XV-2020,sysex and accessing higher sound banks
Discussion in 'alt.music.synth.roland' started by Guitarzan, Oct 15, 2005.
  1. Guitarzan Guest
    Message Count:
    Hi all,
    I have a few general questions regarding the XV2020 and a few sepcific
    quesions on how to reliably access and map it's higher bank sounds.
    1.
    Background: I am a solo act currently using my XV2020 as a GM module
    being driven by a laptop firing off my midi files using a proprietry
    program called Showplay. I am sick of the lame old GM sounds and really
    want to unlock the great sounds in the XV2020 and make sure the patch
    changes translate at gigs.
    2.
    So far: Using Cubase SX3 I have managed to start accessing some of the
    higher sounds using a script I found online and using the track
    inspector I can select the sounds I want and get the midi files to play
    back OK when still in Cubase. The problems start when I try to save
    the midi files and play them back on other equipment as I can't seem to
    get them to play back correctly(odd patch changes, XV-2020 reverts to
    GM mode, etc)
    3.
    I need clarification on: The way the XV deals with the differnt "areas"
    in the machine, such as "performance" versus "patch" versus "GM". I am
    confused as to the differnce between a "performance" setting and
    a"patch setting".
    3.a) What sysex files do I need to insert in my midi files to make sure
    I am accessing the correct areas of the machine in order to play the
    great sounds inside?
    3. b) When I select the sounds I like in Cubase, the midi files contain
    MSB dat bits. Is there a list of internal XV2020 sounds that show the
    combination of program change numnbers as well as theri MSB
    counterparts?
    4. As I am currently working thru my four hundred odd midi files and
    slowly porting them over to access the better sounds, I will be stuck
    using the older GM sounds for a lot of the night so I need to be able
    to mix and match my files so that I can fire off an older GM file and
    the unit will switch to GM mode (this is easy to do by inserting a GM
    reset at the start of each GM file).
    The problem for me occurs when I want to fire off a *non-GM* file. To
    play these back successfuly, I have discovered that I need to do an
    initialisation on the XV2020(using the front planel controls) and then
    the file will play OK. Is there either a sysex message I can send to
    the XV that will saet up the XV so that these *non-GM* files to be
    played correctly, or is there a sysex message that will initialise the
    XV-2020 in the same way that I do using the front panel controls?
    Although I am primarily a guitar player who is floundering thru the
    learning process with this great little unit, I'm not a total luddite
    so any help or tips will go a long way to clarifying the XV-2020's
    system and how to make it work for me.
    Thanks in advance for reading this slightly convoluted post and for any
    help that you might be able to give me.
    Cheers,
    Guitarzan!
      • Advertising
  2. S-E-A Guest
    Message Count:
    > GM mode, etc)
    Are you using 'commercial' MIDI files?
    I'm guess they have the sysex code to switch any module to GM if it's GM
    compatable.
    Strip the sysex code.
    > 3.
    > a"patch setting".
    Patch - just one sound on one MIDI channel.
    Performance - Multi-channel MIDI arrangement, different patches on different
    MIDI channels
    GM - A 'standard' so that a track plays back more or less what the
    programmer had in mind. Downside as you've found is the patches tend to be
    'vanilla'.
    Try and avoid the sysex, it's very MIDI intensive anyway, tends to make
    playback hicup.
    Bank select - then program number, it should allow you to access the patches
    from just about anywhere within the module, plus any that may be on
    expansion boards if fitted.
    > counterparts?
    It should be in the manual (I've a JV-2080 not a XV-2020 so I'm unable to
    give the list)
    GM = cheese!
    Once you've re-arranged your tracks you'll be a happier person.
    How about making a 'live performance' set-up in one of the user memories,
    one that can be recalled quickly, you could use MIDI to recall that
    perfoarmance, but odd things might happen if the MIDI channel you pick gets
    a rouge program change message from one of your 'old GM files'.
    Well you've done well so far, you've managed to access the XV's own patches.
    You seem to have sussed out how to get around the system, stick with it,
    it's bound to improve the quailty of your MIDI files.
  3. Guitarzan Guest
    Message Count:
    Thanks very much for the helpful insights.
    I think I'm slowly making progress........I started working on porting my
    files over using bank select data(MSB,LSB) and that seem to be working
    pretty well. I also am starting to sniff around the whole perfromance/patch
    concept.
    It's a bit convoluted, but hopefully I can structure several performances
    that Ill be able to apply to my files.
    Thanks again!
    "S-E-A" <> wrote in message
    news:s0h4f.3267$...
    > > GM mode, etc)
    > compatable.
    > > 3.
    > > a"patch setting".
    different
    > MIDI channels
    > 'vanilla'.
    > playback hicup.
    patches
    > > counterparts?
    > give the list)
    > GM = cheese!
    gets
    patches.
      • Advertising
Share This Page
