are thinking more about data integrity and safety, then RAID
    1 (mirrored) is probably better. RAID 1 uses two identical drives and the
    idea is that all data written to drive 1 will simultaneously also be written
    to drive 2 thereby meaning you immediatley have a safety net should
    something go wrong. A RAID 1 array with one of the drives failed can
    continue to operate in a degraded state whilst a replacement drive is
    sourced. This would be my preferred choice for any application where the
    data was sufficiently important and particularly in any commercial
    environment where the data isn't centrally held on a server. The advantages
    are: a RAID 1 array can be rebuilt provided one of the drives is still
    operational; there is a continuous second copy of all data at all times (not
    to be confused with regular backups, but it does provide a first line safety
    net). The main disadvantages are: slightly slower (pretty negligible) data
    transfer speeds; twice the outlay in terms of cost for two identical drives
    whilst not seeing any benefit in increased capacity.
    RAID 5:- If you want the best of both worlds, RAID 5 might suit your needs.
    RAID 5 uses a minimum of three identical hard drives which are
    synchronised/'striped' together to provide a capacity of two thirds of the
    sum capacity of all three drives. If any single drive in the array fails,
    the array can continue to operate in degraded mode whilst a replacement is
    sourced. If your system only supports two drives in any RAID array this
    won't work anyway.
    As I said, I'd personally be more interested in protecting my data than
    increasing the data transfer speed. Yes, RAID 0 does go faster in general
    than a single hard drive would on its own, but not that much faster in
    practice, and for me the risks are greater than the gain.
    In your position, I'd double check the maximum drive capacity that your
    motherboard can handle and go with a single SATA drive that is big enough
    for your needs for audio data OR two identical drives in a RAID 1
    configuration if you want increased protection against data loss. Unless
    there is some pressing reason why the main OS drive should be replaced, I'd
    probably stick with the existing drive - BUT I would recommend making a full
    image backup after optimisation in case of failure so that your OS can be
    restored to a new drive relatively painlessly as necessary. Symantec/Norton
    Ghost or the freeware DriveImage XML are two applications which can handle
    this.
    You say you're not worried about parity, which I take to mean you're not
    bothered about mirroring (RAID 1), so I'd say just get a large capacity
    single drive for data and forget about RAID altogether. In my experience
    Promise RAID chipsets and drivers have been reliable, so there would be no
    real reason to not use the Promise IDE connector in JBOD mode, but if
    there's a free SATA connector not on the Promise chip, I'd probably use that
    with a SATA drive.
    Remember that if adding drives to an existing system, power consumption will
    rise and the existing PSU may need to be replaced. In fact if you are
    already having issues with booting your system and you suspect that your
    hard drives are at fault, you may well find that your PSU isn't working
    quite as well as it once did. In my day job I see quite a lot of cheap
    PSU's that are no longer performing as well as the label on the case would
    have you believe and the typically the main symptoms will be systems not
    booting at the first attempt which generally gets gradually worse in a
    matter of weeks; spontaneous reboots. Of course there are plenty of other
    possible reasons for those symptoms, but trying a different PSU often does
    the trick with systems that are more than a couple of years old.
  3. BW Guest
    Message Count:
    Re: VST to Cubase4 and upgrading drives
    > news:...
    > > options...
    > anyway.
    > won't work anyway.
    > this.
    > with a SATA drive.
    Thanks for the reply. The more I think of RAID the less I want to go
    that route. The only real reason I can see for replacing one of my
    drives is its age, besides that, its not showing any bad behavior.
    And I'm thinking a fresh XP install wouldn't hurt things. I'll
    probably just get a good SATA drive and replace my oldest IDE with
    it. And yeah, Ghost it for sure before I do anything.
      • Advertising
Share This Page
