Where is the audio sample played by the "audio" metronome of cubaseSX1?
Discussion in 'alt.steinberg.cubase' started by Hueyduck, Aug 9, 2009.
  1. Hueyduck Guest
    Message Count:
    Hi everyone,
    I want to change the horrible bip sound used by SX1 to play the
    metronome sound.
    I want to avoid using midi clic, so I already put aside the idea of
    loading a LM9 to play the sound ;-)
    But I figured out that when the "audio click" was active, Cubase was
    simply playing a .wav that was located somewhere. But where could it be?
    Thx for your help.
    Huey
      • Advertising
  2. nickm Guest
    Message Count:
    Re: Where is the audio sample played by the "audio" metronome of cubase SX1?
    "Hueyduck" <> wrote in message
    news:4a7f0ca9$0$3592$...
    > Hi everyone,
    > I want to change the horrible bip sound used by SX1 to play the metronome
    > sound.
    > Thx for your help.
    I'm not so sure it is an audio sample in the fom of a WAV file. It sounds
    'generated' in real time - it's just a couple of different 'beep' noises
    with the first in every bar being different in pitch and volume. I might be
    wrong about it being a generated noise, but that's what I've always thought
    it was
  3. SODDI the Obeah Man Guest
    Message Count:
    "nickm" <> wrote in message
    news:4a83a1d7$0$2478$...
    >> Hi everyone,
    >> sound.
    >> Thx for your help.
    > be wrong about it being a generated noise, but that's what I've always
    > thought it was
    I think you're right about the generated "beep" metronome.
    In Cubase Studio 4, under "Metronome Setup", you can select one of three
    ways of generating that metronome sound - internal generation, MIDI out, and
    selecting a sample from your hard drive.
    When I still had a MIDI drum module (Alesis D-4) I used the MIDI option
    almost exclusively. Now I use "beep" and I don't like it that much.
      • Advertising
Share This Page
