Anybody gone wireless with MIDI?
Shaggy
Administrator
Bluetooth MIDI has gotten a lot better from what I hear. Has anyone ditched the cables for good, or is the lag still a deal breaker for you?
Clovis, NM
It's been about 9 years since I last chained two MIDI instruments together, when I switched from the rather primitive Yamaha QS300 workstation of the early 1990's to my later Roland GW7 arranger I bought in 2008. Roland's styles were the more preferrable small combo type backing band than full orchestral / symphonic stage band of say the Yamaha arranger keyboards (my personal impression based on several Yamaha keyboards I owned in the 1980's - 1990's.)
In 2015 - 2017, I was using the Salvation Army's QS300 as the controller and my 1990's GeneralMusic (GEM) WK2AR-HD hard disk arranger that I bought used but in clean condition then. (Think I paid $300 for it. Back in the late 1990's it was going for around $1,500. Late 1990's I bought GEM's cheaper PK7 61 key arranger keyboard for around $800. It used the sound engine of their more expensive keyboards plus I could install several aftermarket styles at a time, bought from GEM's on-line store. Some time in the early 2000's, GEM went out of business. GEM's WK2 arranger for the time was a very decent competent instrument.)
I had my MIDI instruments connected up near each other, like for example my older 1990's GeneralMusic (GEM) WK2AR-HD hard disk arranger to one of my keyboards as its controller. I need access to both so the WK2 sits on its own stand above and to the side of my keyboard. I cut a piece of 1/2-inch plywood a touch larger than the QS300 footprint, laid the ply on the stand with the QS300 sitting on it. Bought and clamped an above tier short stand to the plywood with the WK2 sitting on it. Thus, direct connect MIDI cables is all I needed for both to communicate with each other. This is what the WK2's interface looked like:
It now sits stored in its own custom case I bought for it, but one of these days I may bring it out again and connect to one of current keyboards.
This is a recording of the WK2 ganged via MIDI to the QS300 from 2016. Quality is somewhat mediocre because I used my FujiFilm S9150 bridge camera's video mode to record it. (The S9150 is good for quick and dirty takes.) This was during a practice session I was doing in the local Salvation Army Corps chapel room. The WK2 style is one in a CD's worth of a couple hundred styles I purchased from an on-line European store then. My voice is not well suited for this style of music but is sufficient to lead people in a congregational setting.
Betzi
