Casio PX730 sunken keys
Brisbane Australia
I fix electric pianos for a hobby, and sell them on cheap. I'm getting fairly good at Casios (I know they're easy) The hammer cap rubbers are cheap from Aliexpress but I do find, while they work on all the Casios I have done they are not always the same dimensions. And some have W and B printed upside down too. Also they are always looser on the hammer than the originals but that seems ok. I just fixed a Privia PX730. (What a mongrel to get out of the frame) One question for you experts: On this model what is the single contact strip on the top which is pressed by the key. The double strip is underneath and pressed by the upward movement of the hammer. With the single PCB unplugged it still plays. Another question I should have asked ages ago, what is the safest way to clean the contact boards and the rubbers. I won't tell you how I do it in case you say it's wrong.
Betzi
