Dual Leslie 2101s
Baltimore MD
I'm using an XK-1c and it directly interfaces with the 2101 via 8 pin DIN cable. Has anyone found a way to run two 2101s with the organ switch controlling each rotors?
First things first -- I'm jealous of anyone who gets to play with a Hammond and TWO Leslie 2101s!
That said, the image (from the 2101 Owners Manual) has the info you need, as it shows what has to be (1) Keyboard connecting to (2) Horn Units (the 2101s) and then to (2) Stationary Units (the Leslie 2121s).
You might not have a 2121 (as I don't either) -- but the note about the "Leslie 11-pin 'Y' Cable" is what should allow you to connect (2) 2101s to your board.
Good luck -- and please be sure to let us know if this works for you!
Old No7
I'm assuming no pins on the 8-pin carry power since the 2101 is self powered, so the 8 pin should only be carrying hot/cold and speed switching instructions. If that is the case you should be able to create a custom cable that allows two 8-pin outlets on one end so that you can independently connect a 2101 into each outlet. The issue will be finding the 8-pin din plug. Hammond only sells complete cables but it should be possible with an internet search to find just the end plug, then tap the wires to create a 2nd "end" on one of the ends, so an 8-pin din on one end and two 8-pin dins on the other end. It should work.
Betzi
