yamaha psr-630 & floppy drive connections?
Discussion in 'alt.music.synth' started by wave, Dec 8, 2004.
  1. wave Guest
    Message Count:
    Can anyone tell me if the yamaha psr-630 electronic music keyboard has a
    standard floppy disk drive with standard power and data connections, I have
    spent well over 2 hours trying to find this out by both searching webpages
    and newsgroup archives but frustratingly I have had no luck with a question
    that I thought would be common, I did find out that the older 620 model uses
    non-standard power & data connections and that some newer models uses
    standard connections so it remains to be seen where mine falls, it goes
    without saying really but I would really appreciate some help.
      • Advertising
  2. wave Guest
    Message Count:
    "wave" <wave@waving> wrote in message news:...
    have
    question
    uses
    And I did try yamaha, but got no reply and I live in New Zealand.
  3. Guest
    Message Count:
    I have the PSR-540 which has floppy drive .. also the 640 and 740 has
    a floppy .. which are builtin -- you don't need to connect them
    Frz
  4. wave Guest
    Message Count:
    <> wrote in message
    news:...
    > Frz
    I wanted to know if the data & power connections for the floppy drive were
    standard because if they are it means I can replace my psr-630 floppy drive
    with a standard pc floppy drive and therefore save a lot of money.
      • Advertising
Share This Page
