WinXP swap file on system (C) or audio drive?
Discussion in 'alt.steinberg.cubase' started by gBOT, Mar 17, 2006.
  1. gBOT Guest
    Message Count:
    Hi there,
    Anyone know if it's better to have the windows swap file on your system
    drive or audio drive?
    e.g.
    C: drive (SATA) - windows system, applications etc incl Cubase SX2
    X: drive (SATA) - audio drive - all cubase files - windows swap file on
    this drive!
    I have 2GB RAM, and no swap file on C drive - just on the X drive
    swapfile size is set to 2048 min/max - which seems to work well for me.
    This is not (unfortunately) a dedicated audio PC, so I'm looking for
    the best "all round" option. i.e. I know moving the swap file away from
    the windows drive gives better performance for general computer use,
    but does this compromise Cubase performance when it's accessing the
    same drive for it's audio?
    Does the swapfile even get used when running Cubase and plugins?
    If it is used much (obviously RAM dependent) then I imagine it would
    probably be better to have the swap file back on the windows disk, so
    Cubase can use all the bandwidth on one drive for it's audio...?
      • Advertising
  2. Laurence Payne Guest
    Message Count:
    Shouldn't do. I wouldn't worry too much about it.
  3. Hilmar Steinhauer Guest
    Message Count:
    Hallo gBOT,
    gBOT schrieb:
    > Hi there,
    > e.g.
    > this drive!
    You should set the swapfile size to 3072 (1,5xRAM), even if it works
    with a smaller swapfile, to avoid issues with the windows memory
    manager.
    Yes. The swapfile is always in use, because the windows memory manager
    tries to provide as much fast physical memory as possible for
    applications wich are already running or to be started.
    42,
    Hlmar
  4. Terry Cano Guest
    Message Count:
    I have mine in the partition next to the C drive.
    Yes, I only run Cubase and there is swap file on drive D partition....
    It isn't very big though. I only have 1 Gig of RAM.
    Terry
      • Advertising
  5. Laurence Payne Guest
    Message Count:
    On Fri, 17 Mar 2006 14:39:23 +0100, Hilmar Steinhauer
    What if there is plenty of physical memory?
  6. Hilmar Steinhauer Guest
    Message Count:
    Hallo Laurence Payne,
    The windows memory manager swaps even then. It's much less, though.
    42,
    Hilmar
  7. Aphelion Guest
    Message Count:
    On Sat, 18 Mar 2006 00:03:47 +0100, Hilmar Steinhauer
    >42,
    >Hilmar
    Remember.....
    ConservativeSwapfileUsage=1
    Ap
  8. Laurence Payne Guest
    Message Count:
    What if (on a system with ample RAM, say 2GB) you disable the swap
    file altogether?
  9. gBOT Guest
    Message Count:
    i think that causes problem for windows, if it's turned off altogether.
  10. Hilmar Steinhauer Guest
    Message Count:
    > file altogether?
    This may cause trouble and provides absolutely no performance gain.
    42,
    Hilmar
  11. Hilmar Steinhauer Guest
    Message Count:
    Hallo Aphelion,
    >>42,
    >>Hilmar
    > Remember.....
    Yepp. Back then, memory management tuning was a bit effective. Nowadays
    the windows memory manager does it's job very well, even if it uses the
    swap file. It's an UL that swapping affects performance generally.
    42,
    Hilmar
  12. Aphelion Guest
    Message Count:
    On Sat, 18 Mar 2006 12:17:15 +0100, Hilmar Steinhauer
    <> wrote:
    >Hallo Aphelion,
    >>>42,
    >>>Hilmar
    >> Remember.....
    I've never found it to be a problem, it's not usually done when high
    priority tasks are executing.
    Ap
  13. Laurence Payne Guest
    Message Count:
    On Sat, 18 Mar 2006 12:12:56 +0100, Hilmar Steinhauer
    >> file altogether?
