Bend pitch 12 semitones rather than only 2?
I have a Roland RD2000 and the pitch bend lever only bends the pitch at most 2 semitones. I've looked all around without success to bend the pitch a full octave (12 semitones). I'm trying to emulate the full octave guitar slide at the beginning of the CCR song Sweet Hitch-Hiker. All thoughts welcome.
Upper Midwest - United States
This is from an AI Google search so YMMV…
(I found it in a sub menu in my D50 for individual patches.)
I searched “pitch bend semitones Roland RD2000”
“You can adjust the pitch bend range on the Roland RD-2000 from 0 to 24 semitones (up to two octaves up and down) for most editable internal synthesizer and ensemble tones.
How to Adjust Pitch Bend Range
  • Press the Tone Designer button on the front panel for compatible tones (like SuperNATURAL synth or clav sounds).
  • Select Pitch Bend Range from the on-screen menu list.
  • Use the encoder or value button to choose your desired semitone value (0–24).
  • Remember to save your Scene/Program so the new bend range is retained with your custom setup.
Exceptions
  • Acoustic & V-Piano Engines: The pitch bend range for dedicated acoustic piano and V-Piano programs is fixed or restricted (typically locked to a +/- 1 tone or non-adjustable depending on the engine layer).
  • Tonewheel Organs: Organ patches generally do not support a wide adjustable bend range and remain fixed at standard behavior.”
Hopefully this can get you started.
You’re welcome.
It could be that you’re locked-in to +/- 1 tone (two semitones) per the exception above for Acoustic & V-piano engines.
As much as I love Roland equipment, there are sections of their manuals that just don’t translate well into English.
As another poster has said, “Ed Diaz is the Roland Guru of everything.
He has created all the Roland Product Support video tutorials.
Additionally Ed contributes to Roland’s Facebook page and to his own page.”
Perhaps you could get a definitive answer by reaching out to him.
Thanks again, shadedude. I've watched a number of videos from Ed Diaz and agree he is the guru. I'll see if Ed can help.
Cheers.
Oogie Wa Wa
Nate, bass and keys for The Feds Band
NW Ohio, Ottawa County
Cheers.
For what it's worth, the Juno DS has a system setting to change the amount of pitch bend. But I can't look that up for yours exactly, of course. The manuals are written in engineering instead of musician. Somewhere it tells you how things work, the How, but not ever the When or Why.
Edit: If you have the electronic versions of the owners manual and the Parameter Guide in pdf or doc format, you can do a a Find for the word 'bend' and find it. Don't use 'pitch', there's about 700 instances. You should be able to get all the documents from the Roland website.
I have actually accomplished exactly this (12 semi-tone pitch bend). With your voice selected, hit the [TONE DESIGNER] button to bring up this screen:
Then [ENTER] to get to this screen:
I've circled the setting that got it for me.
Important caveat: As a previous response noted, there are some tones that do NOT support changing the pitch bend range. I happened to do this for Voice 0403 VintageStr 3. Which voice are you trying to do this for?
Oh, and agreed about the Roland documentation -- it's next to useless.
Varga47: Ah, that was it. Thank you kindly!!!
Fyi, I used it on 0667 Dist Gtr 2 and sounds similar enough for the opening of CCR Sweet Hitch-hiker (starting from D3 going down to D2 on 88 keys).
Betzi
