Genos 2 2.0 Update soon
Norway
It's to find here. 👍
https://europe.yamaha.com/en/musica...workstations/genos2/support.html#product-tabs
V1.30 to V2.00
  • The Mixer display can now be called up while using Style Creator. In addition, the workflow for channel recording has been improved with the addition of Preview and Undo/Redo functions.
  • The Master Compressor has been upgraded to a multiband compressor.
  • Step Edit is now available for the Chord Looper function.
  • You can now set USB Function Audio channels as multi-channel output destinations on the Line Out display. You can also select the number of USB Audio output channels (4 or 16) on the Utility display.
  • S.Art+ Voices are now supported.
  • Chinese can now be selected as the display language.
  • Smart Chord has been added to Fingering Type.
  • Now supports use with the "EXPANSION EXPLORER" app (V1.7.0), featuring faster data transfer via USB and a function for optimizing the User storage of the instrument.
  • Fixed a problem that occurred when attempting to convert a Music Finder file containing User Style information.
  • Fixed a problem in which parameter changes might not be correctly reflected on the display when switching Registration Memories.
  • Fixed a problem with Song recording in which selecting not to overwrite a file canceled the save operation instead of returning to the file name entry operation.
  • Fixed a problem in which, under certain conditions, some settings might not be restored correctly when Factory Reset was performed or "System" data in Setup Files was loaded.
  • Fixed a problem in which the Chord Looper function could become unresponsive when recalling a Registration Memory under certain conditions.
Aslo other updates:
Yamaha Expansion Manager V2.12.1 and Expansion Explorer V1.7 are to find at the downloadpage
Don't forget to check out the manuals who are updated as well. New v.E0
Betzi
