windows seven tweaks for MAO?
Discussion in 'alt.steinberg.cubase' started by Hueyduck, May 15, 2010.
  1. Hueyduck Guest
    Message Count:
    Hi,
    As said in a previous thread, I'm trying out Win 7 x64.
    What list of tweaks would you recommend?
    I feel like I'm gonna be quite happy with this one:
    http://www.zikmao.net
    but I wondered if any other source was known amongst this forum's
    participants.
    Thx.
    Huey
      • Advertising
  2. Laurence Payne Guest
    Message Count:
    On Sat, 15 May 2010 16:14:51 +0200, Hueyduck <>
    None, unless things don't work well. Maybe the Background Services
    priority setting, though even that's unproved on multi-core systems.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
  3. Hueyduck Guest
    Message Count:
    Thanks for answering.
    As you know, under Win XP, there were a lot of services that could be
    turned off, ofr instance.
    This is what I want to do now: eliminate everything that eats processing
    power without being needed by cubase and my sound card.
    Would you say that it is unuseful? s : it was useful in Xp but not in
    seven?
    huey
  4. Laurence Payne Guest
    Message Count:
    On Sat, 15 May 2010 19:00:59 +0200, Hueyduck <>
    >seven?
    I'm not sure most of them made much difference in XP either! We're
    well past the days when underpowered computers had to be tweaked right
    up to the edge just to get audio to work at all. There's a hundred
    threads running just to keep Windows running, and you can't do
    anything about them. Turning off a few optional ones isn't going to
    be earth-shattering! Try "Background Services" and pull the plug on
    any network and Internet connections. Don't install any of the more
    invasive security suites. Don't schedule your virus scan for a time
    when you'll be recording! Indexing is quite heavy-duty during the
    initial scan, but after that it does little harm - I'd not worry about
    leaving it on if you find it useful. Don't choose a laptop as your
    music production machine. Other than that, don't go looking for
    problems until they look for you :)
    I felt sorry for XP users who took misguided advice to turn off System
    Restore. It's a lifesaver.
  5. Hueyduck Guest
    Message Count:
    Habits are hard to leave :))
    I never stopped making images of my HDDs, but not with Windows.
    On the other hand, I never had strange crashes. Ever, ever,ever, with my
    "tweaked" XP.
    But thx again, you answered my question quite thouroughly.
    Huey
      • Advertising
Share This Page
