B 3 Hammond organ
Hi, does anyone play a B3 Hammond organ and have any technical knowledge?
Yes. What sort of technical knowledge are you referring to, how to technically maneuver around the hammond or technical knowledge around mechanical troubleshooting? If the latter, this forum is your best bet:
What do you wwant to know about the Hammond B3/C3 organs.? I used to play them, service them and refurbish them. They have been the workhorse for bands for years. Very heavy and hard to move as with the Leslie cabinets. I now play a Korg PaX5 that does great job of simulating them including all the drawbars, switches the Leslie speaker settings and controls.
Ed
Look up Tony Monaco's organ course. Worth every penny to save you a ton of time. Wish I had it whenI was starting out. 👍
/I have a problem with my volume pedal, and only my foot pedals and the far right drawbars have tiny volume. What can it be? A tube or something else?
I have a problem with my volume pedal, and only my foot pedals and the far right drawbars have tiny volume.What can it be? A tube or something else?
luisruiz