    But as some people seem convinced that the swap file on a modern
    system with ample RAM will be constantly churning and causing audio
    glitches...... :)
    I'm writing this on a laptop with Windows XP and 1GB RAM. Yesterday,
    just for fun, I disabled the swapfile. I'll let you know when
    something doesn't work. I'll also try doing the same on my music
    desktop when I have a protect to do without clients watching.
  14. Hilmar Steinhauer Guest
    Message Count:
    >>> file altogether?
    > glitches...... :)
    Maybe, on badly configured systems.
    42,
    Hilmar
  15. leutholl Guest
    Message Count:
    Am Sat, 18 Mar 2006 01:25:58 +0000 schrieb Laurence Payne:
    > file altogether?
    Windows Swap can be disabled in the control panel and if you have enough
    RAM (for Cubase at least more than 1.5GB) your system will never swap (see
    in the system monitor). Windows won't have a problem with no swap. If you
    really hit the limit for the physical range, you get an error message like
    (Not enough RAM to execute blablabla).
    I tried it but the difference is not big.
    I have 2 GB dual channel RAM, disabled swap, and I get a very fast machine.
    Lukas
  16. Giganews TEMP Guest
    Message Count:
    2G's o'RAM in dual channel is equivalent to 1G since you are only
    optimising the method that the data is stored in RAM. It really is no big
    deal...you machine doesn't magically improve.
    You'll need a swap file if you plan on using any plug-ins that are memory
    hogs or if you are planning to use more than 1 app (which I am sure you
    will).
    Not only that since it is not a dedicated machine don't even bother. There
    are apps (Photoshop for one) which will not run until you set a swap file. I
    did it myself with 1G. Like I said no big deal.
    If you are concerned about speed and laying down 32 tracks at once go Raptor
    or something similar. I have been tracking for 10 years. Machines today are
    more than adequate. SOS just finished writing an article on swap drive
    placement...I am not sure which month and I am not inclined to hunt/copy a
    link so you either ignore me or not *wink*. If you are planning on laying
    down large takes you might want to consider creating "current audio"
    partition on the outer rim of the disk (check out partition magic). this
    will speed up disk access time. In your case you might want to do that with
    the swap drive. For example:
    Drive 1 - Partition A - Current Project - outer ring
    - Partition B - OS - inner ring
    Drive 2 - Partition A - Swap File - outer ring
    - Partition B - Apps
    ***better yet get a 3rd drive for swap or current projects*****
    Have fun!!
    Lucid SfX
    "leutholl" <> wrote in message
    news:...
    >> file altogether?
    > machine.
    > Lukas
  17. Laurence Payne Guest
    Message Count:
    On Mon, 17 Apr 2006 22:13:52 -0400, "Giganews TEMP" <>
    You're saying that dual-channel halves the effective memory? Really?
    >will).
    No you won't.
    No it doesn't.
    Don't argue - try. I have one machine with 2GB of RAM than has been
    running without a swapfile for several weeks now. Multiple programs,
    sample-playing plugins, the lot. That computer doesn't have
    Photoshop. But this one does (Pentium 4 laptop, 1GB). I just set all
    drives to "No Paging File", clicked "Set" and restarted. Then opened
    Photoshop, loaded a large image and pulled it around a bit. No
    problem.
    I think your theories need re-examining.
  18. Hilmar Steinhauer Guest
    Message Count:
    > No it doesn't.
    > problem.
    Photoshop does not (only) use the windows swap, but it's own. You can't
    deactivate that.
    "Giganews TEMP" mixed that up.
    42,
    Hilmar
  19. Laurence Payne Guest
    Message Count:
    On Tue, 18 Apr 2006 16:35:48 +0200, Hilmar Steinhauer
    >deactivate that.
    I expect he just heard it somewhere. I've heard it too. But it ain't
    so.
    What IS interesting is that my 2GB desktop machine performs just the
    same with or without (Windows) swap file. The 1GB laptop is
    noticeably slower at opening some applications without a swapfile.
    From which I deduce that Windows makes intelligent use of paged memory
    for caching often-used files. With 2GB installed, those pages can all
    be in RAM. With only 1GB they can't.
      • Advertising
Share This Page
