Workstation with Win XP 64?
Discussion in 'alt.steinberg.cubase' started by Hueyduck, Jun 6, 2009.
  1. Hueyduck Guest
    Message Count:
    Hi,
    I'd like to install a 64bit OS in order to bypass the 3.5Go memory problem.
    Ire-read the latest thread about this, and the general advice wad to
    stick to XP 32 and wait for win7, thus skipping Vista.
    This is exactly what I wanted to do. But is anyone using XP64bits?
    MIght it not be a good way to keep XP and have 64 bits benefits?
    Huey
      • Advertising
  2. Phil W Guest
    Message Count:
    Hueyduck wrote:
    > Hi,
    > problem.
    Nice idea, but I´d leave it with the idea...
    The main problem with XP64 is still, that there´s very little 3rd party
    support and only very few drivers available.
    A guy from Steinberg said recently, "Cubase kind of works on XP64, but we
    are NOT supporting it at all!"
    XP64 was rather an experiment, than anything usable. Wait for Win7, buy the
    64bit version and benefit from Steinberg´s official 64bit Cubase5 support.
    Phil
  3. Hueyduck Guest
    Message Count:
    Thanks. I will do this, then.
    Huey
  4. Phil W Guest
    Message Count:
    Hueyduck:
    >> but we are NOT supporting it at all!"
    >> buy the 64bit version and benefit from Steinberg´s official 64bit
    >> Cubase5 support.
    > Huey
    Or, if you don´t want to wait, register with Microsoft (you need a "Live
    ID", formerly ".net passport") and download the "release candidate 1"
    version of Win7 as 64bit edition. Then, you just need a spare internal HD
    you can install Win7 on. If you have a spare computer with 64bit hardware,
    even better... ;-)
    NOTE: this "RC1" edition is for evaluation and testing purposes only!!!
    That´s why I recommend using a spare HD for testing Win7. best choice is to
    disconnect the normal hd with your normal OS and data on it, while testing
    Win7 (installed on a separate hd), so your main HD(s) is safe from any
    changes made by Win7.
    It´s a bit uncomfortable, but easy enough to do...
    Phil
  5. Laurence Payne Guest
    Message Count:
    I've had no problems with it as a multiboot on a partition rather than
    a removable drive. It does use a different multiboot system to XP -
    boot.ini is no longer used. But its easily reversible if you want to
    remove it.
    CubaseFAQ page: http://www.laurencepayne.co.uk/CubaseFAQ.htm
      • Advertising
Share This Page
