I have a Yamaha DX21 and I need to replace the "A" key on it. Is the replacement key only for that model, or can I use one from any DX series. -Jeff -Jeff
I think he means the "A" key.... not the A note key. They are micro buttons and it probably just needs a clean.... unless its packed up for good or bust off. FYI the DX21 didnt have velocity sens keyboard. What is the problem with the button? Missing/damaged/defunct? For reasons only known to himself, "Stratomaster" <> spouted from the largest hole in his head: "The Prof." <> wrote in message news:... > > > > I have a Yamaha DX21 and I need to replace the "A" key on it. Is the > replacement key only for that model, or can I use one from any DX series. > > > -Jeff > You'd need a key "switch" (plastic key you press is probably fine) for either a DX21 or DX7. Those are the only two I know of that have velocity sensitive keys.
