white NOISE every 10 seconds ???
Discussion in 'alt.steinberg.cubase' started by BC, Aug 5, 2009.
  1. BC Guest
    Message Count:
    Recently ghosted my C drive to a new drive.. was running a "try before you
    buy" Nuendo 3..worked flawless on the original drive, but when moved to the
    new drive, I'm getting this very low level "white noise" blast about every
    10 seconds...
    Any way, I completely uninstalled Nuendo 3 and syncrosoft dongle emulator
    etc..from the new drive...and proceded to install my nice new (full ret.)
    Cubase 5, and Wavelab Essential 6.
    Strange thing is, this "white noise" thing is STILL happening !!!
    So does anybody have any ideas on what this might be ???
    Was told originally it was to do with the dongle emulator's way of saying
    "this is now on a different PC"..hmmm...well that's fine...but surely after
    I uninstally all evil, and did the fresh install with all legit stuff this
    wouldn't be the case ???
    Could it be to do with the actual hard drive ( the new one ) ???
    I am runing this with a Presonus "Fire Studio" interface on a PC..
    BC
      • Advertising
  2. Laurence Payne Guest
    Message Count:
    >10 seconds...
    Might be completely unrelated to the warez. What takes longer -
    troubleshooting this comprehensively or wiping your drive and starting
    over with a clean Windows? How long since you did this anyway? As
    you're obviously an experimenter, it should be a regular event.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  3. BC Guest
    Message Count:
    "Laurence Payne" <> wrote in message
    news:...
    >>the
    >>every
    >>10 seconds...
    >>after
    Hmmm...well I thin k it would take me a few weeks to do a complete reformate
    and start over unfortunately.
    Luckily I have the option to still boot off the old CD drive if I need to
    do some music... but really want to get this new set up running smoothly
    asap..
    I'm going to re image to another hard drive to see if that changes
    anything... but after that the reformat may be the only solution...damn.. :(
    BC
  4. Laurence Payne Guest
    Message Count:
    Usually takes me half a day. Keep the old drive as backup - a new
    one's cheap enough. Don't install a program unless you're SURE you'll
    need it that week. Once your staples are on, make a full disk-image
    backup so you can jump to that point next time.
  5. BC Guest
    Message Count:
    Thanks Lawrence...
    it ended up being an exprired demo of a reverb that was still hanging around
    from ages ago... so all is clean aready to go now :)
    cheers,
    Hi-Soft
    news:...
    >>reformate
      • Advertising
Share This Page
