- Joined
- Feb 5, 2022
- Messages
- 14
- Reaction score
- 1
Hi everyone.
Wanted to hear peoples thoughts on entry level midi keyboards vs higher priced ones. I'm not so much interested in a midi controller that can do the things your digital Audio Workstation can do, more in the quality of the build itself. In my time I've owned an M-Audio, Alesis, SubZero (Avoid), Nektar and other 100 ueor/dollar range keyboards.
I did a check on the best rated midi keybaords and the winners were Aturia, Akai, Roland and Native Instruments. All of these come in at the highest prices. I guess my question is, have people found there is a discernable difference? For me, I've just lost my Nektar 49 key that cost 100 Euro after having it only a few days. The little white plastic box that holds the four data and power pins in place on the USB type B port came out and wedged itself in the cable. I insert these cables carefully, without force and remove them the same way, The online music store just emailed me to say Nektar blame me for it so they are not issuing a replacement and my warranty doesnt cover it. This amazes me as it's equally posible the mold for the USB is a cheap part or badly soldered as it is that I pulled on the keyboard with a cable atatched (I didn't).
To surmise:
Akai, Roland, Arturia,Novation, Native Instruments - Good
M-Audio, Alesis - Fair
Nektar, SubZero -Avoid
My best keyboard, a Novation launchkey MKIII has never had such issues. So I'm wondering should I stick to the more expensive brands? has anyone else bought cheaper keyboards only to regret it?
To surmise:
