Win 7 Drivers?
Discussion in 'cakewalk.audio' started by Serginho do Teclado, May 12, 2010.
  1. Serginho do Teclado Guest
    Message Count:
    Anybody knows if I can get Win 7 drivers anywhere for Roland SC
    series.
    SC-8850, SC-8820, SC-D70.
    Thanks.
      • Advertising
  2. Nil Guest
    Message Count:
    On 12 May 2010, Serginho do Teclado <> wrote in
    cakewalk.audio:
    > series.
    Those are external MIDI devices, aren't they? As such, I don't think
    they would need Windows system drivers.
  3. Glennbo Guest
    Message Count:
    In news:Xns9D7680052E230nilch1@130.133.4.11 the killer robot Nil
    <> grabbed the controls of the spaceship
    cakewalk.audio and pressed these buttons...
    >> series.
    I think those modules are USB.
    I also see they got USB drivers for Vista and Vista 64, whish should work
    in Windows 7. Here's some for the SC8850.
    http://www.synthman.com/roland/Roland_SC-8850.html
    Remove YourHeadFromYourAss to Reply by email
    ________ __
    / ____/ /__ ____ ____ / /_ ____
    / / __/ / _ \/ __ \/ __ \/ __ \/ __ \
    / /_/ / / __/ / / / / / / /_/ / /_/ /
    \____/_/\___/_/ /_/_/ /_/_.___/\____/
    Glennbo http://www.soundclick.com/glennbo
    Non-Linear Sound http://www.soundclick.com/jambits
    Hear My Music http://www.soundclick.com/ThePseudonyms
  4. Nil Guest
    Message Count:
    On 12 May 2010, Glennbo <> wrote in
    cakewalk.audio:
    > should work in Windows 7. Here's some for the SC8850.
    I see you're right. I had never heard of these before. Here are
    (probably the same drivers) directly from the Roland site:
    http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=SC-8850
    I would expect the Vista drivers would work for Windows 7, but ya never
    know...
    It looks like you may need their special "GS Advanced Editor" software
    to easily get at the unit's deep parameters. It also looks like this
    unit dates from the Win98/2000 days. I don't see that software on the
    site, and even if I could find it I would be worried that it wouldn't
    work on the latest couple of Windows versions.
    Funny how something that seems so hi-tech at the time becomes obsolete
    so quickly.
      • Advertising
  5. Ben Goldman Guest
    Message Count:
    Nil let loose with the following tirade:
    > cakewalk.audio:
    > > series.
    Nil, if he wants to use the *Host* serial com port he'll need a driver.
    BTW - I use XP and don't know where to get that driver. I have an SC-880 and just use the MIDI
    ports these days.
    Cheers,
    Ben
  6. Glennbo Guest
    Message Count:
    The killer robot Nil <> grabbed the controls
    of the spaceship cakewalk.audio and pressed these buttons...
    > know...
    > so quickly.
    I gave away my last hardware based module last year. It was a Roland
    SC880, and I gave it to my wife along with a Roland Vintage Keys module.
    Put them into a cheep rack and hooked 'em up at her church gig for her.
    Now I use nothing but pure softsynths, and I don't miss the hardware at
    all.
    ________ __
  7. Serginho do Teclado Guest
    Message Count:
    On May 13, 4:19 am, "Ben Goldman" <>
    > > cakewalk.audio:
    > > > series.
    > Nil, if he wants to use the *Host*  serial com port he'll need a driver..
    > ports these days.
    > Cheers,
    > Ben
    I use USB, not serial. Used all 3 of them for years with XP and
    Vista.
    I do have GS Advanced Editor, but it has nothing to do with USB
    drivers.
  8. Serginho do Teclado Guest
    Message Count:
    > > > cakewalk.audio:
    > > > > series.
    > > ports these days.
    > > Cheers,
    > > Ben
    > Vista.
    > drivers.
    Vista 64 bit driver worked for Vin7 64 bit. Thanks Glenbo.
  9. Glennbo Guest
    Message Count:
    The killer robot Serginho do Teclado <> grabbed the
    controls of the spaceship cakewalk.audio and pressed these buttons...
    Cool! I would expect most Vista drivers to work with Win7.
    ________ __
      • Advertising
Share This Page
