Fixing Yamaha keyboard
Hello. Have Yamaha PRS 500 keyboard. Some of the keys are not working. Need step by step instructions how to open and fix keyboard. Please if u know any sites that may be helpful,please let me know . Thanks
Welcome
Google
Yamaha PSR 500 Service Manual.
You will get a list of results amongst which there will be a downloadable service manual which will go through all you should need.
Good luck and do return for more info or further help.
Search on "Yamaha keyboard repair" on Youtube.
Lots of useful howto videos there.
Sounds like corrosion issues. Replace the MK boards (all). The rubber contacts separate from the original boards and most likely can be reused.
Similar Threads
emmecciq
